查看: 3306|回復(fù): 0
藍(lán)牙+電機(jī)的Arduino源碼分享
ID:424598 發(fā)表于 2018-11-22 21:04 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/*注意事項(xiàng):(在燒寫的過程中,請(qǐng)先斷開藍(lán)牙模塊和Nano板的連接,否則會(huì)燒不進(jìn)程序。)
1.寫代碼到Arduino板上時(shí),數(shù)字0和1口不能接線,必需撥掉(不要帶電撥線,容易燒)
2.藍(lán)牙的TX口接Arduino板上的0口,RX口接Arduino板上的1口
const byte B1A = 6; //B-1A
const byte B1B = 9; //B-1B
const byte A1A = 10; //A-1A
const byte A1B = 11; //A-1B
void setup() {
  Serial.begin(9600);  //串口波特率(使用藍(lán)牙串口必需此句)
  pinMode(B1A,OUTPUT); //設(shè)置數(shù)字口為輸出口
  pinMode(B1B,OUTPUT);
  pinMode(A1A,OUTPUT);
  pinMode(A1B,OUTPUT);
void loop() {
  while(Serial.available()) {  //判斷緩沖器狀態(tài)。
        char c=Serial.read();    //讀取串口
        switch (c) {
        case 'A':
                goUp(80); //前進(jìn)
                break;
        case 'B':
                goLeft(200); //左轉(zhuǎn)
                break;
        case 'C':
                goRight(200); //右轉(zhuǎn)
                break;
        case 'D':
                goBack(80); //后退
                break;
        case 'E':
                goStop(); //停止
                break;
void goUp(int up_speed) { //前進(jìn)
  analogWrite(B1A,255);
  analogWrite(A1B,255);
  analogWrite(B1B,up_speed);
  analogWrite(A1A,up_speed);
  Serial.println("goUp"); //輸出到串口
void goLeft(int left_speed) { //左轉(zhuǎn)
  analogWrite(B1A,0); //向數(shù)字口發(fā)送值(以下都是)
  analogWrite(A1A,0);
  analogWrite(B1B,left_speed);
  analogWrite(A1B,left_speed);
  Serial.println("goLeft");
void goRight(int right_speed) { //右轉(zhuǎn)
  analogWrite(B1B,0);
  analogWrite(A1B,0);
  analogWrite(B1A,right_speed);
  analogWrite(A1A,right_speed);
  Serial.println("goRight");
void goBack(int back_speed) { //后退
  analogWrite(B1B,255);
  analogWrite(A1A,255);
  analogWrite(B1A,back_speed);
  analogWrite(A1B,back_speed);
  Serial.println("goBack");
void goStop() { //停止
  analogWrite(B1A,0);
  analogWrite(B1B,0);
  analogWrite(A1A,0);
  analogWrite(A1B,0);
  Serial.println("goStop");
