查看: 4316|回復(fù): 2
單片機(jī)實(shí)現(xiàn)唱歌
ID:34415 發(fā)表于 2012-4-12 17:33 | 顯示全部樓層 |閱讀模式
用單片機(jī)怎么實(shí)現(xiàn)唱歌
ID:35775 發(fā)表于 2012-4-12 17:50 | 顯示全部樓層
#include<reg52.h>
#include<intrins.h> //11111
sbit P32=P2^0;
sbit kg=P3^3;
uchar i,j,time1,time2;
uchar temp; //11111
uint code array1[]={400,400,650,650,650,1200,
     400,400,650,650,650,650,1200,
uchar code array[]={0xfd,0x79,0xfd,0x79,0xfd,0xc7,0xfd,0x79,0xfe,0x21,0xfe,0x05,
        0xfd,0x79,0xfd,0x79,0xfd,0xc7,0xfd,0x79,0xfe,0x51,0xfe,0x21,
     0xfd,0x79,0xfd,0x79,0xfe,0xc0,0xfe,0x84,0xfe,0x21,0xfe,0x05,0xfd,0xc7,
     0xfe,0x99,0xfe,0x99,0xfe,0x90,0xfe,0x21,0xfe,0x51,0xfe,0x21
void delay(uint m)
    uint n;
 for(m;m>0;m--)
  for(n=125;n>0;n--);
    kg=1;
 TMOD=0x01;
 TH0=0;
 TL0=0;
 EA=1;
 ET0=1;
 TR0=1;
  temp=0xfe; // 11111
      P1=temp; // 11111
  temp=_crol_(temp,1);// 111
  P1=temp;  // 1111
  if(kg==0)
     delay(19);
     if(kg==0)
        P1=0;
     time1=array[i++];
        time2=array[i++];
        if(i==50)
          i=0;
        delay(array1[j++]);
        if(j==25)
     j=0;
     while(!kg);
void init() interrupt 1
 TR0=0;
 P32=~P32;
 TH0=time1;
 TL0=time2;
 TR0=1;
不知道是不是你想要的哦
