查看: 7907|回復(fù): 1
Arduino紅外遙控舵機(jī)代碼(帶LCD12864顯示)
硬件:
Arduino UNO
紅外遙控接受接受模塊
LCD12864 液晶顯示屏
紅外發(fā)射器
代碼:
#include "InfraredRemote.h"
#include "LCD12864RSPI.h"    //3,8,9 引腳
#define AR_SIZE( a ) sizeof( a ) / sizeof( a[0] )
unsigned char show0[]={0xBA, 0xEC,0xCD, 0xE2,0xD2, 0xA3,0xBF, 0xD8,0xB6, 0xE6,0xBB, 0xFA};    //紅外遙控舵機(jī)
unsigned char show1[]={0xD2, 0xA3,0xBF, 0xD8,0xD6, 0xB8,0xC1, 0xEE,0x3A, 0x00};                    //遙控指令:
unsigned char show2[]={0xD0, 0xFD,0xD7, 0xAA,0xBD, 0xC7,0xB6, 0xC8,0x3A, 0x00};                    //旋轉(zhuǎn)角度:
unsigned char show3[]={0x28, 0x00,0xB0, 0xB4,0x30, 0x00,0xB8, 0xB4,0xD4, 0xAD,0x29, 0x00};         //(按0復(fù)原)
#define PWM_pin 2                  //舵機(jī)引腳
int pulsewidth = 0;                      //高電平時(shí)間
char d[3];                                  //定義年值存儲數(shù)組,3位
void setup()
Serial.begin(9600);
pinMode(PWM_pin,OUTPUT);
pinMode(IR_IN,INPUT_PULLUP);//設(shè)置紅外接收引腳為輸入
Serial.flush(); //清除串口緩沖器內(nèi)容函數(shù)。
timer1_init();//定時(shí)器初始化
startRun(0);
LCDA.Initialise();
delay(100);
LCDA.DisplayString(0,1,show0,AR_SIZE(show0));
LCDA.DisplayString(1,0,show1,AR_SIZE(show1));
LCDA.DisplayString(1,5," ",AR_SIZE(" "));
LCDA.DisplayString(2,0,show2,AR_SIZE(show1));
LCDA.DisplayString(2,5,"0",AR_SIZE("0"));
LCDA.DisplayString(3,1,show3,AR_SIZE(show3));
void loop()
remote_decode(); //譯碼
if( adrL_code == 0x45 )  {
LCDA.DisplayString(1,5," 1 ",AR_SIZE(" 1 "));
//Serial.println("1");
startRun(10);
} else if( adrL_code == 0x46) {
LCDA.DisplayString(1,5," 2 ",AR_SIZE(" 2 "));
//Serial.println("2");
startRun(20);
}else if( adrL_code == 0x47 ) {
LCDA.DisplayString(1,5," 3 ",AR_SIZE(" 3 "));
//Serial.println("3");
startRun(30);
} else if( adrL_code == 0x44 )  {
LCDA.DisplayString(1,5," 4 ",AR_SIZE(" 4 "));
//Serial.println("4");
startRun(40);
} else if( adrL_code == 0x40 )  {
LCDA.DisplayString(1,5," 5 ",AR_SIZE(" 5 "));
//Serial.println("5");
startRun(50);
} else if( adrL_code == 0x43 )  {
LCDA.DisplayString(1,5," 6 ",AR_SIZE(" 6 "));
//Serial.println("6");
startRun(60);
} else if( adrL_code == 0x07 )  {
LCDA.DisplayString(1,5," 7 ",AR_SIZE(" 7 "));
//Serial.println("7");
startRun(70);
} else if( adrL_code == 0x15) {
LCDA.DisplayString(1,5," 8 ",AR_SIZE(" 8 "));
//Serial.println("8");
startRun(80);
} else if( adrL_code == 0x09 ){
LCDA.DisplayString(1,5," 9 ",AR_SIZE(" 9 "));
//Serial.println("9");
startRun(90);
} else if( adrL_code == 0x19) {
LCDA.DisplayString(1,5," 0 ",AR_SIZE(" 0 "));
//Serial.println("0");
startRun(0);
} else if( adrL_code == 0x16) {
LCDA.DisplayString(1,5," * ",AR_SIZE(" * "));
//Serial.println("*");
startRun(100);
} else if( adrL_code == 0x0d) {
LCDA.DisplayString(1,5," # ",AR_SIZE(" # "));
//Serial.println("#");
startRun(110);
} else if( adrL_code == 0x18) {
LCDA.DisplayString(1,5," Up",AR_SIZE(" Up"));
//Serial.println("Up");
startRun(120);
} else if( adrL_code == 0x08 ){
LCDA.DisplayString(1,5," L ",AR_SIZE(" L "));
//Serial.println("left");
startRun(130);
} else if( adrL_code == 0x1C ){
LCDA.DisplayString(1,5," OK",AR_SIZE(" OK"));
//Serial.println(" OK ");
startRun(140);
} else if(adrL_code == 0x5A)  {
LCDA.DisplayString(1,5," R ",AR_SIZE(" R "));
//Serial.println("Right");
startRun(150);
} else if( adrL_code == 0x52 )  {
LCDA.DisplayString(1,5," D ",AR_SIZE(" D "));
//Serial.println("Down");
startRun(160);
adrL_code = 0x00;
adrH_code = 0x00;
ir_code = 0x00;
void servopulse(int servopin, int myangle) /*定義一個(gè)脈沖函數(shù),用來模擬方式產(chǎn)生PWM值*/
pulsewidth = (myangle * 11) + 500; //將角度轉(zhuǎn)化為500-2480 的脈寬值
digitalWrite(servopin, HIGH); //將舵機(jī)接口電平置高
delayMicroseconds(pulsewidth);//延時(shí)脈寬值的微秒數(shù)
digitalWrite(servopin, LOW); //將舵機(jī)接口電平置低
delay(20 - pulsewidth / 1000); //延時(shí)周期內(nèi)剩余時(shí)間
void startRun(int degree) {
if (degree >= 0 && degree <= 180) //判斷收到數(shù)據(jù)值是否符合范圍
