//本程序只供學(xué)習(xí)使用,
// 功能描述 : 0.69寸OLED 接口演示例程(STM32F103ZE系列IIC)
// 說明:
// GND 電源地
// VCC 接5V或3.3v電源
// SCL 接PD6(SCL)
// SDA 接PD7(SDA)
//All rights reserved
#include "oled.h"
#include "stdlib.h"
#include "oledfont.h"
#include "delay.h"
//OLED的顯存
//存放格式如下.
//[0]0 1 2 3 ... 127
//[1]0 1 2 3 ... 127
//[2]0 1 2 3 ... 127
//[3]0 1 2 3 ... 127
//[4]0 1 2 3 ... 127
//[5]0 1 2 3 ... 127
//[6]0 1 2 3 ... 127
//[7]0 1 2 3 ... 127
//IIC Start
//IIC Start
void IIC_Start()
OLED_SCLK_Set() ;
OLED_SDIN_Set();
OLED_SDIN_Clr();
OLED_SCLK_Clr();
//IIC Stop
void IIC_Stop()
OLED_SCLK_Set() ;
// OLED_SCLK_Clr();
OLED_SDIN_Clr();
OLED_SDIN_Set();
void IIC_Wait_Ack()
//GPIOB->CRH &= 0XFFF0FFFF; //設(shè)置PB12為上拉輸入模式
//GPIOB->CRH |= 0x00080000;
// OLED_SDA = 1;
// delay_us(1);
//OLED_SCL = 1;
//delay_us(50000);
/* while(1)
if(!OLED_SDA) //判斷是否接收到OLED 應(yīng)答信號(hào)
//GPIOB->CRH &= 0XFFF0FFFF; //設(shè)置PB12為通用推免輸出模式
//GPIOB->CRH |= 0x00030000;
return;
OLED_SCLK_Set() ;
OLED_SCLK_Clr();
// IIC Write byte
void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
unsigned char m,da;
da=IIC_Byte;
OLED_SCLK_Clr();
for(i=0;i<8;i++)
m=da;
// OLED_SCLK_Clr();
m=m&0x80;
if(m==0x80)
{OLED_SDIN_Set();}
else OLED_SDIN_Clr();
da=da<<1;
OLED_SCLK_Set();
OLED_SCLK_Clr();
// IIC Write Command
void Write_IIC_Command(unsigned char IIC_Command)
IIC_Start();
Write_IIC_Byte(0x78); //Slave address,SA0=0
IIC_Wait_Ack();
Write_IIC_Byte(0x00); //write command
IIC_Wait_Ack();
Write_IIC_Byte(IIC_Command);
IIC_Wait_Ack();
IIC_Stop();
// IIC Write Data
void Write_IIC_Data(unsigned char IIC_Data)
IIC_Start();
Write_IIC_Byte(0x78); //D/C#=0; R/W#=0
IIC_Wait_Ack();
Write_IIC_Byte(0x40); //write data
IIC_Wait_Ack();
Write_IIC_Byte(IIC_Data);
IIC_Wait_Ack();
IIC_Stop();
void OLED_WR_Byte(unsigned dat,unsigned cmd)
if(cmd)
Write_IIC_Data(dat);
else {
Write_IIC_Command(dat);
// fill_Picture
void fill_picture(unsigned char fill_Data)
unsigned char m,n;
for(m=0;m<8;m++)
OLED_WR_Byte(0xb0+m,0); //page0-page1
OLED_WR_Byte(0x00,0); //low column start address
OLED_WR_Byte(0x10,0); //high column start address
for(n=0;n<128;n++)
OLED_WR_Byte(fill_Data,1);
/***********************Delay****************************************/
void Delay_50ms(unsigned int Del_50ms)
unsigned int m;
for(;Del_50ms>0;Del_50ms--)
for(m=6245;m>0;m--);
void Delay_1ms(unsigned int Del_1ms)
unsigned char j;
while(Del_1ms--)
for(j=0;j<123;j++);
//坐標(biāo)設(shè)置
void OLED_Set_Pos(unsigned char x, unsigned char y)
{ OLED_WR_Byte(0xb0+y,OLED_CMD);
OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
OLED_WR_Byte((x&0x0f),OLED_CMD);
//開啟OLED顯示
void OLED_Display_On(void)
OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
//關(guān)閉OLED顯示
void OLED_Display_Off(void)
OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
//清屏函數(shù),清完屏,整個(gè)屏幕是黑色的!和沒點(diǎn)亮一樣!!!
