帶鬧鐘的萬年歷程序測試無誤,希望能幫到大家
- #include "12864.h"
- #include "DS1302.h"
- #include "KEY.h"
- #include "DS18B20.h"
- #include<intrins.h>
- sfr CLK_DIV=0x97;
- uchar clock_page=0; //鬧鐘
- //uchar flag=0;
- uchar keynum;
- char yearH=20,year,month,date,day,hour=0,min=0,sec=0; //時(shí)間變量
- //char cursor_xy=0; //光標(biāo)位置
- uchar page=0; //page菜單頁面
- code char* Weekday[8]={" ","一","二","三","四","五","六","日"};
- code uchar cursor[6][2]={{0,16},{4,16},{0,32},{4,32},{0,48},{4,48}}; //光標(biāo)位置
- extern code uchar DS1302_Addr[7];
- uchar M_num=59,S_num=59;
- uchar counter=1; //定時(shí)器計(jì)數(shù)
- struct TIME
- char x;
- char y;
- char num;
- char max;
- char min;
- struct TIME Time[10]=
- {1,2,0,99,0}, //年
- {3,2,0,12,1}, //月
- {5,2,0,31,1}, //日
- {1,3,0,23,0}, //時(shí)
- {2,3,0,59,0}, //分
- {4,3,0,59,0}, //秒
- {4,4,0,7,1}, //星期
- {1,2,0,23,0}, //鬧鐘小時(shí)
- {3,2,0,59,0}, //鬧鐘分鐘
- {3,3,0,1,0} //鬧鐘標(biāo)志
- uchar Clock_num_hour[3]={0,0,0}; //三個(gè)鬧鐘小時(shí)
- uchar Clock_num_min[3]={0,0,0}; //三個(gè)鬧鐘分鐘
- uchar Clock_flag[3]={0,0,0}; //三個(gè)鬧鐘使能標(biāo)志
- void Timer(void)
- uint temp; //溫度
- while(DS18B20_Init()) //DS18B20初始化
- LCD12864_datas(3,2,"未插入");
- LCD12864_datas(2,3,"溫度模塊");
- LCD12864_WriteCom(0x01); //12864清屏(DDRAM)
- LCD12864_datas(2,1,"年");
- LCD12864_datas(4,1,"月");
- LCD12864_datas(6,1,"日");
- LCD12864_datas(2,4,"星期");
- while(1)
- if(Clock_flag[0]==1||Clock_flag[1]==1||Clock_flag[2]==1) LCD12864_DrawPic1616(0,48,0);
- else LCD12864_DrawPic1616(0,48,1); //鬧鐘標(biāo)志
- hour=DS1302_ReadData(HOUR);
- min=DS1302_ReadData(MIN);
- sec=DS1302_ReadData(SEC); //讀取時(shí)間
- LCD12864_Num3216(0,16,hour>>4);
- LCD12864_Num3216(1,16,hour&0x0f); //小時(shí)
- LCD12864_Num3216(2,16,10); //冒號(hào)
- LCD12864_Num3216(3,16,min>>4);
- LCD12864_Num3216(4,16,min&0x0f); //分鐘
- LCD12864_Num3216(5,16,10); //冒號(hào)
- LCD12864_Num3216(6,16,sec>>4);
- LCD12864_Num3216(7,16,sec&0x0f); //秒針
- year=DS1302_ReadData(YEAR);
- month=DS1302_ReadData(MONTH);
- date=DS1302_ReadData(DATE); //讀取年月日
- LCD12864_SetXY(0,1);
- LCD12864_WriteData(yearH/10+'0');
- LCD12864_WriteData(yearH%10+'0');
- LCD12864_WriteData('0'+(year>>4));
- LCD12864_WriteData('0'+(year&0x0f)); //年份
- LCD12864_SetXY(3,1);
- LCD12864_WriteData('0'+(month>>4));
- LCD12864_WriteData('0'+(month&0x0f)); //月份
- LCD12864_SetXY(5,1);
- LCD12864_WriteData('0'+(date>>4));
- LCD12864_WriteData('0'+(date&0x0f)); //日期
- LCD12864_datas(4,4,Weekday[DS1302_ReadData(DAY)]); //星期
- temp=DS18B20_ReadTemp(); //讀取溫度值
- LCD12864_SetXY(6,4);
- LCD12864_WriteData('0'+(temp%10000/1000));
- LCD12864_WriteData('0'+(temp%1000/100));
- // LCD12864_WriteData('C');
- LCD12864_DrawPic1616(7,48,2); //溫度符號(hào)