//直接獲取旋轉(zhuǎn)角度
dtostrf(degree,3,0,d);
LCDA.DisplayString(2,5,(unsigned char *)d,AR_SIZE(d));
//Serial.print("moving servo to ");
//Serial.print(degree, DEC);
//Serial.println();
for (int i = 0; i <= 50; i++) //產(chǎn)生PWM個(gè)數(shù),等效延時(shí)以保證能轉(zhuǎn)到響應(yīng)角度
servopulse(PWM_pin, degree); //模擬產(chǎn)生PWM
InfraredRemote.h
#ifndef __InfraredRemote__H__
#define __InfraredRemote__H__
#include <Arduino.h>
#define IR_IN 11 //紅外接收
extern void timer1_init(void);        //定時(shí)器初始化函數(shù)
extern char logic_value();//判斷邏輯值“0”和“1”子函數(shù)
extern void pulse_deal();//接收地址碼和命令碼脈沖函數(shù)
extern void remote_decode(void);
extern void remote_deal(void);//執(zhí)行譯碼結(jié)果函數(shù)
extern unsigned int ir_code;// 用戶編碼值
extern unsigned int adrL_code;//命令碼
extern unsigned int adrH_code;//命令碼反碼
#endif
InfraredRemote.cpp
int Pulse_Width = 0;//存儲脈寬
unsigned int ir_code = 0x00;// 用戶編碼值
unsigned int adrL_code = 0x00;//命令碼
unsigned int adrH_code = 0x00;//命令碼反碼
void timer1_init(void)//定時(shí)器初始化函數(shù)
        TCCR1A = 0X00;
        TCCR1B = 0X05;//給定時(shí)器時(shí)鐘源                        //64us進(jìn)行一次計(jì)數(shù)器累加
        TCCR1C = 0X00;
        TCNT1 = 0X00;
        TIMSK1 = 0X00;  //禁止定時(shí)器溢出中斷
void remote_deal(void)//執(zhí)行譯碼結(jié)果函數(shù)
{ //數(shù)據(jù)顯示
        Serial.print("\nir_code:");
        Serial.println(ir_code,HEX);//16進(jìn)制顯示
        Serial.print("adrL_code:");
        Serial.println(adrL_code,HEX);//16進(jìn)制顯示
        Serial.print("adrH_code:");
        Serial.println(adrH_code,HEX);//16進(jìn)制顯示
char logic_value()//判斷邏輯值“0”和“1”子函數(shù)
        TCNT1 = 0X00;
        while(!(digitalRead(IR_IN))); //低等待
        Pulse_Width=TCNT1;
        TCNT1=0;
        if(Pulse_Width>=7&&Pulse_Width<=10)//低電平560us
                while(digitalRead(IR_IN));//是高就等待
                Pulse_Width=TCNT1;
                TCNT1=0;
                if(Pulse_Width>=7&&Pulse_Width<=10)//接著高電平560us
                        return 0;
                else if(Pulse_Width>=25&&Pulse_Width<=27) //接著高電平1.7ms
                        return 1;
        return -1;
void pulse_deal()//接收地址碼和命令碼脈沖函數(shù)
        int i;
        int j;
        ir_code=0x00;// 清零
        adrL_code=0x00;// 清零
        adrH_code=0x00;// 清零
        //解析遙控器編碼中的用戶編碼值
        for(i = 0 ; i < 16; i++)
                if(logic_value() == 1) //是1
                        ir_code |= (1<<i);//保存鍵值
        //解析遙控器編碼中的命令碼
        for(i = 0 ; i < 8; i++)
                        adrL_code |= (1<<i);//保存鍵值
        //解析遙控器編碼中的命令碼反碼
        for(j = 0 ; j < 8; j++)
                        adrH_code |= (1<<j);//保存鍵值
        remote_deal();
void remote_decode(void)//譯碼函數(shù)
        TCNT1=0X00;
        while(digitalRead(IR_IN))//是高就等待
                //if(TCNT1>=1563) //當(dāng)高電平持續(xù)時(shí)間超過100ms,表明此時(shí)沒有按鍵按下
                //        ir_code=0x00ff;// 用戶編碼值
                //        adrL_code=0x00;//鍵碼前一個(gè)字節(jié)值
                //        adrH_code=0x00;//鍵碼后一個(gè)字節(jié)值
                //        return;
        //如果高電平持續(xù)時(shí)間不超過100ms
        TCNT1=0X00;
        Pulse_Width=TCNT1;
        TCNT1=0;
        if(Pulse_Width>=140&&Pulse_Width<=141)//9ms
                Pulse_Width=TCNT1;
                TCNT1=0;
                if(Pulse_Width>=68&&Pulse_Width<=72)//4.5ms
                        pulse_deal();
                        return;
                else if(Pulse_Width>=34&&Pulse_Width<=36)//2.25ms
                        while(!(digitalRead(IR_IN)));//低等待
                        Pulse_Width=TCNT1;
                        TCNT1=0;
                        if(Pulse_Width>=7&&Pulse_Width<=10)//560us
                                return;
admin + 50 共享資料的黑幣獎勵!
收藏收藏2 分享淘帖 頂 踩
ID:389836 發(fā)表于 2019-5-31 09:09 | 只看該作者
還能液晶顯示,真不錯(cuò),樓主這個(gè)庫能分享下嗎?LCD12864RSPI.h
