增加3個(gè)標(biāo)志,k1開(kāi)始/清0,k2暫停/繼續(xù)。
#include<reg52.h>
#define LCD_DATAPINS P0
sbit RS=P2^6;
sbit RW=P2^5;
sbit E=P2^7;
sbit k1=P3^0;
sbit k2=P3^1;
//sbit k3=P3^2;
//sbit k4=P3^3;
uchar mil,sec,min,count;
uchar code table[ ]="WH JIAYOU";
uchar code table1[ ]=" 00:00:0 ";
bit sign_1=0,sign_2=0,sign_3=0;
void delay(uint z)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<100;y++);
void write_com(uchar com)
delay(1);
RS=0;
E=0;
RW=0;
delay(5);
LCD_DATAPINS=com;
E=1;
delay(5);
E=0;
void write_date(uchar date)
delay(1);
RS=1;
E=0;
RW=0;
delay(5);
LCD_DATAPINS=date;
E=1;
delay(5);
E=0;
void init()
uchar i;
E=0;
mil=0;
sec=0;
min=0;
count=0;
write_com(0x38);
write_com(0x01);
write_com(0x0c);
write_com(0x06);
write_com(0x80);
for(i=0;i<9;i++)
write_date(table[i]);
write_com(0x80+0x40);
for(i=0;i<12;i++)
write_date(table1[i]);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_msmm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void write_mm(uchar a,uchar date)
uchar shi;
shi=date%10;
write_com(0x80+0x40+a);
void keycan()
if(k1==0)
delay(5);
if(k1==0)
sign_1=~sign_1;//0=清0,1=開(kāi)始
if(sign_1==1)
sign_2=0;
if(sign_1==0)
sign_2=0;
mil=0;
sec=0;
min=0;
count=0;
write_msmm(4,min);
write_msmm(7,sec);
write_mm(10,mil);
while(!k1);
if(k2==0)
delay(5);
if(k2==0)
sign_2=~sign_2;//0=繼續(xù),1=暫停
while(!k2);
init();
keycan();
if(sign_3==1)
sign_3=0;
mil++;
if(mil==10)
mil=0;
sec++;
if(sec==60)
sec=0;
min++;
if(min==60)
min=0;
write_msmm(4,min);
write_msmm(7,sec);
write_mm(10,mil);
void timer0() interrupt 1
if((sign_1==1)&&(sign_2==0))
count++;
if(count==2)
count=0;
sign_3=1;
