查看: 11046|回復(fù): 2
單片機(jī)與4個(gè)獨(dú)立按鍵和8個(gè)led指示燈構(gòu)成的獨(dú)立式鍵盤系統(tǒng)設(shè)計(jì)
ID:437916 發(fā)表于 2018-12-2 22:52 | 顯示全部樓層 |閱讀模式
按下k1時(shí)led燈由上至下流水點(diǎn)亮
按下k2時(shí)led燈由下至上流水點(diǎn)亮
按下k3時(shí)led燈高低4個(gè)led交替點(diǎn)亮
按下K4時(shí)led燈閃爍點(diǎn)亮
電路圖
電路圖
單片機(jī)源碼:
  1. #include<reg51.h>
  2. #include<absacc.h>
  4. bit keyflag;                        // keyflag為按鍵按下的標(biāo)志位
  5. uchar keyval;                         // keyval為鍵值
  6. uchar forwardtab[ ]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  7. uchar backwardtab[ ]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  8. uchar altertab[]={0x0f,0xf0};
  9. uchar blinktab[]={0x00,0xff};
  10. void delay10ms(void)                        //函數(shù):軟件消抖延時(shí)10ms
  11.   {         unsigned char i,j;
  12.                 for(i=0;i<100;i++)
  13.                 for(j=0;j<100;j++)
  14.                 ;
  15.                 }
  16. void led_delay(void)                        //函數(shù):延時(shí)
  17.          {    unsigned char i,j;
  18.                   for(i=0;i<220;i++)
  19.                   for(j=0;j<220;j++)
  20.                                                 ;
  21.                                         }
  22.
  23. void forward(void)        //函數(shù)功能:正向流水點(diǎn)亮LED
  24. {
  25.          unsigned char i,j;
  26.         for(j=0;j<10;j++)
  27.         { for (i=0;i<8;i++)
  28.           {
  29.                 P0=forwardtab[i];                         //LED0亮
  30.             led_delay();
  31.                 }
  32.         }
  33.         P0=0xff;
  34.         }
  35. void backward(void)        //函數(shù)功能:反向流水點(diǎn)亮LED
  36. {
  37.          unsigned char i,j;
  38.         for(j=0;j<10;j++)
  39.         { for (i=0;i<8;i++)
  40.           {
  41.                 P0=backwardtab[i];                         //LED0亮
  42.             led_delay();
  43.                 }
  44.         }
  45.         P0=0xff;
  46.         }
  47.
  48. void alter(void)        //函數(shù)功能:反向流水點(diǎn)亮LED
  49. {
  50.          unsigned char i,j;
  51.         for(j=0;j<10;j++)
  52.         { for (i=0;i<2;i++)
  53.           {
  54.                 P0=altertab[i];                         //LED0亮
  55.             led_delay();
  56.                 }
  57.         }
  58.         P0=0xff;
  59.         }
  60. void blink(void)        //函數(shù)功能:反向流水點(diǎn)亮LED
  61. {
  62.          unsigned char i,j;
  63.         for(j=0;j<10;j++)
  64.         { for (i=0;i<2;i++)
  65.           {
  66.                 P0=blinktab[i];                         //LED0亮
  67.             led_delay();
  68.                 }
  69.         }
  70.         P0=0xff;
  71.         }
  72. void main(void)
  73. {
  74.         IE=0x81;                //總中斷允許EA=1,允許中斷
  75.         IT0=1;       //跳邊沿觸發(fā)INT0
  76.     keyflag=0;                //設(shè)置按鍵按下標(biāo)志為0
  77. do {
  78.         P0=0x00; //全亮
  79.         if(keyflag)                //如果按鍵按下標(biāo)志keyflag =1,則有鍵按下
  80.                 {
  81.
  82.                         keyval=~keyval;        //鍵值取反
  83.                         switch(keyval)                //根據(jù)按下鍵的鍵值進(jìn)行分支跳轉(zhuǎn)
  84.                         {
  85.                                 case 1: forward();                //處理0號(hào)鍵
  86.                                 break;
  87.                                 case 2: backward();                //處理0號(hào)鍵
  88.                                 break;
  89.                                 case 4: alter();                //處理0號(hào)鍵
  90.                                 break;
  91.                                 case 8: blink();                //處理0號(hào)鍵
  92.                                 break; }
  93.                                 keyflag=0;                //清按鍵按下標(biāo)志
  94.                 }
  95.         } while(1);
  96.                                 }
  97.
  98.
  99. void int0( )  interrupt 0        //有鍵按下,則執(zhí)行的中斷函數(shù)
  100.         {
  101.                 uchar reread_key;                 // reread_key為重讀鍵值變量;
  102.                 IE=0x80;                        // 屏蔽中斷
  103.                 keyflag=0;                 // 把按鍵按下標(biāo)志keyflag清0
  104.                 P1=0xff;                 // 向P1口寫1,設(shè)置P1口為輸入
  105.                 keyval=P1;                 // 從P1口讀入鍵盤的狀態(tài)
  106.                 delay10ms();         // 延時(shí)10ms
  107.                 reread_key=P1;         // 再次從P1口讀鍵盤狀態(tài),并存reread_key中
  108.                 if(keyval==reread_key) // 比較兩次讀取的鍵值,如相同,說(shuō)明鍵按下
  109.                {                 keyflag=1;                 // 按鍵按下標(biāo)志key_flag為1     }
  110.                                         IE=0x81;                         // 重新允許中斷
  111.                                                         }
  112.                                                 }
全部資料51hei下載地址:
project512.zip (58.87 KB, 下載次數(shù): 55)
ID:722429 發(fā)表于 2020-4-4 18:54 | 顯示全部樓層
最下面的原件是什么
ID:1054290 發(fā)表于 2022-11-29 10:09 | 顯示全部樓層
為什么沒(méi)有反應(yīng)
