查看: 5135|回復(fù): 1
51單片機(jī)數(shù)碼管顯示時間
ID:438586 發(fā)表于 2018-12-12 21:12 | 顯示全部樓層 |閱讀模式
//S2鍵調(diào)整小時,S3鍵調(diào)整分鐘
#include <reg51.h>
#include <intrins.h>
unsigned char data dis_digit;
unsigned char key_s, key_v;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char data dis_buf[8];
unsigned char data dis_index;
unsigned char hour,min,sec;
unsigned char sec100;
sbit        K1 = P3^4;
sbit        K2 = P3^5;
sbit    dula=P2^6;
sbit    wela=P2^7;
bit scan_key();
void proc_key();
void inc_sec();
void inc_min();
void inc_hour();
//void display();
void delay(unsigned char ms);
void display1(unsigned char a1,unsigned char a2,unsigned char a3,unsigned char a4,unsigned char a5,unsigned char a6);
void main(void)
        P0 = 0xff;
        P2 = 0xff;
        TMOD = 0x11;                // 定時器0, 1工作模式1, 16位定時方式
        TH1 = 0xdc;
        TL1 = 0;
        TH0 = 0xFC;
        TL0 = 0x17;
        hour = 12;
        min = 00;
        sec = 00;
        sec100 = 0;
        dis_buf[0] = hour / 10;                // 時十位
        dis_buf[1] = hour % 10;                // 時個位
        dis_buf[3] = min / 10;                // 分十位
        dis_buf[4] = min % 10;                // 分個位
        dis_buf[6] = sec / 10;                // 秒十位
        dis_buf[7] = sec % 10;                // 秒個位
//        dis_buf[2] = 0xbf;                                                // 顯示"-"
//        dis_buf[5] = 0xbf;                                                // 顯示"-"
        dis_digit = 0xfe;
        dis_index = 0;
        TCON = 0x01;
        IE = 0x8a;                                // 使能timer0,1 中斷
        TR1 = 1;
        key_v = 0x03;
                if(scan_key())
                        delay(10);
                        if(scan_key())
                                key_v = key_s;
                                proc_key();
                display1(dis_buf[0],dis_buf[1],dis_buf[3],dis_buf[4],dis_buf[6],dis_buf[7]);
bit scan_key()
        key_s = 0x00;
        key_s |= K2;
        key_s <<= 1;
        key_s |= K1;
        return(key_s ^ key_v);
void proc_key()
        EA = 0;
        if((key_v & 0x01) == 0)                // K1
                inc_hour();
        else if((key_v & 0x02) == 0)        // K2
                min++;
                if(min > 59)
                        min = 0;
        EA = 1;
void timer0() interrupt 1
// 定時器0中斷服務(wù)程序, 用于數(shù)碼管的動態(tài)掃描
// dis_index --- 顯示索引, 用于標(biāo)識當(dāng)前顯示的數(shù)碼管和緩沖區(qū)的偏移量
// dis_digit --- 位選通值, 傳送到P2口用于選通當(dāng)前數(shù)碼管的數(shù)值, 如等于0xfe時,
//                                選通P2.0口數(shù)碼管
// dis_buf   --- 顯于緩沖區(qū)基地址
        TH0 = 0xFC;
        TL0 = 0x17;
        P2 = 0xff;                                                        // 先關(guān)閉所有數(shù)碼管
        P0 = dis_buf[dis_index];                        // 顯示代碼傳送到P0口
        P2 = dis_digit;                                                //
        dis_digit = _crol_(dis_digit,1);        // 位選通值左移, 下次中斷時選通下一位數(shù)碼管
        dis_index++;                                                //
        dis_index &= 0x07;                        // 8個數(shù)碼管全部掃描完一遍之后,再回到第一個開始下一次掃描
void timer1() interrupt 3
        TH1 = 0xdc;
        sec100++;
        if(sec100 >= 100)
                sec100 = 0;
                inc_sec();
void inc_sec()
        sec++;
        if(sec > 59)
                sec = 0;
                inc_min();
void inc_min()
        min++;
        if(min > 59)
                min = 0;
                inc_hour();
void inc_hour()
        hour++;
        if(hour > 23)
                hour = 0;
        if(hour > 9)
                dis_buf[0] = 0x00;                                        // 當(dāng)小時的十位為0時不顯示
// 延時子程序
        unsigned char i;
        while(ms--)
                for(i = 0; i < 120; i++);
void display1(unsigned char a1,unsigned char a2,unsigned char a3,unsigned char a4,unsigned char a5,unsigned char a6)                        //顯示程序
   dula=0;
   P0=table[a1];                //顯示百位
   dula=1;
   dula=0;
   wela=0;
   P0=0x7e;
   wela=1;
   wela=0;
   delay(1);
   dula=0;
   P0=table[a2];                //顯示十位
   dula=1;
   dula=0;
   wela=0;
   P0=0x7d;
   wela=1;
   wela=0;
   delay(1);
   P0=table[a3];                //顯示個位
   dula=1;
   dula=0;
   P0=0x7b;
   wela=1;
   wela=0;
   delay(1);
   P0=table[a4];                //顯示個位
   dula=1;
   dula=0;
   P0=0x77;
   wela=1;
   wela=0;
   delay(1);
   P0=table[a5];                //顯示個位
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(1);
   P0=table[a6];                //顯示個位
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(1);
ID:1 發(fā)表于 2018-12-14 01:23 | 顯示全部樓層
補(bǔ)全原理圖或者詳細(xì)說明一下電路連接即可獲得100+黑幣
