誤差不大
- #include "reg51.h"
- #include "intrins.h"
- #define CKSEL (*(unsigned char volatile xdata *)0xfe00)
- #define CKDIV (*(unsigned char volatile xdata *)0xfe01)
- #define IRC24MCR (*(unsigned char volatile xdata *)0xfe02)
- #define XOSCCR (*(unsigned char volatile xdata *)0xfe03)
- #define IRC32KCR (*(unsigned char volatile xdata *)0xfe04)
- #define M 2000
- sfr ADC_CONTR = 0xbc;
- sfr ADC_RES = 0xbd;
- sfr ADC_RESL = 0xbe;
- sfr ADCCFG = 0xde;
- sfr P_SW2 = 0xba;
- sbit EADC = IE^5;
- sfr AUXR = 0x8e;
- sfr CMPCR1 = 0xe6;
- sfr CMPCR2 = 0xe7;
- sfr IE2 = 0xaf;
- sfr AUXINTIF = 0xef;
- sfr T4T3M = 0xd1;
- sfr TL3 = 0xd5;
- sfr TH3 = 0xd4;
- sfr IPH = 0xb7;
- sfr P1M0 = 0x92;
- sfr P1M1 = 0x91;
- sbit FreIn = P0^4;
- sbit P26 = P2^6;
- sbit P27 = P2^7;
- sbit CLK = P2^3;
- sbit DAT = P2^1;
- void display164(unsigned char udata)
- char i;
- for(i=0;i<8;i++)
- if(udata&0x80)
- DAT=1;
- CLK=0;
- udata = udata<<1;
- CLK=1;
- else
- DAT=0;
- CLK=0;
- udata = udata<<1;
- CLK=1;
- void DiviVol()
- P26 = 1;
- P27= 0;
- void NotDiviVol()
- P27 = 1;
- P26 = 0;
- void delay(int ms)
- int a,b;
- for(a=ms;a>0;a--)
- for(b=120;b>0;b--);
- unsigned int time = 0;
- unsigned int count = 0;
- unsigned long frequency = 0,temp=0,tempone = 0;
- unsigned char code Table[]={0xee,0x28,0xcd,0x6d,0x2b,0x67,0xe7,0x2c,0xef,0x6f};
- unsigned char code PotTable[]={0xfe,0x38,0xdd,0x7d,0x3b,0x77,0xf7,0x3c,0xff,0x7f};
- unsigned int H=0,L=0;
- unsigned char tempp[7]={0};
- unsigned int Vol = 0,RawVol = 0;
- bit flag = 0;
- unsigned int qf = 0;
- void SetOutXtal()
- P_SW2 = 0x80;
- XOSCCR = 0xc0; //啟動外部晶振
- while (!(XOSCCR & 1)); //等待時鐘穩(wěn)定
- CKDIV = 0x00; //時鐘不分頻
- CKSEL = 0x01; //選擇外部晶振
- P_SW2 = 0x00;
- void CMP_Ini()
- CMPCR1 = 0x86;
- CMPCR2 = 0x42;
- // CMPCR2 = 0x43;
- P_SW2 = 0x00;
- void T1_Ini()
- TMOD = 0x00;
- TH1 = 0x3c;
- TL1 = 0xb0;
- AUXR = 0x00;
- ET1 = 1;
- void T3_Ini()
- T4T3M = 0x04;
- TH3 = 0x00;
- TL3 = 0x00;
- IE2=0x20; //允許T3中斷
- void INT1_Ini()
- IT1 = 1;
- EX1 = 1;
- IP = 0x04;
- IPH = 0x04;
- void SysClkTest()
- display164(Table[0]); //七個數(shù)碼管都顯示0,則系統(tǒng)時鐘選擇正常
- void ADC_Ini()
- DiviVol(); //初始選擇分壓
- P1M0 = 0x00; //設(shè)置P1.0為ADC口
- P1M1 = 0x03; //P1.0和P1.1都設(shè)置為高阻輸入模式
- ADCCFG = 0x00; //設(shè)置ADC時鐘為系統(tǒng)時鐘/2/16/16
- ADC_CONTR = 0x80; //使能ADC模塊
- void main()
- int timev[M]={0};
- int i,imax,imaxp;
- imaxp=0;
- SetOutXtal();
- SysClkTest();
- INT1_Ini();
- CMP_Ini();
- T1_Ini();
- T3_Ini();
- ADC_Ini();
- EA = 1;
- while(1)
- if(flag==0)
- for(i=0;i<M;i++)
- ADC_CONTR |= 0x40; //啟動AD轉(zhuǎn)換
- _nop_();
- _nop_();
- delay(1);
- while (!(ADC_CONTR & 0x20)); //查詢ADC完成標(biāo)志
- ADC_CONTR &= ~0x20; //清完成標(biāo)志
- H=ADC_RES;
- L=ADC_RESL;
- RawVol=H*16+L/16;
- ADC_CONTR &= 0xa0;
- // Vol = RawVol*11;
- timev[i]=RawVol*11;
- delay(5);
- imax=timev[0];
- for(i=1;i<M;i++)
- if(timev[i]>imax)
- imax=timev[i];
- //imaxp=i;
- Vol=2*imax;
- // if(RawVol<33)
- // NotDiviVol();
- // delay(5);
- // ADC_CONTR = 0x81; //使能ADC模塊
- // delay(5);
- // ADC_CONTR |= 0x40; //啟動AD轉(zhuǎn)換
- // _nop_();
- // _nop_();
- // while (!(ADC_CONTR & 0x20)); //查詢ADC完成標(biāo)志
- // ADC_CONTR &= ~0x20; //清完成標(biāo)志
- // H=ADC_RES;
- // L=ADC_RESL;
- // RawVol=H*16+L/16;
- // Vol = RawVol/11;
- display164(Table[Vol/10%10]);
- display164(Table[Vol/100%10]);
- display164(PotTable[Vol/1000%10]);
- display164(Table[Vol/10000]);
- display164(0x00);
- display164(0x00);
- display164(0x00);
- display164(0x3e);