- keynum=Key_Scan();
- if(keynum==13) {page=4;break;} //當(dāng)按鍵按下鍵值為13時(shí),打開菜單
- LCD12864_Delay1ms(500);
- void Cursor(uchar n)
- switch(n)
- case 0:LCD12864_Reverse(1, 0,0);LCD12864_Reverse(2, 0,0);LCD12864_Reverse(3, 0,0);LCD12864_Reverse(4, 0,0);LCD12864_Reverse(5, 0,0);break;
- case 1:LCD12864_Reverse(1,16,0);LCD12864_Reverse(2,16,0);LCD12864_Reverse(3,16,0);LCD12864_Reverse(4,16,0);LCD12864_Reverse(5,16,0);break;
- case 2:LCD12864_Reverse(1,32,0);LCD12864_Reverse(2,32,0);LCD12864_Reverse(3,32,0);LCD12864_Reverse(4,32,0);LCD12864_Reverse(5,32,0);break;
- case 3:LCD12864_Reverse(1,48,0);LCD12864_Reverse(2,48,0);LCD12864_Reverse(3,48,0);LCD12864_Reverse(4,48,0);LCD12864_Reverse(5,48,0);break;
- default:break;
- void meun(void) //菜單界面
- char n=0,late=7;
- LCD12864_datas(0,1," 1.電子時(shí)鐘");
- LCD12864_datas(0,2," 2.調(diào)整時(shí)間");
- LCD12864_datas(0,3," 3.設(shè)置鬧鐘");
- LCD12864_datas(0,4," 4.倒計(jì)時(shí)器");
- Cursor(0); //初始光標(biāo)位置
- while(1)
- late=n;
- if(keynum==13) {page=n;break;} //確認(rèn)鍵
- else if(keynum>=1&&keynum<=4) n=keynum-1;
- else if(keynum==14) n++;
- else if(keynum==15) n--;
- if(n>3)n=0;if(n<0)n=3;
- if(n!=late)
- Cursor(n);
- Cursor(late);
- void Time_Cursor(char n)
- switch(n) //選光標(biāo)
- case 0:LCD12864_Reverse(0,16,0);LCD12864_Reverse(1,16,0);break;
- case 1:LCD12864_Reverse(3,16,0);break;
- case 2:LCD12864_Reverse(5,16,0);break;
- case 3:LCD12864_Reverse(1,32,0);break;
- case 4:LCD12864_Reverse(2,32,1);LCD12864_Reverse(3,32,2);break;
- case 5:LCD12864_Reverse(4,32,0);break;
- case 6:LCD12864_Reverse(4,48,0);break;
- case 7:break;
- void Adjust_time(void)
- char n=0,late=7;
- LCD12864_datas(0,1,"----時(shí)間設(shè)置----");
- LCD12864_datas(2,2,"年");
- LCD12864_datas(4,2,"月");
- LCD12864_datas(6,2,"日");
- day=DS1302_ReadData(DAY);
- LCD12864_SetXY(0,2);
- LCD12864_SetXY(3,2);
- LCD12864_SetXY(5,2);
- LCD12864_SetXY(1,3);
- LCD12864_WriteData((hour>>4)+'0');
- LCD12864_WriteData((hour&0x0f)+'0'); //小時(shí)
- LCD12864_WriteData(':'); //冒號(hào)
- LCD12864_WriteData((min>>4)+'0');
- LCD12864_WriteData((min&0x0f)+'0'); //分鐘
- LCD12864_WriteData((sec>>4)+'0');
- LCD12864_WriteData((sec&0x0f)+'0'); //秒針
- LCD12864_datas(4,4,Weekday[day]); //星期
- Time[0].num=(year>>4)*10+(year&0x0f);
- Time[1].num=(month>>4)*10+(month&0x0f);
- Time[2].num=(date>>4)*10+(date&0x0f);
- Time[3].num=(hour>>4)*10+(hour&0x0f);
- Time[4].num=(min>>4)*10+(min&0x0f);
- Time[5].num=(sec>>4)*10+(sec&0x0f);
- Time[6].num=day; //將BCD碼轉(zhuǎn)換為十進(jìn)制數(shù)
- Time_Cursor(0); //初始光標(biāo)位置
- while(1)
- LCD12864_datas(7,4,"00");
- late=n;
- if(keynum==13)
- LCD12864_datas(7,4,"01");
