查看: 3357|回復: 0
ATMEGA16A英文datasheet AVR單片機資料下載
ID:383785 發(fā)表于 2018-11-24 16:55 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
The ATmega16A is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC
architecture. By executing powerful instructions in a single clock cycle, the ATmega16A
achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize
power consumption versus processing speed.
完整的pdf格式文檔51黑下載地址:
ATMEGA16A.pdf (7.21 MB, 下載次數: 27)
Powered by 單片機教程網
