數(shù)字萬用表仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
2018-12-14 00:51 上傳
2018-12-14 00:51 上傳
注意OUT1~OUT8,最高位是OUT1,最低位是OUT8
單片機源程序如下:
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- //ADC0809相關(guān)引腳定義
- #define ADC_DATA P1
- sbit ADC_EOC = P3^3;
- sbit ADC_CLK = P3^4;
- sbit ADC_START = P3^6;
- sbit ADC_OE = P3^7;
- //4位共陽數(shù)碼管相關(guān)
- uchar code seg[10]={ 0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90 }; //0~9 小數(shù)點不亮
- uchar code seg_dot[10]={ 0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10 }; //0~9 小數(shù)點亮
- #define SEG_DATA P2 //數(shù)碼管段選碼,共陽數(shù)碼管,低電平選通段選碼
- sbit SEG_SEL_0 = P0^3; //數(shù)碼管位選:第0位,共陽數(shù)碼管,高電平選通位選碼
- sbit SEG_SEL_1 = P0^2; //數(shù)碼管位選:第1位
- sbit SEG_SEL_2 = P0^1; //數(shù)碼管位選:第2位
- sbit SEG_SEL_3 = P0^0; //數(shù)碼管位選:第3位
- //警報:LED與蜂鳴器引腳
- sbit LED = P0^5; //低電平亮
- sbit BEEP = P0^4; //高電平響
- #define LED_ON LED=0
- #define LED_OFF LED=1
- #define BEEP_ON BEEP=1
- #define BEEP_OFF BEEP = 0
- //粗略延時函數(shù) AT89C51 & 12MHz
- void delayms(unsigned int ms)
- unsigned char a,b,c;
- while(ms--)
- for(c=1;c>0;c--)
- for(b=142;b>0;b--)
- for(a=2;a>0;a--);
- //粗略延時函數(shù) STC12C5A60S2 & 12MHz
- while(ms--)
- for(c=1;c>0;c--)
- for(b=222;b>0;b--)
- for(a=12;a>0;a--);
- //定時器初始化,配置ADC0809時鐘
- void timer_init(void)
- //配置定時器0
- ET0 = 1;
- TMOD &= 0xF0;
- TMOD |= 0x02; //定時器0,模式2,自動重裝定時器
- TH0 = 200; //自動重裝值
- TL0 = 200;
- TR0 = 1;
- //配置定時器1
- ET1 = 1;
- TMOD &= 0x0F; //清除定時器1配置,不改動定時器0的配置
- TMOD |= 0x10; //定時器1模式一,不改動定時器0的模式
- TH1 = (65536 - 2000)/256;
- TL1 = (65536 - 2000)%256;
- TR1 = 1;
- EA = 1;
- //定時器0中斷,為ADC0809提供時鐘信號
- void timer0() interrupt 1
- ADC_CLK = ~ADC_CLK;
- //ADC0809 轉(zhuǎn)換函數(shù)
- uchar ADC0809_GET(void)
- ADC_START = 0;
- ADC_OE = 0;
- ADC_START = 1;
- ADC_START = 0;
- while(ADC_EOC == 0);
- ADC_OE = 1;
- return ADC_DATA;
- //定時器1中斷函數(shù),用于刷新數(shù)碼管
- uchar t1_flag = 0; //用于標(biāo)記顯示第幾位數(shù)碼管
- uchar seg0 = 0; //第0位數(shù)碼管的值
- uchar seg1 = 1; //第1位數(shù)碼管的值
- uchar seg2 = 2; //第2位數(shù)碼管的值
- uchar seg3 = 3; //第3位數(shù)碼管的值
- void timer1() interrupt 3
- SEG_SEL_0 = 0;
- SEG_SEL_1 = 0;
- SEG_SEL_2 = 0;
- SEG_SEL_3 = 0;
- SEG_DATA = 0xff;
- if(t1_flag == 0)
- SEG_SEL_0 = 1; //選通第0位數(shù)碼管
- SEG_SEL_1 = 0;
- SEG_SEL_2 = 0;
- SEG_SEL_3 = 0;
- SEG_DATA = seg_dot[seg0]; //顯示帶小數(shù)點的數(shù)
- else if(t1_flag == 1)
- SEG_DATA = seg[seg1];
- SEG_SEL_0 = 0;
- SEG_SEL_1 = 1; //選通第1位數(shù)碼管
- SEG_SEL_2 = 0;
- SEG_SEL_3 = 0;
- else if(t1_flag == 2)
- SEG_DATA = seg[seg2];
- SEG_SEL_0 = 0;
- SEG_SEL_1 = 0;
- SEG_SEL_2 = 1; //選通第2位數(shù)碼管
- SEG_SEL_3 = 0;
- else if(t1_flag == 3)
- SEG_DATA = seg[seg3];
- SEG_SEL_0 = 0;
- SEG_SEL_1 = 0;
- SEG_SEL_2 = 0;
- SEG_SEL_3 = 1; //選通第3位數(shù)碼管
- t1_flag++; //自加1
- t1_flag = t1_flag%4; //讓t1_flag 在0和3之間循環(huán)
- //顯示電壓值,輸入0~255,顯示0.000~5.000
- uint print_volt(uchar num)
- uint volt = 0;
- volt = num/255.0 * 5000 + 0.5; //除255.0和除255有很大區(qū)別,除255.0會自動轉(zhuǎn)換為float型,小數(shù)才能保持,而volt/255=0,+0.5四舍五入。
- seg0 = volt/1000%10;
- seg1 = volt/100%10;
- seg2 = volt/10%10;
- seg3 = volt%10;
- return volt;
- //主函數(shù)
- void main(void)
- uchar adc_num = 0; //ADC采集到的值
2018-12-14 00:52 上傳
ADC0809【2_顯示電壓值,過壓報警】.zip
(80.81 KB, 下載次數(shù): 118)
2018-12-13 15:04 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
