查看: 3226|回復(fù): 0
[原創(chuàng)]
ID:37408 發(fā)表于 2012-3-29 22:44 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
void key34x(uchar xuanzhe);//reentrant
void key34()
    void LCM12864_Clear_Screen();
  key=0;
  while(key==0){key=kbscan();}
switch(key)
   case 0xee: yumen_startdisplay(0);key34x(1);break;
   case 0xde: yumen_startdisplay(0);key34x(2);break;
   case 0x7e: yumen_startdisplay(0);key34x(3);break;
   case 0x77: personshow();break;//返回
   default: break;
void key34x(uchar xuanzhe)    reentrant
      uchar jump=1;
      uchar xx;
      uchar ee=1;;
      if(xuanzhe==1) xx=ffrate;
      if(xuanzhe==2) xx=clong;
      if(xuanzhe==3) xx=unit_price;
      if(xuanzhe==4) jump=0;
    if(jump==1)
      if(xx>10)
       {  key=0;
           while(key==0)
           { key=kbscan();
             LCM12864_display(2,8,2*xuanzhe-2,80,shuzi[temp_shi]);
             LCM12864_display(2,8,2*xuanzhe-2,80,kongge);
     switch(key)
          { case 0xd7:b=0;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xee:b=1;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xde:b=2;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0x7e:b=3;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xed:b=4;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xdd:b=5;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xbd:b=6;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xeb:b=7;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xdb:b=8;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xbb:b=9;LCM12864_display(2,8,2*xuanzhe-2,32,shuzi);break;
            case 0xe7:xuanzhe=xuanzhe+1;key34x(xuanzhe);ee=0; break;
            case 0x77:jump=0;personshow();break;//返回
            default:break;
main()
 key34();
出現(xiàn)的問題: error C231: 'key34x': redefinition
實(shí)在不知道哪里出錯(cuò)了。key34x() 我用了  reentrant 函數(shù)。
往哪個(gè)大神 幫忙看看。
