查看: 2955|回復: 1
跪求大神 51單片機24s倒計時 以及計時完畢后蜂鳴器響3
ID:440935 發(fā)表于 2018-12-6 15:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
想用proteus仿真一個籃球24s倒計時的電路,51單片機,倒計時為零后蜂鳴器會響,計時完畢后自行復位24s重新開始
初學者
求教
ID:645140 發(fā)表于 2020-11-16 19:44 | 只看該作者
#include<reg52.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit addr0 = P1^0;
sbit addr1 = P1^1;
sbit addr2 = P1^2;
sbit beep=P1^5;
u8 code smgduan[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
                                        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//顯示0~F的值
u8 LedBuff[3]= {
        //數(shù)碼管的顯示緩沖區(qū),初值0x00確保啟動時都不亮
        0x00,0x00,0x00
u8 flag1s = 0;
u16 cnt = 0;
u8 i = 0;
void delay(u16 j)
        while(j--);
void Timer0Init(void);
        u8 sec = 24;        //記錄經(jīng)過的秒數(shù)
        Timer0Init();
                if (flag1s == 1) //判斷 1 秒定時標志
                        flag1s = 0; //1 秒定時標志清零
                        sec--; //秒計數(shù)自加 1
                        //以下代碼將 sec 按十進制位從低到高依次提取并轉(zhuǎn)為數(shù)碼管顯示字符
                        LedBuff[2] = smgduan[sec%10];
                        LedBuff[1] = smgduan[sec/10%10];
                        LedBuff[0] = smgduan[sec/100%10];
                        if(sec == 0)
                                sec = 24;
                                beep=~beep;
                                delay(10);
void Timer0Init()                //1毫秒@11.0592MHz
        TMOD &= 0xF0;                //設(shè)置定時器模式
        TMOD |= 0x01;                //設(shè)置定時器模式
        TL0 = 0x66;                //設(shè)置定時初值
        TH0 = 0xFC;                //設(shè)置定時初值
        TF0 = 0;                //清除TF0標志
        TR0 = 1;                //定時器0開始計時
        EA = 1;
        ET0 = 1;
void InterruptTimer0() interrupt 1
        static u8 i = 0;
        TH0 = 0xfc;
        TL0 = 0x67;
        cnt++;
        if(cnt == 1000)
                cnt = 0;
                flag1s = 1;
        P0 = 0x00;
        P1 = (0xf8 & P1) | i;
        P0 = LedBuff[i];
        if(i < 3)
                i++;
                i = 0;
