查看: 1918|回復(fù): 1
課程設(shè)計(jì)-單片機(jī)數(shù)字鐘源碼
ID:425693 發(fā)表于 2018-11-13 15:17 | 顯示全部樓層 |閱讀模式
數(shù)字鐘設(shè)計(jì)(基于單片機(jī)的設(shè)計(jì)——實(shí)驗(yàn)箱或Proteus仿真)
設(shè)計(jì)要求:
l 顯示格式:hh-mm-ss
l 可更改的12小時(shí)制或24小時(shí)制
l 整點(diǎn)報(bào)時(shí)功能
l 鬧鐘功能
l 對時(shí)調(diào)整功能
l 秒表功能
  1. #include<reg51.h>
  2. /*------------------檢查忙位-----------------------------*/
  3. void chk_busy();
  4. /*------------------延時(shí)子程序-----------------------------*/
  5. void delay(unsigned int num);
  6. /*------------------寫命令到LCD------------------------------*/
  7. void write_com(unsigned char cmdcode);
  8. /*-------------------寫數(shù)據(jù)到LCD----------------------------*/
  9. void write_data(unsigned char Dispdata);
  10. /*------------------初始化LCD屏--------------------------*/
  11. void lcdreset();
  12. /*------------------顯示字符串--------------------------*/
  13. void hzkdis(unsigned char  *s,unsigned char len);
  14. /*------------------清屏命令--------------------------*/
  15. void clrscreen();
  16. void change();
  17. sbit RS = P2^0;
  18. sbit RW = P2^1;
  19. sbit E  = P2^2;
  20. void zhengdianbaoshi();
  21. void naozhong();
  22. void Pwm_Set(unsigned int Hz,unsigned char Pwm);
  23. void key_scan();
  24.    sbit key1=P3^0;
  25.    sbit key2=P3^1;
  26.    sbit key3=P3^2;
  27.    sbit key4=P3^3;
  28.    sbit key5=P3^4;
  29.    sbit key6=P3^5;
  30.    sbit key7=P3^6;
  31.    sbit key8=P1^1;
  32.    sbit key9=P1^2;
  33.    sbit BEEP=P1^0;
  34. #define Lcd_Bus P0
  35. unsigned char ADDR=0x90;
  36. volatile unsigned char sec=0,min=59,hour=23;
  37. unsigned char  disp_hour[2]={'0','0'};
  38. unsigned char  disp_min[2]={'0','0'};
  39. unsigned char  disp_sec[2]={'0','0'};
  40. void main()
  41. {
  42.
  43.
  44.         EA=1;
  45.         ET0=1;
  46.         TH0=0x3c;
  47.         TL0=0xb0;
  48.         TMOD=0x01;
  49.         TR0=1;
  50.         lcdreset();
  51.         clrscreen();
  52.         write_com(0x80);
  53.                   hzkdis("張玉科",6);
  54.             hzkdis("、陳偉藝:",9);
  55.                 write_com(0x90);//0x90 start
  56.                   hzkdis("鬧鐘:",6);
  57.             hzkdis("00",2);
  58.                 hzkdis(":",1);
  59.                 hzkdis("01",2);
  60.                 write_com(0x88);//0x88
  61.                   hzkdis("報(bào)時(shí):",6);
  62.             hzkdis("整點(diǎn)",6);
  63.         while(1)
  64.         {
  65.
  66.                 if(sec>=60)
  67.                 {
  68.                         min++;
  69.                         sec=0;
  70.                 }
  71.                 if(min>=60)
  72.                 {
  73.                         hour++;
  74.                         min=0;
  75.                 }
  76.                 if(hour>=24)
  77.                 {
  78.                         hour=0;
  79.                 }
  80.