void OLED_Clear(void)
u8 i,n;
for(i=0;i<8;i++)
OLED_WR_Byte (0xb0+i,OLED_CMD); //設(shè)置頁(yè)地址(0~7)
OLED_WR_Byte (0x00,OLED_CMD); //設(shè)置顯示位置—列低地址
OLED_WR_Byte (0x10,OLED_CMD); //設(shè)置顯示位置—列高地址
for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
} //更新顯示
void OLED_On(void)
u8 i,n;
for(i=0;i<8;i++)
for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
} //更新顯示
//在指定位置顯示一個(gè)字符,包括部分字符
//x:0~127
//y:0~63
//mode:0,反白顯示;1,正常顯示
//size:選擇字體 16/12
void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
unsigned char c=0,i=0;
c=chr-' ';//得到偏移后的值
if(x>Max_Column-1){x=0;y=y+2;}
if(Char_Size ==16)
OLED_Set_Pos(x,y);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
OLED_Set_Pos(x,y+1);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
else {
OLED_Set_Pos(x,y);
for(i=0;i<6;i++)
OLED_WR_Byte(F6x8[c][i],OLED_DATA);
//m^n函數(shù)
u32 oled_pow(u8 m,u8 n)
u32 result=1;
while(n--)result*=m;
return result;
//顯示2個(gè)數(shù)字
//x,y :起點(diǎn)坐標(biāo)
//len :數(shù)字的位數(shù)
//size:字體大小
//mode:模式 0,填充模式;1,疊加模式
//num:數(shù)值(0~4294967295);
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
u8 t,temp;
u8 enshow=0;
for(t=0;t<len;t++)
temp=(num/oled_pow(10,len-t-1))%10;
if(enshow==0&&t<(len-1))
if(temp==0)
OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
continue;
}else enshow=1;
OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
//顯示一個(gè)字符號(hào)串
void OLED_ShowString(u8 x,u8 y,u8 *chr,u8 Char_Size)
unsigned char j=0;
while (chr[j]!='\0')
{ OLED_ShowChar(x,y,chr[j],Char_Size);
x+=8;
if(x>120){x=0;y+=2;}
j++;
//顯示漢字
void OLED_ShowCHinese(u8 x,u8 y,u8 no)
u8 t,adder=0;
OLED_Set_Pos(x,y);
for(t=0;t<16;t++)
OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
adder+=1;
for(t=0;t<16;t++)
OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
adder+=1;
/***********功能描述:顯示顯示BMP圖片128×64起始點(diǎn)坐標(biāo)(x,y),x的范圍0~127,y為頁(yè)的范圍0~7*****************/
void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
if(y1%8==0) y=y1/8;
else y=y1/8+1;
for(y=y0;y<y1;y++)
OLED_Set_Pos(x0,y);
for(x=x0;x<x1;x++)
OLED_WR_Byte(BMP[j++],OLED_DATA);
//初始化SSD1306
void OLED_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOG, ENABLE); //使能PC,D,G端口時(shí)鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_3|GPIO_Pin_8; //PD3,PD6推挽輸出
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
GPIO_Init(GPIOD, &GPIO_InitStructure); //初始化GPIOD3,6
GPIO_SetBits(GPIOD,GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_3|GPIO_Pin_8); //PD3,PD6 輸出高
#if OLED_MODE==1
GPIO_InitStructure.GPIO_Pin =0xFF; //PC0~7 OUT推挽輸出
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,0xFF); //PC0~7輸出高
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; //PG13,14,15 OUT推挽輸出
GPIO_Init(GPIOG, &GPIO_InitStructure);
GPIO_SetBits(GPIOG,GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15); //PG13,14,15 OUT 輸出高
#else
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; //PC0,1 OUT推挽輸出
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1); //PC0,1 OUT 輸出高
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; //PG15 OUT推挽輸出 RST
GPIO_SetBits(GPIOG,GPIO_Pin_15); //PG15 OUT 輸出高
#endif
delay_ms(200);
OLED_WR_Byte(0xAE,OLED_CMD);//--display off
OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
OLED_WR_Byte(0x81,OLED_CMD); // contract control
OLED_WR_Byte(0xFF,OLED_CMD);//--128
OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
OLED_WR_Byte(0x80,OLED_CMD);//
OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
OLED_WR_Byte(0x05,OLED_CMD);//
OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
OLED_WR_Byte(0xF1,OLED_CMD);//
OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
OLED_WR_Byte(0x12,OLED_CMD);//
OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
OLED_WR_Byte(0x30,OLED_CMD);//
OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
OLED_WR_Byte(0x14,OLED_CMD);//
OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
