查看: 3101|回復: 0
ERROR L104: MULTIPLE PUBLIC DEFINITIONS單片機庫函數(shù)的頭文件總是出問題?
ID:284936 發(fā)表于 2018-12-1 17:57 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
*    通用頭文件
#include "general.h"
*    main主函數(shù)
//        P1 =0xfe;
                run1_led();                //流水燈函數(shù)
                display(0,1);              //數(shù)碼管動態(tài)掃描函數(shù)
//                display(1,2);
//                display(2,3);
//                display(3,4);
//                display(4,5);
//                display(5,6);
通用頭文件__GENERAL_H_頭文件    (包含所有調(diào)用函數(shù)頭文件)
#ifndef __GENERAL_H_
#define __GENERAL_H_
#include <reg52.h>
#include <intrins.h>
#include "def.h"
#include "running_led.h"
#include "delay.h"
#include "display_led.h"
#endif
宏定義__DEF_H_頭文件
#ifndef __DEF_H_
#define __DEF_H_
#endif
延時函數(shù)__DELAY_H_頭文件
#ifndef __DELAY_H_
#define __DELAY_H_
void delay(uint z);
#endif
延時函數(shù).C文件
*   包含頭文件
#include "delay.h"
*   延時函數(shù)
void delay(uint z)
        uint x,y;
        for(x = z;x > 0; x--)
                for(y = 110;y > 0;y--);
數(shù)碼管掃描__DISPLAY_LED_H_頭文件
#ifndef __DISPLAY_LED_H_
#define __DISPLAY_LED_H_
sbit dula = P2^6;
sbit wela = P2^7;
uchar code tabledu[]= {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x7b,0x71};
uchar code tablewe[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
void display(uchar we,uchar du);
#endif
數(shù)碼管掃面.C文件
*   包含頭文件
*    掃描函數(shù)
        dula = 1;
        P0 = tabledu[du];
        dula = 0;
        delay(5);
        P0 = 0XFF;
        wela = 1;
        P0 = tablewe[we];
        wela = 0;
為什么編譯會出現(xiàn)好多警告
Rebuild target 'Target 1'
assembling STARTUP.A51...
compiling delay.c...
compiling main.c...
Objects\main.c(17): warning C206: 'run1_led': missing function-prototype
compiling display_led.c...
linking...
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
    SYMBOL:  TABLEWE
    MODULE:  .\Objects\main.obj (MAIN)
    SYMBOL:  TABLEDU
    SYMBOL:  TABLEWE
    MODULE:  .\Objects\display_led.obj (DISPLAY_LED)
    SYMBOL:  TABLEDU
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?CO?DELAY
    SEGMENT: ?CO?MAIN
    SEGMENT: ?PR?_DISPLAY?DISPLAY_LED
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  RUN1_LED
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
    SYMBOL:  RUN1_LED
    ADDRESS: 0094H
Program Size: data=10.0 xdata=0 code=152
Target not created.
Build Time Elapsed:  00:00:01