  81.                 change();
  82.             write_com(0x80);
  83.                   hzkdis("張玉科",6);
  84.             hzkdis("、陳偉藝:",9);
  85.                 write_com(0x90);//0x90 start
  86.                   hzkdis("鬧鐘:",6);
  87.             hzkdis("00",2);
  88.                 hzkdis(":",1);
  89.                 hzkdis("01",2);
  90.                 write_com(0x88);//0x88
  91.                   hzkdis("報(bào)時(shí):",6);
  92.             hzkdis("整點(diǎn)",6);
  93.                 write_com(0x98);//0x98
  94.                 hzkdis(disp_hour,2);
  95.                 hzkdis(":",1);
  96.                 hzkdis(disp_min,2);
  97.                 hzkdis(":",1);
  98.                 hzkdis(disp_sec,2);
  99.                 key_scan();
  100.                 zhengdianbaoshi();
  101.                    naozhong();
  102.
  103.         }
  104. }
  105. /*------------------檢查忙位-----------------------------*/
  106. void chk_busy()
  107. {
  108.         RS=0;
  109.         RW=1;
  110.         E=1;
  111.         Lcd_Bus=0xff;
  112.         while((Lcd_Bus&0x80)==0x80);
  113.         E=0;
  114. }
  115. /*------------------延時(shí)子程序-----------------------------*/
  116. void delay(unsigned int num)
  117. {
  118.         unsigned int i,j;
  119.         for(i=0;i<num;i++)
  120.         {
  121.                 for(j=0;j<5;j++)
  122.                 {
  123.                 }
  124.         }
  125. }
  126. /*------------------寫命令到LCD------------------------------*/
  127. void write_com(unsigned char cmdcode)
  128. {
  129.         chk_busy();
  130.         RS=0;
  131.         RW=0;
  132.         E=1;
  133.         Lcd_Bus=cmdcode;
  134.         delay(5);////////////////////在數(shù)據(jù)寫入的時(shí)候加入適當(dāng)?shù)难訒r(shí)
  135.         E=0;
  136.         delay(5);
  137. }
  138. /*-------------------寫數(shù)據(jù)到LCD----------------------------*/
  139. void write_data(unsigned char Dispdata)
  140. {
  141.         chk_busy();
  142.         RS=1;
  143.         RW=0;
  144.         E=1;
  145.         Lcd_Bus=Dispdata;
  146.         delay(5);///////////////////在數(shù)據(jù)寫入的時(shí)候加入適當(dāng)?shù)难訒r(shí)
  147.         E=0;
  148.         delay(5);
  149. }
  150. /*------------------初始化LCD屏--------------------------*/
  151. void lcdreset()
  152. {
  153.         delay(2000);
  154.         write_com(0x30);
  155.         delay(10); //選擇基本指令集
  156.         write_com(0x30); //選擇8bit數(shù)據(jù)流
  157.         delay(5);
  158.         write_com(0x0c); //開顯示(無游標(biāo)、不反白)
  159.         delay(10);
  160.         write_com(0x01); //清除顯示,并且設(shè)定地址指針為00H
  161.         delay(500);
  162.         write_com(0x06); //指定在資料的讀取及寫入時(shí),設(shè)定游標(biāo)的移動(dòng)方向及指定顯示的移位
  163.         delay(0);
  164. }
  165. /*------------------顯示字符串--------------------------*/
  166. void hzkdis(unsigned char  *s,unsigned char len)
  167. {
  168.         while(len!=0)
  169.         {
  170.                 write_data(*s);
  171.                 s++;
  172.                 len--;
  173.                 delay(50);
  174.         }
  175. }
  176. /*------------------清屏命令--------------------------*/
  177. void clrscreen()
  178. {
  179.         write_com(0x01);
  180.         delay(10);
  181. }/*------------------------------*/
  182. void timer0() interrupt 1
  183. {
  184.         static unsigned char i=0;
  185.         EA=0;
  186.         TF0=0;
  187.         TR0=0;
  188.         TH0=0x3c;
  189.         TL0=0xb0;
  190.         i++;
  191.         if(i>=20)
  192.         {
  193.                 i=0;
  194.                 sec++;
  195.         }
  196.