- DiviVol();
- delay(5);
- //imax=0;
- // ADC_CONTR = 0x80; //使能ADC模塊
- time = 0;
- delay(6000);
- if(flag==1)
- if(time==0)
- // while(FreIn==1);
- // while(FreIn==0);
- TR1=1;//打開T1、T3,開始測頻
- T4T3M |= 0x08;
- if(time==20)
- TR1 = 0;
- T4T3M &= 0xf7;
- temp = TH3*256+TL3+count*65536;
- tempone = temp+1;
- frequency = temp+(int)(tempone*0.0001);
- tempp[0] = frequency%10;
- tempp[1] = (frequency/10)%10;
- tempp[2] = (frequency/100)%10;
- tempp[3] = (frequency/1000)%10;
- tempp[4] = (frequency/10000)%10;
- tempp[5] = (frequency/100000)%10;
- tempp[6] = (frequency/1000000)%10;
- if((frequency/1000000)%10==0)
- tempp[6] = 10;
- if((frequency/100000)%10==0)
- tempp[5] = 10;
- if((frequency/10000)%10==0)
- tempp[4] = 10;
- if((frequency/1000)%10==0)
- tempp[3] = 10;
- if((frequency/100)%10==0)
- tempp[2] = 10;
- if((frequency/10)%10==0)
- tempp[1] = 10;
- if(frequency%10==0)
- tempp[0] = 10;
- display164(Table[tempp[0]]); //頻率送顯
- display164(Table[tempp[1]]);
- display164(Table[tempp[2]]);
- display164(Table[tempp[3]]);
- display164(Table[tempp[4]]);
- display164(Table[tempp[5]]);
- display164(Table[tempp[6]]);
- display164(0x71);
- time = 0;
- count = 0;
- TH3 = 0;
- TL3 = 0;
- TH1 = 0x3c;
- TL1 = 0xb0;
- void INT1_Ser() interrupt 2
- flag=!flag;
- void T1_Isr() interrupt 3
- time++;
- void T3_Isr() interrupt 19
- count++;
- AUXINTIF &= 0xfd; //清中斷標(biāo)志
- sfr P_SW2 = 0xba;
- sbit EADC = IE^5;
- sfr AUXR = 0x8e;
- sfr IE2 = 0xaf;
- sfr T4T3M = 0xd1;
- sfr TL3 = 0xd5;
- sfr TH3 = 0xd4;
- sfr IPH = 0xb7;
- sfr P1M0 = 0x92;
- sfr P1M1 = 0x91;
- sbit P26 = P2^6;
- sbit P27 = P2^7;
- sbit CLK = P2^3;
- sbit DAT = P2^1;
- char i;
- for(i=0;i<8;i++)
- if(udata&0x80)
- DAT=1;
- CLK=0;
- udata = udata<<1;
- CLK=1;
- else
- DAT=0;
- CLK=0;
- udata = udata<<1;
- CLK=1;
- void DiviVol()
- P26 = 1;
- P27= 0;
- void NotDiviVol()
- P27 = 1;
- P26 = 0;
- int a,b;
- for(a=ms;a>0;a--)
- //unsigned char code Table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
- //unsigned char code PotTable[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
- bit flag = 0;
- void SetOutXtal()
- P_SW2 = 0x80;
- P_SW2 = 0x00;
- void CMP_Ini()
- CMPCR1 = 0x86;
- CMPCR2 = 0x42;
- // CMPCR2 = 0x43;
- P_SW2 = 0x00;
- void T1_Ini()
- TMOD = 0x00;
- TH1 = 0x3c;
- TL1 = 0xb0;
- AUXR = 0x00;
- ET1 = 1;
- void T3_Ini()
- T4T3M = 0x04;
- TH3 = 0x00;
- TL3 = 0x00;
- void INT1_Ini()
- IT1 = 1;
- EX1 = 1;
- IP = 0x04;
- IPH = 0x04;
- void SysClkTest()
- void ADC_Ini()
- void main()
- SetOutXtal();
- SysClkTest();
- INT1_Ini();
- CMP_Ini();
- T1_Ini();
- T3_Ini();
- ADC_Ini();
- EA = 1;
- while(1)
- if(flag==0)
- _nop_();
- _nop_();
- delay(1);
- H=ADC_RES;
- L=ADC_RESL;
- RawVol=H*16+L/16;
- Vol = RawVol*11;
- // if(RawVol<33)
- // NotDiviVol();
- // delay(5);
- // delay(5);
- // _nop_();
- // _nop_();
- // H=ADC_RES;
- // L=ADC_RESL;
- display164(0x00);
- display164(0x00);
- display164(0x00);
- display164(0x3e);
- DiviVol();
- delay(5);
- time = 0;
- delay(3000);
- if(flag==1)
- if(time==0)
- T4T3M |= 0x08;
- if(time==20)
- TR1 = 0;
- T4T3M &= 0xf7;
- tempone = temp+1;
- tempp[6] = 10;
- tempp[5] = 10;
- tempp[4] = 10;
- tempp[3] = 10;
- tempp[2] = 10;
- tempp[1] = 10;
- tempp[0] = 10;
- display164(0x71);
- time = 0;
- count = 0;
- TH3 = 0;
- TL3 = 0;
- TH1 = 0x3c;
- TL1 = 0xb0;
- flag=!flag;
- time++;
- count++;
測頻率.rar
(37.85 KB, 下載次數(shù): 25)
2018-11-19 22:11 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
