本帖最后由 oldspring 于 2018-11-17 09:27 編輯
51芯片內(nèi)部沒有Ethernet模塊,無法直接與網(wǎng)絡(luò)連接,但是我們可以利用外部網(wǎng)絡(luò)專用芯片ENC28J60,使得我們的51芯片可以進(jìn)行網(wǎng)絡(luò)通信。這里介紹一個(gè)簡(jiǎn)單的51 SPI Ethernet 測(cè)試程序,希望大家能夠喜歡。
注意:這個(gè)51編譯器的Ethernet庫函數(shù)支持:
- IPv4 protocol.
- ARP requests.
- ICMP echo requests.
- UDP requests.
- TCP requests (no stack, no packet reconstruction).
- packet fragmentation is NOT supported.
- // duplex config flags
- #define Spi_Ethernet_HALFDUPLEX 0x00 // half duplex
- #define Spi_Ethernet_FULLDUPLEX 0x01 // full duplex
- // mE ehternet NIC pinout
- sfr sbit Spi_Ethernet_RST at P1_0_bit;
- sfr sbit Spi_Ethernet_CS at P1_1_bit;
- // end ethernet NIC definitions
- * ROM constant strings
- const code unsigned char httpHeader[] = "HTTP/1.1 200 OKnContent-type: " ; // HTTP header
- const code unsigned char httpMimeTypeHTML[] = "text/htmlnn" ; // HTML MIME type
- const code unsigned char httpMimeTypeScript[] = "text/plainnn" ; // TEXT MIME type
- idata unsigned char httpMethod[] = "GET /";
- * web page, splited into 2 parts :
- * when coming short of ROM, fragmented data is handled more efficiently by linker
- * this HTML page calls the boards to get its status, and builds itself with javascript
- const code char *indexPage = // Change the IP address of the page to be refreshed
- "<meta http-equiv="refresh" content="3;url=http://192.168.20.60">
- <HTML><HEAD></HEAD><BODY>
- <h1>8051 + ENC28J60 Mini Web Server</h1>
- <a href=/>Reload</a>
- <script src=/s></script>
- <table><tr><td><table border=1 style="font-size:20px ;font-family: terminal ;">
- <tr><th colspan=2>P0</th></tr>
- <script>
- var str,i;
- str="";
- for(i=0;i<8;i++)
- {str+="<tr><td bgcolor=pink>BUTTON #"+i+"</td>";
- if(P0&(1<<i)){str+="<td bgcolor=red>ON";}
- else {str+="<td bgcolor=#cccccc>OFF";}
- str+="</td></tr>";}
- document.write(str) ;
- </script>
- const char *indexPage2 = "</table></td><td>
- <table border=1 style="font-size:20px ;font-family: terminal ;">
- <tr><th colspan=3>P3</th></tr>
- <script>
- var str,i;
- str="";
- for(i=0;i<8;i++)
- {str+="<tr><td bgcolor=yellow>LED #"+i+"</td>";
- if(P3&(1<<i)){str+="<td bgcolor=red>ON";}
- str+="</td><td><a href=/t"+i+">Toggle</a></td></tr>";}
- </script>
- </table></td></tr></table>
- This is HTTP request #<script>document.write(REQ)</script></BODY></HTML>
- * RAM variables
- idata unsigned char myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f} ; // my MAC address
- idata unsigned char myIpAddr[4] = {192, 168, 20, 60} ; // my IP address
- idata unsigned char getRequest[15] ; // HTTP request buffer
- idata unsigned char dyna[29] ; // buffer for dynamic response
- idata unsigned long httpCounter = 0 ; // counter of HTTP requests
- * functions
- * put the constant string pointed to by s to the ENC transmit buffer.
- /*unsigned int putConstString(const code char *s)
- unsigned int ctr = 0 ;
- while(*s)
- Spi_Ethernet_putByte(*s++) ;
- ctr++ ;
- return(ctr) ;
- * it will be much faster to use library Spi_Ethernet_putConstString routine
- * instead of putConstString routine above. However, the code will be a little
- * bit bigger. User should choose between size and speed and pick the implementation that
- * suites him best. If you choose to go with the putConstString definition above
- * the #define line below should be commented out.