- while(1)
- if(keynum==14) Time[n].num++;
- if(keynum==15) Time[n].num--;
- if(Time[n].num>Time[n].max)Time[n].num=Time[n].min;
- if(Time[n].num<Time[n].min)Time[n].num=Time[n].max;
- if(n==6)
- LCD12864_datas(4,4,Weekday[Time[n].num]); //星期
- else
- LCD12864_SetXY(Time[n].x,Time[n].y);
- if(n==4) LCD12864_WriteData(':'); //冒號(hào)
- LCD12864_WriteData('0'+(Time[n].num/10));
- LCD12864_WriteData('0'+(Time[n].num%10));
- if(keynum==13)
- DS1302_WriteDat(0x8e,0x00); //關(guān)閉寫保護(hù)
- DS1302_WriteDat(DS1302_Addr[n],((Time[n].num/10)<<4)+(Time[n].num%10));
- DS1302_WriteDat(0x8e,0x80); //開啟寫保護(hù)
- break;
- if(keynum==16) break;
- if(keynum==14) n++;
- if(keynum==15) n--;
- if(n>6)n=0;if(n<0)n=6;
- if(n!=late)
- Time_Cursor(n);
- Time_Cursor(late);
- if(keynum==16)
- page=4;
- break;
- void Clock_Cursor(char n)
- case 0:LCD12864_Reverse(1,16,0);break;
- case 2:LCD12864_Reverse(3,32,0);break;
- case 3:break;
- void Clock(uchar k)
- char n=0,late=3;
- Time[7].num=Clock_num_hour[k]; //小時(shí)
- Time[8].num=Clock_num_min[k]; //分鐘
- Time[9].num=Clock_flag[k]; //標(biāo)志
- LCD12864_datas(0,1,"----鬧鐘設(shè)置----");
- LCD12864_SetXY(2,2);
- LCD12864_SetXY(1,2);
- LCD12864_WriteData((Time[7].num>>4)+'0');
- LCD12864_WriteData((Time[7].num&0x0f)+'0'); //小時(shí)
- LCD12864_WriteData((Time[8].num>>4)+'0');
- LCD12864_WriteData((Time[8].num&0x0f)+'0'); //分鐘
- LCD12864_datas(0,3,"鬧鐘:");
- if(Time[9].num==0) LCD12864_datas(3,3,"關(guān)");
- else LCD12864_datas(3,3,"開");
- Time[7].num=(Time[7].num>>4)*10+(Time[7].num&0x0f);
- Time[8].num=(Time[8].num>>4)*10+(Time[8].num&0x0f);
- Time[9].num=(Time[9].num>>4)*10+(Time[9].num&0x0f);
- Clock_Cursor(0); //初始光標(biāo)位置
- while(1)
- late=n;
- if(keynum==13)
- n=n+7;
- while(1)
- LCD12864_WriteData((Time[7].num/10)+'0');
- LCD12864_WriteData((Time[7].num%10)+'0'); //小時(shí)
- LCD12864_WriteData((Time[8].num/10)+'0');
- LCD12864_WriteData((Time[8].num%10)+'0'); //分鐘
- if(keynum==13)
- break;
- if(keynum==16)
- break;
- n=n-7;
- if(n>2)n=0;if(n<0)n=2;
- if(n!=late)
- Clock_Cursor(n);
- Clock_Cursor(late);
- if(keynum==16)
- page=2; //返回菜單
- Time[7].num=((Time[7].num/10)<<4)+(Time[7].num%10);
- Time[8].num=((Time[8].num/10)<<4)+(Time[8].num%10);
- Time[9].num=((Time[9].num/10)<<4)+(Time[9].num%10);
- Clock_num_hour[k]=Time[7].num; //小時(shí)
- Clock_num_min[k]=Time[8].num; //分鐘
- Clock_flag[k]=Time[9].num; //標(biāo)志
- if(Clock_flag[k]!=0)
- TMOD|=0x01;
- EA=1;
- ET0=1;
- TH0=0x3c;
- TL0=0xb0; //定時(shí)50ms
- TR0=1;
- break;
- void Select_Clock_Cursor(uchar n)
- switch(n)
- case 0:LCD12864_Reverse(2,16,0);LCD12864_Reverse(3,16,0);LCD12864_Reverse(4,16,0);LCD12864_Reverse(5,16,0);break;
