查看: 5156|回復(fù): 2
按鍵控制單片機(jī)的暫停與繼續(xù)
ID:401370 發(fā)表于 2018-11-29 20:18 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
兩個(gè)按鍵 一個(gè)按鍵按下時(shí)開(kāi)始倒計(jì)時(shí)  另一個(gè)按鍵是按下一次時(shí)倒計(jì)時(shí)暫停 再按一次倒計(jì)時(shí)還是從暫停的數(shù)開(kāi)始倒計(jì)時(shí)
求指教 再按一次那一部分 程序怎么修改??就在我的這個(gè)程序上修改的話(huà)。。求指教 各位大佬。。
#include<reg51.h>
uint i;
uchar flag1,flag2;
sbit key_1 = P1^0;
sbit key_2 = P1^1;
uchar code aa[]={  0x3F,  //"0"
                   0x06,  //"1"
                   0x5B,  //"2"
                   0x4F,  //"3"
                   0x66,  //"4"
                   0x6D,  //"5"
                   0x7D,  //"6"
                   0x07,  //"7"
                   0x7F,  //"8"
                   0x6F   //"9"
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void show(uchar n)
        P2 = aa[n%10];
        P3 =0x01;
        delay(20);
        P3 = 0xFF;
        P2 = aa[n/10];
        P3 =0x02;
        delay(20);
        P3 = 0xFF;
void key()
  if(!key_1)
    delay(10);
                if(!key_1)
       flag1 = 1;
         if(!key_2)
    delay(10);
                if(!key_2)
       flag2 = 1;
                 key();
                 if(flag1 == 1)
       for(i=60;i>0;i--)
                          delay(75);
        show(i);
       key();
                         if(flag2 == 1)
          flag1 = 0;
                                        break;
                  if(flag2 == 1)
                                        show(i);
                                        key();
                            if(flag1 == 1)
            flag2 = 0;
                                          break;
仿真圖
仿真圖
ID:164602 發(fā)表于 2018-11-30 09:15 | 只看該作者
倒計(jì)時(shí)嘛,有什么難的?次业模/*
使用定時(shí)器中斷進(jìn)行的倒計(jì)時(shí)程序。
#include <STC89C5xRC.H>
#include <intrins.h>
#define SMG P0//數(shù)碼管接口
sbit K1=P3^4;//獨(dú)立按鍵接口
sbit K2=P3^5;
sbit K3=P3^6;
sbit K4=P3^7;
sbit DUAN=P2^6;//數(shù)碼管顯示段碼的鎖存
sbit WEI=P2^7;//選擇數(shù)碼管位的鎖存
sbit FMQ=P2^3;//蜂鳴器
unsigned char ZF[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,
                                        0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
unsigned char Wei[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char PLAY[8]={0,0,0,0,0,0,0,0};
unsigned char n=0,TT=0;
void Delay1ms()
        unsigned char i, j;
        _nop_();
        i = 2;
        j = 199;
        do
                while (--j);
        } while (--i);
void Delay10ms()
        unsigned char i, j;
        i = 18;
        j = 235;
        do
                while (--j);
        } while (--i);
void Delay100ms()
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 5;
        j = 52;
        k = 195;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void Timer0Init(void)                //50毫秒@11.0592MHz,定時(shí)器設(shè)置
        AUXR &= 0x7F;
        TMOD &= 0xF0;
        TMOD |= 0x01;
        TL0 = 0x00;
        TH0 = 0x4C;
    EA = 1;
    ET0 = 1;
        TF0 = 0;
        TR0 = 0;
void XS(void)//顯示子函數(shù)
        unsigned char i;
        for (i=0;i<8;i++)
                SMG=Wei;
                WEI=1;
                WEI=0;
                SMG=PLAY;
                DUAN=1;
                DUAN=0;
                Delay1ms();
                SMG=0x00;
                DUAN=1;
                DUAN=0;
void DISPLAY(void)
        PLAY[5]=ZF[n/100];
        PLAY[6]=ZF[(n%100)/10];
        PLAY[7]=ZF[(n%10)/1];
void main(void)
        unsigned char m;
        bit KS=0;
        Timer0Init();
                if (K1==0)
                        Delay10ms();
                        if (K1==0)
                                n=n+1;
                        for(m=0;((m<50)&&(K1==0));m++)
                                Delay10ms();
                if (K2==0)
                        Delay10ms();
                        if (K2==0)
                                n=n-1;
                        for(m=0;((m<50)&&(K2==0));m++)
                                Delay10ms();
                if (K3==0)
                        Delay10ms();
                        if (K3==0)
                                n=0;
                        for(m=0;((m<50)&&(K3==0));m++)
                                Delay10ms();
                if (K4==0)
                        Delay10ms();
                        if (K4==0)
                                if (n!=0)
                                        TR0=1;
                        for(m=0;((m<50)&&(K4==0));m++)
                                Delay10ms();
                DISPLAY();
                XS();
void Time0 (void) interrupt 1
        unsigned char m;
        TL0 = 0x00;
        TH0 = 0x4C;
        TT++;
        if (TT==20)
                n--;
                if (n==0)
                        for (m=0;m<100;m++)
                                DISPLAY();
                                XS();
                        TR0=0;
                        FMQ=0;
                        Delay100ms();
                        FMQ=1;
                TT=0;
ID:401370 發(fā)表于 2018-11-30 20:34 | 只看該作者
HC6800-ES-V2.0 發(fā)表于 2018-11-30 09:15
倒計(jì)時(shí)嘛,有什么難的。看我的:/*
可否幫我改一下我的那個(gè)程序..
