/***************COPYRIGHT2011***************************
*File Name :ch450.c
*Author :gaochs
*Description :stm32控制ch450
stm32IO口分配:
SDA = PB11 SCL = PB10 INT = PE0
微調(diào)旋鈕(INT2_L = PB8 INT3_R = PB9)
蜂鳴器 = PE1
*Vision :V1.0.0
*Last Modify:
*Modification History
#include "stm32f4xx.h"
#include "CH450.h"
Variable Name :CH450_xxx
Dscription :define CH450 IO
#define CH450_SDA_SET GPIO_SetBits(GPIOE, GPIO_Pin_5) //SDA置高
#define CH450_SDA_CLR GPIO_ResetBits(GPIOE, GPIO_Pin_5) //SDA置低
#define CH450_SCL_SET GPIO_SetBits(GPIOE, GPIO_Pin_6) //SCL置高
#define CH450_SCL_CLR GPIO_ResetBits(GPIOE, GPIO_Pin_6) //SCL置低
#define CH450_RD_SDA GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_5)
#define DELAY mDelayuS(1000)
#define CH450_I2C_ADDR0 0x40 // CH450的ADDR=0時(shí)的地址
#define CH450_I2C_MASK 0x3E // CH450的2線接口高字節(jié)命令掩碼
#define CH450_GET_KEY 0x0700 // 獲取按鍵,返回按鍵代碼
// 類型定義
// CH450的全局變量End
void CH450_SDA_IN()
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOE, &GPIO_InitStructure);
void CH450_SDA_OUT()
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
void CH450_SCL_OUT()
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
*Function Name :mDelayuS
*Description :0.04us
*Input :n 延時(shí)時(shí)間
*Output :None
*Return :None
void mDelayuS(u16 n)
while( --n )
*Function Name :mDelaymS
*Description :43us
*Input :delay 延時(shí)時(shí)間
*Output :None
*Return :None
void mDelaymS(u16 delay)
u16 ms;
u16 sm;
u16 c;
for(ms = delay; ms != 0; ms--)
for (sm = 200; sm != 0; sm--) c += 3;
for (sm = 240; sm != 0; sm--) c += 3;
for (ms = delay; ms != 0; ms--)
*Function Name :CH450_I2c_Start
*Description :I2C START
*Input :None
*Output :None
*Return :None
void CH450_I2c_Start( void )
CH450_SDA_OUT(); /* 設(shè)置SDA為輸出方向 */
DELAY;
CH450_SDA_SET; /*發(fā)送起始條件的數(shù)據(jù)信號(hào)*/
DELAY;
CH450_SCL_SET;
DELAY;
CH450_SDA_CLR; /*發(fā)送起始信號(hào)*/
DELAY;
CH450_SCL_CLR; /*鉗住I2C總線,準(zhǔn)備發(fā)送或接收數(shù)據(jù) */
DELAY;
*Function Name :CH450_I2c_Stop
*Description :I2C STOP
*Input :None
*Output :None
*Return :None
void CH450_I2c_Stop( void )
DELAY;
CH450_SDA_CLR;
DELAY;
CH450_SCL_SET;
DELAY;
CH450_SDA_SET; /*發(fā)送I2C總線結(jié)束信號(hào)*/
DELAY;
*Function Name :CH450_I2c_WrByte
*Description :I2C 寫一個(gè)字節(jié)
*Input :c 待寫字節(jié)數(shù)據(jù)
*Output :None
*Return :None
void CH450_I2c_WrByte(u8 c) //寫一個(gè)字節(jié)數(shù)據(jù)
u8 i;
DELAY;
for (i = 0; i != 8; i++)
if (c & 0x80)
CH450_SDA_SET;
CH450_SDA_CLR;
DELAY;
CH450_SCL_SET;
c <<= 1;
DELAY;
CH450_SCL_CLR;
DELAY;
CH450_SDA_IN(); /* 設(shè)置SDA為輸入方向 */
DELAY;
CH450_SCL_SET; //接收應(yīng)答