- case 1:LCD12864_Reverse(2,32,0);LCD12864_Reverse(3,32,0);LCD12864_Reverse(4,32,0);LCD12864_Reverse(5,32,0);break;
- case 2:LCD12864_Reverse(2,48,0);LCD12864_Reverse(3,48,0);LCD12864_Reverse(4,48,0);LCD12864_Reverse(5,48,0);break;
- default:break;
- void Select_Clock(void)
- char n=0,late=4;
- LCD12864_datas(0,1,"----鬧鐘選擇----");
- LCD12864_datas(0,2," 1.鬧鐘01");
- LCD12864_datas(0,3," 2.鬧鐘02");
- LCD12864_datas(0,4," 3.鬧鐘03");
- Select_Clock_Cursor(0); //初始光標(biāo)位置
- while(1)
- late=n;
- if(keynum==13) {clock_page=n;page=5;break;} //確認(rèn)鍵
- else if(keynum==16) {page=4; break;}
- if(n!=late)
- Select_Clock_Cursor(n);
- Select_Clock_Cursor(late);
- void Countdown(void)
- LCD12864_datas(0,1,"----倒計(jì)時(shí)器----");
- while(1)
- LCD12864_SetXY(3,3);
- LCD12864_WriteData((M_num/10)+'0');
- LCD12864_WriteData((M_num%10)+'0'); //分鐘
- LCD12864_WriteData((S_num/10)+'0');
- LCD12864_WriteData((S_num%10)+'0'); //分鐘
- if(keynum==13)
- TMOD|=0x10;
- EA=1;
- ET1=1;
- TH1=0x3c;
- TL1=0xb0; //定時(shí)50ms
- TR1=1;
- else if(keynum==2) M_num--; //減低分鐘
- else if(keynum==3) S_num--; //減低秒針
- else if(keynum==14) //重置計(jì)數(shù)值
- S_num=59;
- M_num=59;
- else if(keynum==15) //停止計(jì)時(shí)
- TR1=0;
- else if(keynum==16) {page=4; break;} //退出到菜單頁
- if(S_num==0) //判斷時(shí)間越界
- S_num=59;
- M_num--;
- if(M_num==0&&S_num==0)
- while(1)
- Beep_key();
- Delay10ms(5);
- if(Key_Scan()!=0)
- TR1=0;
- S_num=59;
- M_num=59;
- break;
- void time_2(void) interrupt 3
- TH1=0x3c;
- counter++;
- if(counter==20)
- counter=0;
- S_num--;
- void main(void)
- CLK_DIV=0x03; //八分頻
- LCD12864_Init(); //12864初始化
- LCD12864_CleanScreen(); //12864清屏
- DS1302_Init(); //DS1302初始化
- while(1)
- LCD12864_CleanScreen(); //12864清屏(CGRAM)
- if(page==0) Timer(); //page=0時(shí),數(shù)字鐘界面
- else if(page==1) Adjust_time(); //page=1時(shí),調(diào)整時(shí)間界面
- else if(page==2) Select_Clock(); //page=2時(shí),系統(tǒng)設(shè)置界面
- else if(page==3) Countdown(); //page=3時(shí),倒計(jì)時(shí)器頁面
- else if(page==4) meun(); //page=4時(shí),菜單頁面
- else if(page==5) Clock(clock_page); //page=4時(shí),菜單頁面
- void time_1(void) interrupt 1
- uchar i,H,M;
- H=DS1302_ReadData(HOUR);
- M=DS1302_ReadData(MIN);
- TH0=0x3c;
- for(i=0;i<3;i++)
- if(Clock_flag[i]==1)
- while(H==Clock_num_hour[i]&&M==Clock_num_min[i])
- Clock_flag[i]=0;
- Beep_key();
- Delay10ms(5);
- if(Key_Scan()!=0) break;
- if(Clock_flag[0]==0&&Clock_flag[1]==0&&Clock_flag[2]==0)
- TR0=0;
- // Time[9].num=0;
- // Clock_flag[0]=1;
- // Clock_flag[1]=1;
- // Clock_flag[2]=1;
帶鬧鐘萬年歷程序.zip
(117.86 KB, 下載次數(shù): 36)
2018-11-28 23:11 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
