將從外部輸入IO口的數(shù)據(jù)轉(zhuǎn)為10進(jìn)制數(shù),顯示在數(shù)碼管上
我不知道怎樣將IO口的數(shù)據(jù)讀入
求各位大俠幫小弟看看后面改怎么寫(xiě),怎么改
謝謝各位大俠!
#include<reg52.h> #include<string.h> #define uchar unsigned char #define uint unsigned int sbit a1=P3^0; sbit a2=P3^1; sbit a3=P3^2; sbit a4=P3^3; sbit a5=P3^4; sbit a6=P3^5; sbit a7=P3^6; sbit a8=P3^7; sbit a9=P0^0; sbit a10=P0^1; sbit a11=P0^2; sbit a12=P0^3; sbit a13=P0^4; sbit a14=P0^5; uchar code tabledu[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x80,0x00}; uchar count,wang,qin,bai,shi,ge; uint temp,aa,n,j,i,t=0,p=1; char a[50]; //延遲函數(shù) void delay(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } //初始化函數(shù) void init() { TMOD=0x01; //定時(shí)器T0為工作方式1 TH0=(65536-50000)/256; TL0=(65536-50000)%256; ET0=1; EA=1; //開(kāi)啟總中斷 TR0=1; //啟動(dòng)定時(shí)器 count=0;
} //顯示函數(shù) void display(uchar wang,uchar qin,uchar bai,uchar shi,uchar ge){ P2=tabledu[wang]; P1=0x00; delay(1);
P2=tabledu[qin]; P1=0x01; delay(1);
P2=tabledu[bai]; P1=0x02; delay(1);
P2=tabledu[shi]; P1=0x03; delay(1);
P2=tabledu[ge]; P1=0x04; delay(1);
} void main() { init(); char a[50]; //將2進(jìn)制數(shù)轉(zhuǎn)為10進(jìn)制數(shù) gets(a); n=strlen(a); for(i=n-1;i>=0;i--) { p=1; t=(a-48); if(i==n-1) { p=1; } else { for(j=0;j<n-i-1;j++) { p=p*2; } } temp+=t*p; } 、 while(1){ if(count==10){ count=0; wang=temp/10000; qin=temp%10000/1000; bai=temp%10000%1000/100; shi=temp%10000%1000%100/10; ge=temp%10; } display(wang,qin,bai,shi,ge); //調(diào)用顯示函數(shù) } } void timer0() interrupt 1 { TH0=(65536-50000)/256; TL0=(65536-50000)%256; count++; } |
