查看: 3102|回復: 2
51單片機測試mpu6050原始數(shù)據(jù)并用1602顯示代碼
ID:436656 發(fā)表于 2018-12-9 11:40 | 顯示全部樓層 |閱讀模式
#include <REG52.H>
#include <math.h>    //Keil library
#include <stdio.h>   //Keil library
#include <INTRINS.H>
typedef unsigned char  uchar;
typedef unsigned short ushort;
typedef unsigned int   uint;
// 定義51單片機端口
#define DataPort P0  //LCD1602數(shù)據(jù)端口
sbit    SCL=P1^0;   //IIC時鐘引腳定義
sbit    SDA=P1^1;   //IIC數(shù)據(jù)引腳定義
sbit    LCM_RS=P2^0;  //LCD1602命令端口
sbit    LCM_RW=P2^1;  //LCD1602命令端口
sbit    LCM_EN=P2^2;  //LCD1602命令端口
// 定義MPU6050內(nèi)部地址
#define SMPLRT_DIV  0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
#define CONFIG   0x1A //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG  0x1B //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG 0x1C //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
   #define TEMP_OUT_H  0x41
#define TEMP_OUT_L  0x42
#define GYRO_XOUT_H  0x43
#define GYRO_XOUT_L  0x44
#define GYRO_YOUT_H  0x45
#define GYRO_YOUT_L  0x46
#define GYRO_ZOUT_H  0x47
#define GYRO_ZOUT_L  0x48
#define PWR_MGMT_1  0x6B //電源管理,典型值:0x00(正常啟用)
#define WHO_AM_I   0x75 //IIC地址寄存器(默認數(shù)值0x68,只讀)
#define SlaveAddress 0xD0 //IIC寫入時的地址字節(jié)數(shù)據(jù),+1為讀取
//定義類型及變量
uchar dis[4];       //顯示數(shù)字(-511至512)的字符數(shù)組
int dis_data;      //變量
//int Temperature,Temp_h,Temp_l; //溫度及高低位數(shù)據(jù)
//函數(shù)聲明
void  delay(unsigned int k);          //延時
//LCD相關(guān)函數(shù)
void  InitLcd();              //初始化lcd1602
void  lcd_printf(uchar *s,int temp_data);
void  WriteDataLCM(uchar dataW);         //LCD數(shù)據(jù)
void  WriteCommandLCM(uchar CMD,uchar Attribc);    //LCD指令
void  DisplayOneChar(uchar X,uchar Y,uchar DData);   //顯示一個字符
void  DisplayListChar(uchar X,uchar Y,uchar *DData,L);
  void  InitMPU6050();             //初始化MPU6050
void  Delay5us();
void  I2C_Start();
void  I2C_Stop();
void  I2C_SendACK(bit ack);
bit   I2C_RecvACK();
void  I2C_SendByte(uchar dat);
uchar I2C_RecvByte();
void  I2C_ReadPage();
void  I2C_WritePage();
void  display_ACCEL_x();
void  display_ACCEL_y();
void  display_ACCEL_z();
uchar Single_ReadI2C(uchar REG_Address);      //讀取I2C數(shù)據(jù)
void  Single_WriteI2C(uchar REG_Address,uchar REG_data); //向I2C寫入數(shù)據(jù)
//整數(shù)轉(zhuǎn)字符串
if(temp_data<0)
  temp_data=-temp_data;
  *s='-';
else *s=' ';
*++s =temp_data/100+0x30;
temp_data=temp_data%100;     //取余運算
*++s =temp_data/10+0x30;
temp_data=temp_data%10;      //取余運算
*++s =temp_data+0x30;
unsigned int i,j;
for(i=0;i<k;i++)
  for(j=0;j<121;j++);
//LCD1602初始化
void InitLcd()
WriteCommandLCM(0x38,1);
WriteCommandLCM(0x08,1);
WriteCommandLCM(0x01,1);
WriteCommandLCM(0x06,1);
WriteCommandLCM(0x0c,1);
DisplayOneChar(0,0,'A');
DisplayOneChar(0,1,'G');
//LCD1602寫允許
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;LCM_RW=1;_nop_();
LCM_EN=1;_nop_();_nop_();
while(DataPort&0x80);
LCM_EN=0;
  //LCD1602寫入命令
if(Attribc)WaitForEnable();
LCM_RS=0;LCM_RW=0;_nop_();
DataPort=CMD;_nop_();
LCM_EN=1;_nop_();_nop_();LCM_EN=0;
//LCD1602寫入數(shù)據(jù)
WaitForEnable();
LCM_RS=1;LCM_RW=0;_nop_();
DataPort=dataW;_nop_();
//LCD1602寫入一個字符
Y&=1;
X&=15;
if(Y)X|=0x40;
X|=0x80;
WriteCommandLCM(X,0);
WriteDataLCM(DData);
   //LCD1602顯示字符串
uchar ListLength=0;
Y&=0x1;
X&=0xF;
while(L--)
  DisplayOneChar(X,Y,DData[ListLength]);
  ListLength++;
  X++;
//延時5微秒(STC90C52RC@12M)
//不同的工作環(huán)境,需要調(diào)整此函數(shù)
//當改用1T的MCU時,請調(diào)整此延時函數(shù)
void Delay5us()
_nop_();_nop_();_nop_();_nop_();
//I2C起始信號
void I2C_Start()
    SDA = 1;                    //拉高數(shù)據(jù)線
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SDA = 0;                    //產(chǎn)生下降沿
