查看: 4043|回復(fù): 0
一種很精煉的矩陣鍵盤掃描應(yīng)用原理圖及單片機源碼
ID:21069 發(fā)表于 2018-12-7 02:54 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
電路原理圖如下:
//  4×4 鍵盤矩陣按鍵
#include <avr/io.h>
#include <util/delay.h>
#define    uint   unsigned int
#define    BEEP( )  PORTD ^= _BV(PD7)  //蜂鳴器
uint KeyNo = 16 ; //16表示無按鍵
const uint  SEG_CODE[ ] =
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
                0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71
uint  Key_Down()  // 消抖與松檢測
        DDRB = 0XF0;  PORTB = 0X0F;
        _delay_ms(1);
        if(PINB!=0x0F)return 1;  //        return PINB!= 0x0f ? 1:0;
        else return 0;
//--------------------  重點-------------------  //
void Keys_Scan()  //------------ 鍵盤矩陣掃描程序
        switch(PINB)
    case 0B00001110: KeyNo=0; break;
    case 0B00001101: KeyNo=1; break;
        case 0B00001011: KeyNo=2; break;
        case 0B00000111: KeyNo=3; break;
        default: KeyNo=0xFF;
        DDRB = 0X0F; PORTB = 0xF0;
        _delay_ms(1);
        switch(PINB)
        case 0B11100000: KeyNo+=0; break;
        case 0B11010000: KeyNo+=4; break;
        case 0B10110000: KeyNo+=8; break;
        case 0B01110000: KeyNo+=12; break;
    default: KeyNo= 0xFF;
void sounn()
        uint i;
        for ( i = 0; i < 200; i++)
                _delay_ms(1);_delay_ms(1);
                BEEP( );
int main()
                if( Key_Down( ))Keys_Scan ( ); //有按下就讀值,否則一邊玩去
                else continue;
                if( KeyNo < 16)
                        DDRC = 0xff;
                        PORTC = SEG_CODE[ KeyNo ];
                        sounn();
                while( Key_Down( ));//松手了沒有?
全部資料51hei下載地址:
一款很精煉的矩陣鍵盤掃描應(yīng)用電路圖.rar (9.87 KB, 下載次數(shù): 19)
參與人數(shù) 2黑幣 +24 收起 理由
鉆牛尖滴劉尖尖 + 9
shuisheng + 15 很給力!
