本帖最后由 zhou__mi 于 2020-6-22 19:21 編輯
2018-11-18 13:51 上傳
程序代碼:
//Pass at AS-07 V2.0,ZhouYinxiang,1881003@qq.com,20171009,9:55
//Pass at PROTEUS 8.7,ZhouYinxiang,1881003@qq.com,20181118,11:31
//實驗內(nèi)容和現(xiàn)象:
//(1)配置時鐘RCC;
//(2)配置中斷NVIC;
//(3)設置全部GPIO為Analog Input mode,降低功耗和提高EMI/EMC;
//(4)使能GPIOA的時鐘,設置PA5為GPIO_Mode_Out_PP 50MHz;使能GPIOC的時鐘,設置PC6和PC7為GPIO_Mode_Out_PP 50MHz;
//(5)LCD顯示實驗信息,沒有學習LCD之前,請忽略;
//(5)流水燈程序:PC6驅(qū)動LED1、PC7驅(qū)動LED2、PA5驅(qū)動LED3依次點亮、延時、熄滅,形成亮流水效果。
// 說明:程序源于STM3210E-EVAL,請看本project的readme.txt
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V2.0.1
* Date : 06/13/2008
* Description : Main program body.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
/* Private functions ---------------------------------------------------------*/
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)
#ifdef DEBUG
debug();
#endif
//(1)配置時鐘RCC;
/* System Clocks Configuration **********************************************/
RCC_Configuration();
//(2)配置中斷NVIC;
/* NVIC Configuration *******************************************************/
NVIC_Configuration();
////(3)設置全部GPIO為Analog Input mode,降低功耗和提高EMI/EMC;
// /* Configure all unused GPIO port pins in Analog Input mode (floating input
// trigger OFF), this will reduce the power consumption and increase the device
// immunity against EMI/EMC *************************************************/
// RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
// RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
// RCC_APB2Periph_GPIOE, ENABLE); //使能所有的端口時鐘
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All; //選擇設置所有的端口位
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模擬輸入模式
// GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化端口GPIOA
// GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化端口GPIOB
// GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化端口GPIOC
// GPIO_Init(GPIOD, &GPIO_InitStructure); //初始化端口GPIOD
// GPIO_Init(GPIOE, &GPIO_InitStructure); //初始化端口GPIOE
// RCC_APB2Periph_GPIOE, DISABLE); //失能(關(guān)閉)所有的端口時鐘
/* Configure IO connected to LED1, LED2, LED3 leds *********************/
/* Enable GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //使能GPIOA的時鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //使能GPIOC的時鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化PC6和PC7為50MHz推拉輸出
while (1)
/* Turn on LED1 */
GPIO_SetBits(GPIOC, GPIO_Pin_6); //PC6輸出高電平1,驅(qū)動LED1點亮
/* Insert delay */
Delay(0xAFFFF); //延時一會兒(0.05038140-0.00031892 = 0.05006248s = 50ms)
/* Turn off LED1 */
GPIO_ResetBits(GPIOC, GPIO_Pin_6); //PC6輸出低電平0,驅(qū)動LED1熄滅
/* Insert delay */
Delay(0xAFFFF); //延時一會兒(0.10044386-0.05038154 = 0.05006263s = 50ms)
/* Turn on LED2 */
GPIO_SetBits(GPIOC, GPIO_Pin_7); //PC7輸出高電平1,驅(qū)動LED2點亮
/* Insert delay */
/* Turn off LED2*/
GPIO_ResetBits(GPIOC, GPIO_Pin_7); //PC7輸出低電平0,驅(qū)動LED2熄滅
/* Insert delay */
/* Turn on LED3 */
GPIO_SetBits(GPIOA, GPIO_Pin_5); //PA5輸出高電平1,驅(qū)動LED3點亮
/* Insert delay */
/* Turn off LED3 */
GPIO_ResetBits(GPIOA, GPIO_Pin_5); //PA5輸出低電平0,驅(qū)動LED3熄滅
/* Insert delay */
實驗4-3 IOToggle.rar
2018-11-18 13:53 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
1.51 MB, 下載次數(shù): 8, 下載積分: 黑幣 -5
