本帖最后由 zhou__mi 于 2020-6-22 19:12 編輯
程序代碼:
// 實(shí)驗(yàn)程序分為3個(gè)部分或者說(shuō)3個(gè)步驟:
//(1)RCC_Configuration 函數(shù)使能外設(shè)GPIO PORTC時(shí)鐘;
//(2)GPIO_Configuration函數(shù)設(shè)置PC6為50MHz推挽輸出;
//(3)GPIO_ResetBits庫(kù)函數(shù)設(shè)置PC6輸出低電平0,熄滅與PC6連接的LED1,
// GPIO_SetBits 庫(kù)函數(shù)設(shè)置PC6輸出高電平1,點(diǎn)亮與PC6連接的LED1。
* File Name : main.c
* Author : Zhou_yinxiang, 1881003@qq.com,CDUESTC
* Date First Issued : 03/08/2014
* Description : 點(diǎn)亮 或 熄滅 與PC6連接的LED1
使用ST的庫(kù)函數(shù),MDK4.7,最簡(jiǎn)RCC配置,在AS-05(STM32-SS),AS-07,PROTEUS上驗(yàn)證通過(guò)
/* Includes ---------------------------------------------------------------*/
#include "stm32f10x_lib.h"//包含頭文件
/* Private function prototypes --------------------------------------------*/
void RCC_Configuration(void);//函數(shù)聲明
void GPIO_Configuration(void);//函數(shù)聲明
/* Private functions ------------------------------------------------------*/
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)//main函數(shù),在STM32F10x.s里,設(shè)置IMPORT __main為程序的入口
/* Configure the system clocks */
RCC_Configuration();//調(diào)用設(shè)置系統(tǒng)時(shí)鐘函數(shù)
/* Configure the GPIO ports */
GPIO_Configuration();//調(diào)用設(shè)置GPIO端口函數(shù)
//GPIO_ResetBits(GPIOC, GPIO_Pin_6); //PC6輸出低電平,熄滅LED1
GPIO_SetBits(GPIOC, GPIO_Pin_6); //PC6輸出高電平,點(diǎn)亮LED1
* Function Name : RCC_Configuration
* Description : Configures the different system clocks.
* Input : None
* Output : None
* Return : None
void RCC_Configuration(void)//設(shè)置系統(tǒng)時(shí)鐘函數(shù)
/* Enable GPIOA clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能GPIOC的時(shí)鐘
* Function Name : GPIO_Configuration
* Description : Configures the different GPIO ports.
* Input : None
* Output : None
* Return : None
void GPIO_Configuration(void)//設(shè)置GPIO端口函數(shù)
GPIO_InitTypeDef GPIO_InitStructure;//GPIO_InitStructure是GPIO_InitTypeDef結(jié)構(gòu)體
/* Configure PC6 as Output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//結(jié)構(gòu)體成員GPIO_Pin賦值
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//結(jié)構(gòu)體成員GPIO_Speed賦值
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//結(jié)構(gòu)體成員GPIO_Mode賦值
GPIO_Init(GPIOC, &GPIO_InitStructure);//按照上面賦值的結(jié)構(gòu)體初始化GPIOC端口,
//就是設(shè)置PC6為速度是50MHz的推挽(推拉)輸出工作模式
/**************** (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
