我們知道阻塞模式的程序存在代碼簡(jiǎn)潔、邏輯性強(qiáng)、容易理解等優(yōu)點(diǎn)。但是阻塞模式的代碼也存在效率不高,不適合多任務(wù)等缺點(diǎn)。在此我們用ST7735顯示用阻塞模式和查詢模式分別顯示特定圖象,對(duì)它們之間的性能進(jìn)
選擇硬件為CPU:stm32f103c8t6,顯示屏為128X128pix。比較SPI16bit方式的阻塞與查詢模式的顯示效果。話不多說(shuō)貼上兩者的代碼。首先上阻塞模式的代碼:
//code by pmason_rose@qq.com
#include "stm32f10x.h"
#include "stm32f10x_spi.h"
#define LED_PORT GPIOC
#define LED_PIN GPIO_Pin_13
#define LCD_CTRL GPIOB //定義TFT數(shù)據(jù)端口
#define LCD_SCL GPIO_Pin_13 //PB13連接至TFT -- CLK
#define LCD_SDA GPIO_Pin_15 //PB15連接至TFT - SDI
#define LCD_LED GPIO_Pin_9 //PB9 連接至TFT -LED
#define LCD_RS GPIO_Pin_10 //PB10連接至TFT --RS
#define LCD_CS GPIO_Pin_11 //PB11 連接至TFT --CS
#define LCD_RST GPIO_Pin_12 //PB12連接至TFT --RST
//液晶控制口置1操作語(yǔ)句宏定義
#define LCD_CS_SET LCD_CTRL->BSRR=LCD_CS
#define LCD_RS_SET LCD_CTRL->BSRR=LCD_RS
#define LCD_SDA_SET LCD_CTRL->BSRR=LCD_SDA
#define LCD_SCL_SET LCD_CTRL->BSRR=LCD_SCL
#define LCD_RST_SET LCD_CTRL->BSRR=LCD_RST
#define LCD_LED_SET LCD_CTRL->BSRR=LCD_LED
//液晶控制口置0操作語(yǔ)句宏定義
#define LCD_CS_CLR LCD_CTRL->BRR=LCD_CS
#define LCD_RS_CLR LCD_CTRL->BRR=LCD_RS
#define LCD_SDA_CLR LCD_CTRL->BRR=LCD_SDA
#define LCD_SCL_CLR LCD_CTRL->BRR=LCD_SCL
#define LCD_RST_CLR LCD_CTRL->BRR=LCD_RST
#define LCD_LED_CLR LCD_CTRL->BRR=LCD_LED
* 名 稱:SPI2_Init(void)
* 功 能:STM32_SPI2硬件配置初始化
* 入口參數(shù):無(wú)
* 出口參數(shù):無(wú)
* 說(shuō) 明:STM32_SPI2硬件配置初始化
void SPI2_Init(void)
SPI_InitTypeDef SPI_InitStructure;
//配置SPI2管腳
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10| GPIO_Pin_11| GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin = LED_PIN;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(LED_PORT, GPIO_Pin_13); // LED
//SPI2配置選項(xiàng)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2 ,ENABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
//使能SPI2
SPI_Cmd(SPI2, ENABLE);
* 名 稱:u8 SPI_WriteByte(SPI_TypeDef* SPIx,u8 Byte)
* 功 能:STM32_硬件SPI讀寫一個(gè)字節(jié)數(shù)據(jù)底層函數(shù)
* 入口參數(shù):SPIx,Byte
* 出口參數(shù):返回總線收到的數(shù)據(jù)
* 說(shuō) 明:STM32_硬件SPI讀寫一個(gè)字節(jié)數(shù)據(jù)底層函數(shù)
u16 SPI_WriteData(SPI_TypeDef* SPIx,u16 data)
while((SPIx->SR&SPI_I2S_FLAG_TXE)==RESET); //等待發(fā)送區(qū)空
SPIx->DR=data; //發(fā)送一個(gè)字節(jié)
while((SPIx->SR&SPI_I2S_FLAG_RXNE)==RESET);//等待接收完成
return SPIx->DR; //返回收到的數(shù)據(jù)
//函數(shù)名: LCD_WR_REG
//功能: 向液晶屏總線寫入寫16位指令
//輸入?yún)?shù):Reg:待寫入的指令值
//返回值: 無(wú)