    Delay5us();                 //延時
    SCL = 0;                    //拉低時鐘線
//I2C停止信號
void I2C_Stop()
    SDA = 0;                    //拉低數(shù)據(jù)線
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SDA = 1;                    //產(chǎn)生上升沿
    Delay5us();                 //延時
//I2C發(fā)送應答信號
//入口參數(shù):ack (0:ACK 1:NAK)
    SDA = ack;                  //寫應答信號
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SCL = 0;                    //拉低時鐘線
    Delay5us();                 //延時
//I2C接收應答信號
bit I2C_RecvACK()
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    CY = SDA;                   //讀應答信號
    SCL = 0;                    //拉低時鐘線
    Delay5us();                 //延時
    return CY;
//向I2C總線發(fā)送一個字節(jié)數(shù)據(jù)
    uchar i;
    for (i=0; i<8; i++)         //8位計數(shù)器
        dat <<= 1;              //移出數(shù)據(jù)的最高位
        SDA = CY;               //送數(shù)據(jù)口
        SCL = 1;                //拉高時鐘線
        Delay5us();             //延時
        SCL = 0;                //拉低時鐘線
        Delay5us();             //延時
    I2C_RecvACK();
//從I2C總線接收一個字節(jié)數(shù)據(jù)
    uchar i;
    uchar dat = 0;
    SDA = 1;                    //使能內(nèi)部上拉,準備讀取數(shù)據(jù),
        dat <<= 1;
        SCL = 1;                //拉高時鐘線
        Delay5us();             //延時
        dat |= SDA;             //讀數(shù)據(jù)
        SCL = 0;                //拉低時鐘線
        Delay5us();             //延時
    return dat;
//向I2C設備寫入一個字節(jié)數(shù)據(jù)
    I2C_Start();                  //起始信號
    I2C_SendByte(SlaveAddress);   //發(fā)送設備地址+寫信號
    I2C_SendByte(REG_Address);    //內(nèi)部寄存器地址,
    I2C_SendByte(REG_data);       //內(nèi)部寄存器數(shù)據(jù),
    I2C_Stop();                   //發(fā)送停止信號
//從I2C設備讀取一個字節(jié)數(shù)據(jù)
uchar REG_data;
I2C_Start();                   //起始信號
I2C_SendByte(REG_Address);     //發(fā)送存儲單元地址,從0開始
I2C_Start();                   //起始信號
I2C_SendByte(SlaveAddress+1);  //發(fā)送設備地址+讀信號
REG_data=I2C_RecvByte();       //讀出寄存器數(shù)據(jù)
I2C_SendACK(1);                //接收應答信號
I2C_Stop();                    //停止信號
return REG_data;
//初始化MPU6050
void InitMPU6050()
Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠狀態(tài)
Single_WriteI2C(SMPLRT_DIV, 0x07);
Single_WriteI2C(CONFIG, 0x06);
Single_WriteI2C(GYRO_CONFIG, 0x18);
Single_WriteI2C(ACCEL_CONFIG, 0x01);
//合成數(shù)據(jù)
int GetData(uchar REG_Address)
char H,L;
H=Single_ReadI2C(REG_Address);
L=Single_ReadI2C(REG_Address+1);
return (H<<8)+L;   //合成數(shù)據(jù)
//在1602上顯示10位數(shù)據(jù)
void Display10BitData(int value,uchar x,uchar y)
value/=64;       //轉(zhuǎn)換為10位數(shù)據(jù)
lcd_printf(dis, value);   //轉(zhuǎn)換數(shù)據(jù)顯示
DisplayListChar(x,y,dis,4); //啟始列,行,顯示數(shù)組,顯示長度
//顯示溫度
//void display_temp()
// Temp_h=Single_ReadI2C(TEMP_OUT_H); //讀取溫度
// Temp_l=Single_ReadI2C(TEMP_OUT_L); //讀取溫度
// Temperature=Temp_h<<8|Temp_l;     //合成溫度
// Temperature = 35+ ((double) (Temperature + 13200)) / 280; // 計算出溫度
// lcd_printf(dis,Temperature);     //轉(zhuǎn)換數(shù)據(jù)顯示
// DisplayListChar(11,1,dis,4);     //啟始列,行,顯示數(shù)組,顯示位數(shù)
//主程序
delay(500);  //上電延時
InitLcd();  //液晶初始化
delay(150);
  Display10BitData(GetData(ACCEL_XOUT_H),2,0); //顯示X軸加速度
  Display10BitData(GetData(ACCEL_YOUT_H),7,0); //顯示Y軸加速度
  Display10BitData(GetData(ACCEL_ZOUT_H),12,0); //顯示Z軸加速度
  Display10BitData(GetData(GYRO_XOUT_H),2,1); //顯示X軸角速度
  Display10BitData(GetData(GYRO_YOUT_H),7,1); //顯示Y軸角速度
  Display10BitData(GetData(GYRO_ZOUT_H),12,1); //顯示Z軸角速度
  delay(500);
ID:421308 發(fā)表于 2019-7-19 14:59 | 顯示全部樓層
采到這個數(shù)據(jù)然后呢
ID:589964 發(fā)表于 2021-5-3 21:56 | 顯示全部樓層
為啥我的lcd啥也沒有顯示
