查看: 3426|回復(fù): 1
求STM32驅(qū)動(dòng)MAX7219顯示8位數(shù)碼管程序
ID:267330 發(fā)表于 2018-12-9 16:33 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
如題
ID:379175 發(fā)表于 2019-1-22 01:42 | 只看該作者
#include <reg52.h>
#define uint  unsigned int
//定義Max7219端口
sbit Max7219_pinCLK = P1^2;
sbit Max7219_pinCS  = P1^1;
sbit Max7219_pinDIN = P1^0;
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
//功能:向MAX7219(U3)寫入字節(jié)
//入口參數(shù):DATA
//出口參數(shù):無(wú)
//說(shuō)明:
void Write_Max7219_byte(uchar DATA)
            uchar i;
                Max7219_pinCS=0;
            for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80;
            DATA=DATA<<1;
            Max7219_pinCLK=1;
//功能:向MAX7219寫入數(shù)據(jù)
//入口參數(shù):address、dat
//出口參數(shù):無(wú)
//說(shuō)明:
void Write_Max7219(uchar address,uchar dat)
     Max7219_pinCS=0;
         Write_Max7219_byte(address);           //寫入地址,即數(shù)碼管編號(hào)
     Write_Max7219_byte(dat);               //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
         Max7219_pinCS=1;
void Init_MAX7219(void)
Write_Max7219(0x09, 0xff);       //譯碼方式:BCD碼
Write_Max7219(0x0a, 0x03);       //亮度
Write_Max7219(0x0b, 0x07);       //掃描界限;4個(gè)數(shù)碼管顯示
Write_Max7219(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219(0x0f, 0x01);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
void main(void)
Delay_xms(50);
Init_MAX7219();
Delay_xms(2000);
Write_Max7219(0x0f, 0x00);       //顯示測(cè)試:1;測(cè)試結(jié)束,正常顯示:0
Write_Max7219(1,8);
Write_Max7219(2,7);
Write_Max7219(3,6);
Write_Max7219(4,5);
Write_Max7219(5,4);
Write_Max7219(6,3);
Write_Max7219(7,2);
Write_Max7219(8,1);
while(1);