DELAY;
CH450_SCL_CLR;
DELAY;
void CH450_I2C_SendACK()
CH450_SDA_OUT();
CH450_SCL_CLR;
DELAY;
CH450_SDA_SET;
DELAY;
CH450_SCL_SET;
DELAY;
CH450_SCL_CLR;
DELAY;
CH450_SDA_CLR;
u8 CH450_I2C_ReceACK()
CH450_SDA_IN();
CH450_SCL_CLR;
DELAY;
CH450_SCL_SET;
DELAY;
if (CH450_RD_SDA)
CH450_SCL_CLR;
DELAY;
//CH450_PORT &= ~SDA;
return 1;
CH450_SCL_CLR;
DELAY;
return 0;
*Function Name :CH450_I2c_RdByte
*Description :I2C 讀一個(gè)字節(jié)
*Input :None
*Output :None
*Return :dat
u8 CH450_I2c_RdByte(void) //讀一個(gè)字節(jié)數(shù)據(jù)
u8 dat,i;
u16 j;
CH450_SDA_OUT(); //CPU釋放SDA引腳
DELAY;
CH450_SDA_SET;
DELAY;
DELAY;
dat = 0;
for (i = 0; i != 8; i++) // 輸入8位數(shù)據(jù)
CH450_SCL_SET;
DELAY;
dat <<= 1;
j = CH450_RD_SDA;
if (j)
dat++;
} // 輸入1位
DELAY;
CH450_SCL_CLR;
DELAY;
CH450_SDA_OUT();
DELAY;
CH450_SDA_SET;
DELAY;
CH450_SCL_SET;
DELAY;
CH450_SCL_CLR;
DELAY;
return(dat);
*Function Name :CH450_Write
*Description :CH450寫命令
*Input :command 寫命令
*Output :None
*Return :None
void CH450_Write(u16 command) //寫命令
CH450_I2c_Start(); /*啟動(dòng)總線*/
CH450_I2c_WrByte((u8)(command >> 7) & CH450_I2C_MASK | CH450_I2C_ADDR0); // CH450的ADDR=0時(shí)
CH450_I2c_WrByte((u8)command); /*發(fā)送數(shù)據(jù)*/
CH450_I2c_Stop(); /*結(jié)束總線*/
*Function Name :CH450_Read
*Description :CH450讀命令
*Input :None
*Output :None
*Return :val
u8 CH450_Read( void)
u8 val;
CH450_I2c_Start();/*啟動(dòng)總線*/
DELAY;
// CH450_I2c_WrByte((u8)(CH450_GET_KEY>>7)&CH450_I2C_MASK|CH450_I2C_ADDR0|0x01); // 若有兩個(gè)CH450并連,當(dāng)ADDR=0時(shí),需修改為CH450_I2C_ADDR0
CH450_I2c_WrByte(0x4F);//讀取按鍵代碼輸出字節(jié)1
DELAY;
val = CH450_I2c_RdByte(); /*讀取數(shù)據(jù)*/
DELAY;
return val;
*Function Name :CH450_Init
*Description :CH450的初始化函數(shù)
*Input :None
*Output :None
*Return :None
void CH450_Init( void )
/* Enable GPIOG's AHB interface clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
CH450_SCL_OUT();
DELAY;
CH450_Write(0x0403);//開顯示鍵盤
DELAY;
#ifndef _CH450_H_
#define _CH450_H_
*Description :
*Output :None
*Return :None
void mDelayuS(u16 n);
*Description :
*Output :None
*Return :None
void mDelaymS(u16 delay);
*Input :None
*Output :None
*Return :None
void CH450_I2c_Start( void );
*Input :None
*Output :None
*Return :None
void CH450_I2c_Stop( void );
*Output :None
*Return :None
void CH450_I2c_WrByte(u8 c);
*Input :None
*Output :None
*Return :dat
u8 CH450_I2c_RdByte( void );
*Input :command 寫命令
*Output :None
*Return :None
void CH450_Write(u16 command);
*Input :None
*Output :None
*Return :val
u8 CH450_Read( void);
*Input :None
*Output :None
*Return :None
void CH450_Init( void );
#endif
