查看: 1230|回復(fù): 0
LED矩陣海浪式呼吸效果單片機(jī)源程序
ID:412944 發(fā)表于 2018-12-4 12:47 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <REG51.H>
unsigned char code tabb[]= {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //衡條表
uint PWM_Count,PWM_ZKB,PWM_Delay,PWM_Number;
unsigned char LED;
bit PWM_END;
void Timer0Init(void);                //10微秒@12.000MHz
void Delay500MS();
/*************主函數(shù)*****************************/
void main(void)
        Timer0Init();
    P2=0x00;
        for(LED=0; LED<8; LED++) //循環(huán)8次逐條點(diǎn)亮8個(gè)LED點(diǎn)陣燈
            P0=tabb[7-LED];
            Delay500MS();
            P0=0x00;
                        Delay500MS();
            TR0=1;
            PWM_END = 1;
            while(PWM_END);
void Timer0Init(void)                //10微秒@12.000MHz
    TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
    TMOD |= 0x02;                //設(shè)置定時(shí)器模式
    TL0 = 0xF7;                //設(shè)置定時(shí)初值
    TH0 = 0xF7;                //設(shè)置定時(shí)重載值
    TF0 = 0;                //清除TF0標(biāo)志
    TR0 = 0;                //定時(shí)器0開始計(jì)時(shí)
    ET0 = 1;
    EA = 1;
/*************延時(shí)函數(shù)*********************/
void Delay500MS()                //@11.0592MHz
        unsigned char i, j, k;
        i = 4;
        j = 129;
        k = 119;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void TIME0()        interrupt 1
    PWM_Count++;
    if(PWM_Count > 100)
        PWM_Count = 0;
        PWM_Delay++;
        if(PWM_Delay > 20)
                        PWM_Delay = 0;
//                        if(PWM_ZKB > 60)
//                                PWM_ZKB +=2;
//                        else
                                PWM_ZKB++;
        if(PWM_ZKB > 30)
            PWM_ZKB = 0;
            PWM_Number++;
            if(PWM_Number > 3)
                PWM_Number = 0;
                PWM_END=0;
                TR0 = 0;
        if(PWM_Count < PWM_ZKB)
            P0=tabb[7-LED];
            P0 = 0x00;
