查看: 1760|回復(fù): 0
單片機滾動顯示電話號碼 C語言程序
ID:438865 發(fā)表于 2018-12-3 23:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//程序:ex30.c
//功能:在8×8LED點陣上從下向上滾動顯示出手機號碼 "13592346786"
#include <REGX51.H> //包含頭文件REGX51.H,定義了51單片機的所有SFR
//函數(shù)名:delayms
//函數(shù)功能:實現(xiàn)軟件延時
//形式參數(shù):無符號整型變量i,控制時間為i*1ms
//返回值:無
void   delayms(unsigned int i)
{unsigned char k;
while(i--)
for(k=0;k<120;k++);     //120次空操作
unsigned char code led[]={0xff,0xe7,0xc7,0xe7,0xe7,0xe7,0xe7,0xe7,          //1
                                0xff,0x87,0xf3,0xf3,0xc7,0xf3,0xf3,0x87,           //3
                                                 0xff,0x87,0xbf,0x87,0xf3,0xf3,0xf3,0x87,          //5
                                                 0xff,0xc7,0x93,0x93,0x93,0xc3,0xf3,0xc7,          //9
                                                 0xff,0x87,0xf3,0xf3,0xc7,0x9f,0x9f,0x83,          //2
                                0xff,0xf3,0xe3,0xd3,0xb3,0x83,0xf3,0xf3,          //4
                                0xff,0xc7,0x9f,0x87,0x93,0x93,0x93,0xc7,          //6
                                0xff,0x03,0xf3,0xe7,0xe7,0xcf,0xcf,0xcf,      //7
                                0xff,0xc7,0x93,0x93,0xc7,0x93,0x93,0xc7,          //8
                                                0xff,0xc7,0x9f,0x87,0x93,0x93,0x93,0xc7};    //6
   unsigned char w;
   unsigned int i,j,k,m;
     for(k=0;k<88;k++)                  //顯示滾動行數(shù)控制變量
           for(m=0;m<100;m++) //每個字符掃描顯示100次,控制每個字符顯示時間
                   w=0x01;
           j=k;
           for(i=0;i<8;i++)
               P1=w;                           //行數(shù)據(jù)送P1口
               P0=led[j];                      //列數(shù)據(jù)送P0口
               delayms(1);
                           P0=0xff;                        //關(guān)顯示
               w<<=1;                          //行變量左移指向下一行
                           j++;                            //指向數(shù)組中下一個顯示碼
               if(j>87)j=j-88;                 //如果列數(shù)據(jù)顯示完回到初始
