查看: 4383|回復(fù): 1
基于51單片機(jī)的1602電子顯示屏proteus仿真+代碼
ID:431392 發(fā)表于 2018-11-22 19:33 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
基于51單片機(jī)的電子顯示屏仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar code table[]="I LOVE you!";
  5. uchar code table1[]="WWW.BAIDU.COM";
  6. sbit lcden=P3^4;        //液晶使能端
  7. sbit lcdrs=P3^5;        //液晶數(shù)據(jù)命令選擇端
  8. sbit dula=P2^6;                //申明U1鎖存器的鎖存端
  9. sbit wela=P2^7;                //申明U2鎖存器的鎖存端
  10. uchar num;
  11. unsigned char a=0x00;
  12. void delay(uint z)
  13. {
  14.         uint x,y;
  15.         for(x=z;x>0;x--)
  16.                 for(y=110;y>0;y--);
  17. }
  18. void write_com(uchar com)
  19. {
  20.         lcdrs=0;
  21.         P0=com;
  22.         delay(5);
  23.         lcden=1;
  24.         delay(5);
  25.         lcden=0;
  26. }
  27. void write_data(uchar date)
  28. {
  29.         lcdrs=1;
  30.         P0=date;
  31.         delay(5);
  32.         lcden=1;
  33.         delay(5);
  34.         lcden=0;
  35. }
  36. void init()
  37. {
  38.         dula=0;
  39.         wela=0;
  40.         lcden=0;
  41.         write_com(0x38);//設(shè)置16X2顯示,5X7點(diǎn)陣,8位數(shù)據(jù)接口
  42.         write_com(0x0c);//設(shè)置開(kāi)顯示,不顯示光標(biāo)
  43.         write_com(0x06);//寫(xiě)一個(gè)字符后地址指針加1
  44.         write_com(0x01);//顯示清零,數(shù)據(jù)指針清零
  45.     TMOD = 0x20;
  46.     SCON = 0x50;
  47.     TH1 = 0xFD;
  48.     TL1 = TH1;
  49.     PCON = 0x00;
  50.     EA = 1;
  51.     ES = 1;
  52.     TR1 = 1;
  53. }
  54. void SendOneByte(unsigned char c)
  55. {
  56.     SBUF = c;
  57.     while(!TI);
  58.     TI = 0;
  59. }
  60. void main()
  61. {
  62.         init();
  63.         write_com(0x80);
  64.         for(num=0;num<11;num++)
  65.         {
  66.                 write_data(table[num]);
  67.                 delay(5);
  68.         }
  69.         write_com(0x80+0x40);
  70.         for(num=0;num<13;num++)
  71.         {
  72.                 write_data(table1[num]);
  73.                 delay(5);
  74.         }
  75.          write_com(0x80);
  76.         while(1)
  77.         {
  78.         }
  79. }
  80.     ser()interrupt 4
  81. {
  82.      RI=0;
  83.          write_com(0x01);
  84.          a=SBUF;
  85.          write_data('I');
  86.           write_data('g');
  87.           write_data('e');
  88.            write_data('t');
  89.             write_data(' ');
  90.              write_data(a);
  91. }
顯示屏.rar (15.63 KB, 下載次數(shù): 55)
ID:568302 發(fā)表于 2019-6-26 16:49 | 只看該作者
數(shù)字亂序
