查看: 3447|回復(fù): 1
ArduinoMega2560引腳操作底層庫,能夠提高操作效率和速度
ID:282138 發(fā)表于 2018-12-11 10:39 | 顯示全部樓層 |閱讀模式
之前做項目的時候發(fā)現(xiàn) digitalWrite() 耗時能達(dá)到30us,導(dǎo)致系統(tǒng)卡頓,一怒之下自行開發(fā)了底層引腳操作函數(shù),開發(fā)了N個項目也沒發(fā)現(xiàn)有什么問題
頭文件在這里
  1. /*------------------------------
  2. [name]    Gpio.h
  3. [date]    2018.5.16 17:12
  4. [note]    Designed by TFD Studio
  5. ------------------------------*/
  6. #ifndef Gpio_h
  7. #define Gpio_h
  8. //---------------/* Headerfile */---------------//
  9. #include <Arduino.h>
  10. //---------------/* Debug */---------------//
  11.     /* Level */
  12. #define        HIGH    1
  13. #define        LOW        0
  14. #define        OUTPUT    1
  15. #define        INPUT    0
  16.     /* Analog pins */
  17. #define        A0   (54)
  18. #define        A1   (55)
  19. #define        A2   (56)
  20. #define        A3   (57)
  21. #define        A4   (58)
  22. #define        A5   (59)
  23. #define        A6   (60)
  24. #define        A7   (61)
  25. #define        A8   (62)
  26. #define        A9   (63)
  27. #define        A10  (64)
  28. #define        A11  (65)
  29. #define        A12  (66)
  30. #define        A13  (67)
  31. #define        A14  (68)
  32. #define        A15  (69)
  33.     /* PWM Defaults */
  34. #define        DEFAULT_PWM_FREQUENCY    50
  35. #define        DEFAULT_PWM_LEVEL        HIGH
  36. #define        DEFAULT_PWM_GRADE        100
  37. //---------------/* Class */---------------//
  38. class GPIO{
  39. private:
  40.         /* Normal */
  41.     uint8_t  _bit_;
  42.     volatile uint8_t* _mode_;
  43.     volatile uint8_t* _pin_;
  44.     volatile uint8_t* _port_;
  45.         /* SoftPWM */
  46.     unsigned int grade = DEFAULT_PWM_GRADE;
  47.     unsigned int dutycycle = 0;
  48.     unsigned int factor = 0;
  49.     unsigned int frequency = DEFAULT_PWM_FREQUENCY;
  50.     bool level = DEFAULT_PWM_LEVEL;
  51.     bool enable = false;
  52.     unsigned long int timemark, timecycle;
  53. public:
  54.     void setPin(unsigned char);
  55.         /* Normal */
  56.     void write(unsigned char);
  57.     void mode(unsigned char);
  58.     void high();
  59.     void low();
  60.     void input();
  61.     void output();
  62.     unsigned char read();
  63.         /* SoftPWM */
  64.     void pwmLevel(bool);
  65.     void pwmDuty(unsigned int);
  66.     void pwmGrade(unsigned int);
  67.     void pwmFreq(unsigned int);
  68.     void pwmStart();
  69.     void pwmStop();
  70.     bool pwmThread();
  71. };
  72. #endif
實(shí)現(xiàn)在這里
  2. [name]        Gpio.cpp
  6. #include "Gpio.h"
  7. //---------------/* Set */---------------//
  8. void GPIO::setPin(unsigned char _id)
  9. {
  10.         _bit_ = digitalPinToBitMask(_id);
  11.         _mode_ = portModeRegister(digitalPinToPort(_id));
  12.         _port_ = portOutputRegister(digitalPinToPort(_id));
  13.         _pin_ = portInputRegister(digitalPinToPort(_id));
  14. }
  15. //---------------/* Control */---------------//
  16. void GPIO::write( unsigned char _level)
  17. {
  18.         if (_level)
  19.                 *_port_ |= _bit_;
  20.         else
  21.                 *_port_ &= ~_bit_;
  22. }
  23. void GPIO::mode(unsigned char _mode)
  24. {
  25.         if (_mode)
  26.                 *_mode_ |= _bit_;
  27.         else
  28.                 *_mode_ &= ~_bit_;
  29. }
  30. void GPIO::high()
  31. {
  32.         *_port_ |= _bit_;
  33. }
  34. void GPIO::low()
  35. {
  36.         *_port_ &= ~_bit_;
  37. }
  38. void GPIO::input()
  39. {
  40.         *_mode_ &= ~_bit_;
  41. }
  42. void GPIO::output()
  43. {
  44.         *_mode_ |= _bit_;
  45. }
  46. unsigned char GPIO::read()
  47. {
  48.         if (*_pin_ & _bit_)
  49.                 return 1;
  50.         else
  51.                 return 0;
  52. }
  53. //---------------/* SoftPWM */---------------//
  54. void GPIO::pwmLevel(bool _level)
  55. {
  56.         level = _level;
  57. }
  58. void GPIO::pwmDuty(unsigned int _dutycycle)
  59. {
  60.         if (!level)
  61.                 dutycycle = grade - _dutycycle;
  62.         else
  63.                 dutycycle = _dutycycle;
  64. }
  65. void GPIO::pwmGrade(unsigned int _grade)
  66. {
  67.         grade = _grade;
  68. }
  69. void GPIO::pwmFreq(unsigned int _freq)
  70. {
  71.         frequency = _freq;
  72. }
  73. void GPIO::pwmStart()
  74. {
  75.         enable = true;
  76.         timecycle = 1000000 / (frequency * grade);
  77.         timemark = micros();
  78. }
  79. void GPIO::pwmStop()
  80. {
  81.         enable = false;
  82.         if (!level)
  83.                 *_port_ |= _bit_;
  84.         else
  85.                 *_port_ &= ~_bit_;
  86. }
  87. bool GPIO::pwmThread()
  88. {
  89.         if (enable && micros() - timemark >= timecycle)
  90.         {
  91.                 timemark += timecycle;
  92.                 factor++;
  93.                 if (factor > grade)
  94.                         factor = 1;
  95.                 if (factor <= dutycycle)
  96.                         *_port_ |= _bit_;
  97.                 else
  98.                         *_port_ &= ~_bit_;
  99.                 return true;
  100.         }
  101. }
admin + 50 共享資料的黑幣獎勵!
ID:137736 發(fā)表于 2018-12-15 15:12 | 顯示全部樓層
高!發(fā)現(xiàn)Arduino確實(shí)慢,部分代碼用c寫就好了。
