查看: 4167|回復(fù): 0
單片機(jī)+ADC0808+74LS74數(shù)字電壓表仿真與代碼
ID:219527 發(fā)表于 2018-12-8 11:15 | 顯示全部樓層 |閱讀模式
ADC0808+74LS74實(shí)現(xiàn)ad采樣
  1. #include <AT89X51.H>
  2. unsigned char code dispbitcode[]={0xfe,0xfd,0xfb,0xf7, 0xef,0xdf,0xbf,0x7f};
  3. unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66, 0x6d,0x7d,0x07,0x7f,0x6f,0x00};
  4. unsigned char dispbuf[8]={10,10,10,10,10,0,0,0};
  5. unsigned char dispcount;
  6. unsigned char getdata;
  7. unsigned int temp;
  8. long int  i;
  9. unsigned int R1;
  10. sbit ST=P3^0;
  11. sbit OE=P3^1;
  12. sbit EOC=P3^2;
  13. sbit CLK=P3^3;
  14.
  15. void main(void)
  16. {
  17.   ST=0;
  18.   OE=0;
  19.   ET0=1;
  20.   ET1=1;
  21.   EA=1;
  22.   TMOD=0x12;
  23.   TH0=216;
  24.   TL0=216;
  25.   TH1=(65536-5000)/256;
  26.   TL1=(65536-5000)%256;
  27.   TR1=1;
  28.   TR0=1;
  29.   ST=1;
  30.   ST=0;
  31.   while(1)
  32.     {
  33.       if(EOC==1)
  34.         {
  35.           OE=1;
  36.           getdata=P0;
  37.           OE=0;
  38.                     i=getdata*1960;
  39.                         dispbuf[5]=i/10000;
  40.                         i=i%10000;
  41.                         dispbuf[6]=i/1000;
  42.                         i=i%1000;
  43.                         dispbuf[7]=i/100;
  44.           ST=1;
  45.           ST=0;
  46.         }
  47.     }
  48. }
  49.
  50. void t0(void) interrupt 1 using 0
  51. {
  52.   CLK=~CLK;
  53. }
  54.
  55. void t1(void) interrupt 3 using 0
  56. {
  57.   TH1=(65536-6000)/256;
  58.   TL1=(65536-6000)%256;
  59.   P2=0xff;
  60.   P1=dispcode[dispbuf[dispcount]];
  61.   P2=dispbitcode[dispcount];
  62.   if(dispcount==5)
  63.     {
  64.       P1=P1 | 0x80;
  65.     }
  66.   dispcount++;
  67.   if(dispcount==8)
  68.     {
  69.       dispcount=0;
  70.     }
  71. }
數(shù)字電壓表仿真140516.rar (62.31 KB, 下載次數(shù): 39)