  197.         TR0=1;
  198.         EA=1;
  199. }
  200. void change()
  201. {
  202.         unsigned char k1,k2,k3;
  203.         k1=hour/10;
  204.         k2=min/10;
  205.         k3=sec/10;
  206.         disp_hour[0]=k1+0x30;
  207.         disp_hour[1]=(hour-k1*10)+0x30;
  208.         disp_min[0]=k2+0x30;
  209.         disp_min[1]=(min-k2*10)+0x30;
  210.         disp_sec[0]=k3+0x30;
  211.         disp_sec[1]=(sec-k3*10)+0x30;
  212. }
  213.     void key_scan()
  214. {
  215.           unsigned char hou=0,mi=0;
  216.
  217.         if(key1==0)
  218.         {
  219.                 delay(10);
  220.                 if(key1==0)
  221.                 {
  222.                         if(hour<23)
  223.                         {
  224.                                 hour++;
  225.                         }
  226.                         else
  227.                         {
  228.                                 hour=0;
  229.                         }
  230.      while(!key1);
  231.         }
  232.         }
  233.         if(key3==0)
  234.         {
  235.                 delay(10);
  236.                 if(key3==0)
  237.                 {
  238.                         if(min<59)
  239.                          {
  240.                             min++;
  241.                          }
  242.                         else
  243.                     {
  244.                                 min=0;
  245.                          }
  246.                 }
  247.      while(!key3);
  248.         }
  249.         if(key5==0)
  250.         {
  251.                 delay(10);
  252.                 if(key5==0)
  253.                 {
  254.                         if(sec<59)
  255.                         {
  256.                           sec++;
  257.                         }
  258.                         else
  259.                         {
  260.                            sec=0;
  261.                          }
  262.                 }
  263.      while(!key5);
  264.
  265.         }
  266.         if(key2==0)
  267.         {
  268.                 delay(10);
  269.                 if(key2==0)
  270.                 {
  271.                         if(hour>0)
  272.                         {
  273.                                 hour--;
  274.                          }
  275.                         else
  276.                         {
  277.                                 hour=23;
  278.                          }
  279.                 }
  280.      while(!key2);
  281.         }
  282.         if(key4==0)
  283.         {
  284.                 delay(10);
  285.                 if(key4==0)
  286.                 {
  287.                         if(min>0)
  288.                         {
  289.                             min--;
  290.                         }
  291.                         else
  292.                         {
  293.                             min=59;
  294.                      }
  295.                 }
  296.      while(!key4);
  297.         }
  298.         if(key6==0)
  299.         {
  300.                 delay(10);
  301.                 if(key6==0)
  302.                 {
  303.                         if(sec>0)
  304.                         {
  305.                                   sec--;
  306.                          }
  307.                         else
  308.                         {
  309.                                 sec=59;
  310.                         }
  311.                 }
  312.      while(!key6);
  313.
  314.         }
  315.         if(key7==0)
  316.         {
  317.                 delay(10);
  318.                 if(key7==0)
  319.
  320.                          {
  321.                                 hour=0;
  322.                                 min=0;
  323.                                 sec=0;
  324.                         }
  325.
  326.      while(!key7);
  327.
  328.         }
  329.
  330.         }
  331.   void zhengdianbaoshi()//整點(diǎn)報(bào)時(shí)(從50秒開始)
  332.     {
  333.            if(hour==hour&&min==59&&sec>50)
  334.                 {
  335.                   BEEP=!BEEP;
  336.                 }
  337.
  338.         }
  339.     void naozhong()//鬧鐘00:01:00,就響30秒
  340.    {
  341.
  342.       if(hour==0&&min==1&&sec<30)
  343.                 {
  344.                          BEEP=!BEEP;
  345.
  346.             }
  347.         }
Desktop.zip (2.01 KB, 下載次數(shù): 24)
ID:485100 發(fā)表于 2019-3-6 22:27 | 顯示全部樓層
有圖嗎
