查看: 3531|回復(fù): 1
MSP430實(shí)現(xiàn)定時(shí)器的源程序
ID:436127 發(fā)表于 2018-11-30 22:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
該程序使用到了TM1638,附件中有。
(上一篇文章中的程序包含了此程序的公共代碼部分,但是我忘了把 tm1638.h 放到附件里面了,這次補(bǔ)上)
定時(shí)器初值設(shè)為00:02:15,結(jié)束后重置為23:59:59
源の代碼:
#include "TM1638.h"
#include "msp430f6638.h"
#include "stdint.h"
uint8_t num[8];    //各個(gè)數(shù)碼管顯示的值
uint8_t led_flag[8];
const uint8_t tab[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x00};
void init_port(void)
    P3DIR |= BIT5;
    P3DIR |= BIT4 + BIT2;
    P1DIR |= BIT0;    // ACLK set out to pins
    P1SEL |= BIT0;
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void TM1638_Write(unsigned char DATA)   //寫數(shù)據(jù)函數(shù)
    unsigned char i;
    DIO_OUT;
    for(i=0;i<8;i++)
      CLK_low;
      if(DATA & 0x01)
          DIO_high;
          DIO_low;
      CLK_high;
      DATA>>=1;
unsigned char TM1638_Read(void)     //讀數(shù)據(jù)函數(shù)
    unsigned char i;
    unsigned char temp=0;
    DIO_IN;
    STB_low;
    for(i=0;i<8;i++)
          temp>>=1;
          CLK_low;
          _delay_us(100);
          if(DIO_READ)
              temp |= 0x80;
              temp &= 0x7f;
          CLK_high;
    return temp;
void Write_COM(unsigned char cmd)  //發(fā)送命令字
    CLK_high;
    STB_high;
    STB_low;
    TM1638_Write(cmd);
    STB_high;
void Write_DATA(unsigned char add,unsigned char DATA)  //指定地址寫入數(shù)據(jù)
    Write_COM(0x44);
    STB_low;
    TM1638_Write(0xc0|add);
    TM1638_Write(DATA);
    STB_high;
void init_TM1638(void)
    unsigned char count = 0;
    unsigned char times = 1;
    while(times--){
        Write_allLED(tab2[count]);
        count++;
        if(count == 16)
            count = 0;
        _delay_ms(100);
    Write_allLED(0xff);
    _delay_ms(100);
    Write_allLED(0);
void delay(){
    for (int i=0; i<10; i++)
      for (int j=0; j<1000; j++);
void  Write_allLED(unsigned char DATA){
    unsigned char i;
    Write_COM(0x8F);//顯示控制
    Write_COM(0x40); //數(shù)據(jù)命令
    STB_low;
    TM1638_Write(0xc0);
    for(i=0;i<16;i++)
    TM1638_Write(DATA);
    STB_high;
int main(void)
    WDTCTL = WDTPW+WDTHOLD;
    init_port();
    init_TM1638();
    int hourA = 0;
    int hourB = 0;
    int minuteA = 0;
    int minuteB = 2;
    int secondA = 1;
    int secondB = 5;
    while(1) {
        secondB--;
        if(secondB == -1) {
            secondB = 9;
            secondA--;
            if(secondA == -1) {
                secondA = 5;
                minuteB--;
                if(minuteB == -1) {
                    minuteB = 9;
                    minuteA--;
                    if(minuteA == -1) {
                        minuteA = 5;
                        hourB--;
                        if(hourB == -1) {
                            hourB = 9;
                            hourA--;
                            if(hourA == -1) {
                                hourA = 2;
                                hourB = 3;
        Write_DATA(4*2,tab[hourA]);
        Write_DATA(5*2,tab[hourB]);
        Write_DATA(6*2,tab[15]);
        Write_DATA(7*2,tab[minuteA]);
        Write_DATA(0*2,tab[minuteB]);
        Write_DATA(1*2,tab[15]);
        Write_DATA(2*2,tab[secondA]);
        Write_DATA(3*2,tab[secondB]);
        delay();
sy2-3-1.zip
1.94 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
定時(shí)器
ID:436127 發(fā)表于 2018-11-30 22:17 | 只看該作者
補(bǔ)充說明一下,主函數(shù)中的delay是我自己寫的,是為了便于調(diào)試,并沒有真正起到延時(shí)1s的作用