//修改記錄:無(wú)
void LCD_WR_REG_16b(u16 data)
LCD_CS_CLR;
LCD_RS_CLR;
SPI_WriteData(SPI2,data);
LCD_CS_SET;
//函數(shù)名: LCD_WR_DATA
//功能: 向液晶屏總線寫入寫8位數(shù)據(jù)
//輸入?yún)?shù):Data:待寫入的數(shù)據(jù)
//返回值: 無(wú)
//修改記錄:無(wú)
void LCD_WR_DATA_16b(u16 data)
LCD_CS_CLR;
LCD_RS_SET;
LCD_CS_SET;
函數(shù)名:LCD_SetWindows
功能:設(shè)置lcd顯示窗口,在此區(qū)域?qū)扅c(diǎn)數(shù)據(jù)自動(dòng)換行
入口參數(shù):xy起點(diǎn)和終點(diǎn)
返回值:無(wú)
void LCD_SetWindows(u16 xStar, u16 yStar,u16 xEnd,u16 yEnd)
LCD_WR_REG_16b(0x002a);
LCD_WR_DATA_16b(yStar+2);
LCD_WR_DATA_16b(yEnd+2);
LCD_WR_REG_16b(0x002b);
LCD_WR_DATA_16b(yStar+3);
LCD_WR_DATA_16b(yEnd+3);
LCD_WR_REG_16b(0x002C);
函數(shù)名:DelayS
功能:阻塞模式的延時(shí)函數(shù)
入口參數(shù):延時(shí)大小
返回值:無(wú)
void DelayS(u32 nCount)
for(;nCount!=0;nCount--);
//函數(shù)名: LCD_Init
//功能: LCD初始化
//輸入?yún)?shù):無(wú)
//返回值: 無(wú)
//修改記錄:無(wú)
void LCD_Init(void)
SPI2_Init();
LCD_RST_CLR;
DelayS(100);
LCD_RST_SET;
DelayS(500);
LCD_WR_REG_16b(0x0011);
LCD_WR_REG_16b(0x00B1);
LCD_WR_DATA_16b(0x012C);
LCD_WR_DATA_16b(0x2D00);
LCD_WR_REG_16b(0x00B2);
LCD_WR_REG_16b(0x00B3);
LCD_WR_DATA_16b(0x2D01);
LCD_WR_DATA_16b(0x2C2D);
LCD_WR_REG_16b(0x00B4);
LCD_WR_DATA_16b(0x0700);
LCD_WR_REG_16b(0x00C0);
LCD_WR_DATA_16b(0xA202);
LCD_WR_DATA_16b(0x8400);
LCD_WR_REG_16b(0x00C1);
LCD_WR_DATA_16b(0xC500);
LCD_WR_REG_16b(0x00C2);
LCD_WR_DATA_16b(0x0A00);
LCD_WR_REG_16b(0x00C3);
LCD_WR_DATA_16b(0x8A2A);
LCD_WR_REG_16b(0x00C4);
LCD_WR_DATA_16b(0x8AEE);
LCD_WR_REG_16b(0x00C5);
LCD_WR_DATA_16b(0x0E00);
LCD_WR_REG_16b(0x0036);
LCD_WR_DATA_16b(0xC800);
LCD_WR_REG_16b(0x00e0);
LCD_WR_DATA_16b(0x0f1a);
LCD_WR_DATA_16b(0x0f18);
LCD_WR_DATA_16b(0x2f28);
LCD_WR_DATA_16b(0x2022);
LCD_WR_DATA_16b(0x1f1b);
LCD_WR_DATA_16b(0x2337);
LCD_WR_DATA_16b(0x0007);
LCD_WR_DATA_16b(0x0210);
LCD_WR_DATA_16b(0x0f1b);
LCD_WR_DATA_16b(0x0f17);
LCD_WR_DATA_16b(0x332c);
LCD_WR_DATA_16b(0x292e);
LCD_WR_DATA_16b(0x3030);
LCD_WR_DATA_16b(0x393f);
LCD_WR_DATA_16b(0x0310);
LCD_WR_DATA_16b(0x0000);
LCD_WR_DATA_16b(0x007f);
LCD_WR_REG_16b(0x0026);
LCD_WR_DATA_16b(0x009f);
LCD_WR_REG_16b(0x00F0);
LCD_WR_DATA_16b(0x0100);
LCD_WR_REG_16b(0x00F6);
LCD_WR_REG_16b(0x003A);
LCD_WR_DATA_16b(0x0500);
LCD_WR_REG_16b(0x2936);
void LCD_Clear(u16 Color)
u32 Lcd_Index=0;
LCD_SetWindows(0,0,127,127);
for(Lcd_Index=0;Lcd_Index<(128*128);Lcd_Index++)
LCD_WR_DATA_16b(Color);