- #define putConstString Spi_Ethernet_putConstString
- * put the string pointed to by s to the ENC transmit buffer
- /*unsigned int putString(char *s)
- while(*s)
- ctr++ ;
- return(ctr) ;
- * it will be much faster to use library Spi_Ethernet_putString routine
- * instead of putString routine above. However, the code will be a little
- * suites him best. If you choose to go with the putString definition above
- #define putString Spi_Ethernet_putString
- * this function is called by the library
- * the user accesses to the HTTP request by successive calls to Spi_Ethernet_getByte()
- * the user puts data in the transmit buffer by successive calls to Spi_Ethernet_putByte()
- * the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit
- * if you don't need to reply to HTTP requests,
- * just define this function with a return(0) as single statement
- unsigned int Spi_Ethernet_UserTCP(unsigned char *remoteHost, unsigned int remotePort, unsigned int localPort, unsigned int reqLength)
- idata unsigned int len; // my reply length
- if(localPort != 80) // I listen only to web request on port 80
- return(0) ;
- // get 10 first bytes only of the request, the rest does not matter here
- for(len = 0 ; len < 10 ; len++)
- getRequest[len] = Spi_Ethernet_getByte() ;
- getRequest[len] = 0 ;
- len = 0;
- if(memcmp(getRequest, httpMethod, 5)) // only GET method is supported here
- return(0) ;
- httpCounter++ ; // one more request done
- if(getRequest[5] == 's') // if request path name starts with s, store dynamic data in transmit buffer
- // the text string replied by this request can be interpreted as javascript statements
- // by browsers
- len = putConstString(httpHeader) ; // HTTP header
- len += putConstString(httpMimeTypeScript) ; // with text MIME type
- // add P3 value (buttons) to reply
- len += putConstString("var P3=") ;
- WordToStr(P3, dyna) ;
- len += putString(dyna) ;
- len += putConstString(";") ;
- // add P0 value (LEDs) to reply
- len += putConstString("var P0=") ;
- WordToStr(P0, dyna) ;
- // add HTTP requests counter to reply
- WordToStr(httpCounter, dyna) ;
- len += putConstString("var REQ=") ;
- else if(getRequest[5] == 't') // if request path name starts with t, toggle P3 (LED) bit number that comes after
- unsigned char bitMask = 0 ; // for bit mask
- if(isdigit(getRequest[6])) // if 0 <= bit number <= 9, bits 8 & 9 does not exist but does not matter
- bitMask = getRequest[6] - '0' ; // convert ASCII to integer
- bitMask = 1 << bitMask ; // create bit mask
- P3 ^= bitMask ; // toggle P3 with xor operator
- if(len == 0) // what do to by default
- len += putConstString(httpMimeTypeHTML) ; // with HTML MIME type
- len += putConstString(indexPage) ; // HTML page first part
- len += putConstString(indexPage2) ; // HTML page second part
- return(len) ; // return to the library with the number of bytes to transmit
- * the user accesses to the UDP request by successive calls to Spi_Ethernet_getByte()
- * the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit
- * if you don't need to reply to UDP requests,
- unsigned int Spi_Ethernet_UserUDP(unsigned char *remoteHost, unsigned int remotePort, unsigned int destPort, unsigned int reqLength)
- idata unsigned int len ; // my reply length
- idata unsigned char * ptr ; // pointer to the dynamic buffer
- // reply is made of the remote host IP address in human readable format
- ByteToStr(remoteHost[0], dyna) ; // first IP address byte
- dyna[3] = '.' ;
- ByteToStr(remoteHost[1], dyna + 4) ; // second
- dyna[7] = '.' ;
- ByteToStr(remoteHost[2], dyna + 8) ; // third
- dyna[11] = '.' ;
- ByteToStr(remoteHost[3], dyna + 12) ; // fourth
- dyna[15] = ':' ; // add separator
- // then remote host port number
- WordToStr(remotePort, dyna + 16) ;
- dyna[21] = '[' ;
- WordToStr(destPort, dyna + 22) ;
- dyna[27] = ']' ;
- dyna[28] = 0 ;
- // the total length of the request is the length of the dynamic string plus the text of the request
- len = 28 + reqLength;
- // puts the dynamic string into the transmit buffer
- Spi_Ethernet_putBytes(dyna, 28) ;
- // then puts the request string converted into upper char into the transmit buffer
- while(reqLength--)
- Spi_Ethernet_putByte(toupper(Spi_Ethernet_getByte())) ;
- return(len) ; // back to the library with the length of the UDP reply
- * main entry
- void main()
- * starts ENC28J60 with :
- * reset bit on P1_0
- * CS bit on P1_1
- * my MAC & IP address
- * full duplex
- SPI1_Init();
- Spi_Ethernet_Init(myMacAddr, myIpAddr, Spi_Ethernet_FULLDUPLEX) ; // full duplex, CRC + MAC Unicast + MAC Broadcast filtering
- while(1) // do forever
- * if necessary, test the return value to get error code
- Spi_Ethernet_doPacket() ; // process incoming Ethernet packets
- * add your stuff here if needed
- * Spi_Ethernet_doPacket() must be called as often as possible
- * otherwise packets could be lost
復(fù)制代碼 相關(guān)信息:http://www.torrancerestoration.com/bbs/dpj-136722-1.html
SPI Ethernet .jpg (39.15 KB, 下載次數(shù): 47)
2018-11-17 09:26 上傳
