avr單片機(jī)源碼:
- #include <iom16v.h>
- #include <macros.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define LED1_ON() PORTA=0xFE
- #define LED2_ON() PORTA=0xF7
- #define LED3_ON() PORTA=0xBF
- #define LED4_ON() PORTA=0x7F
- uchar key_0=16;
- uint Fr[]= {0,262*8,294*8,330*8,349*8,392*8,440*8,
- 494*8,523*8,587*8,659*8,698*8,784*8,880*8,988*8 ,1046*8};
- uchar SEG_CODE[]=
- { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
- 0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E
- uint Tone_Delay_Table[] =
- { 64021,64103,64260,64400,64524,64580,64684,64777,
- 64820,64898,64968,65030,65058,65110,65157,65178};
- uchar spe1_Tone[] = { 3,5,5,3,2,1,2,3,5,3,
- 2,3,5,5,3,2,1,2,3,2,1,1,0xFF };
- uchar spe1_Time[] =
- { 2,1,1,2,1,1,1,2,1,1,1,2,1,1,2,1,1,1,2,1,1,1,0xFF };
- uchar spe2_Tone[] =
- { 1,3,3,3,3,5,4,2,5,3,7,6,5,5,7,4,4,3,6,7,2,1,0xFF };
- uchar spe2_Time[] =
- { 2,1,1,2,1,1,1,2,1,1,3,2,1,1,2,4,1,1,2,1,1,1,0xFF };
- uchar spe3_Tone[] = { 0,1,2,3,4,5,5,6,7,8,9,10,11,12,13,14,15,
- 15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0xFF};
- uchar spe3_Time[] =
- { 1,1,1,1,1,1,1,1,1,1,1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
- 1, 1, 1,1,1,1,1,1,1,1,1,1,0xFF};
- uchar spe4_Tone[] =
- { 1,2,3,1,1,2,3,1,3,4,5,3,4,5,5,6,5,4,3,1,5,6,
- 5,4,3,1,1,5,1,1,5,1,0xFF };
- uchar spe4_Time[] =
- { 2,1,1,1,2,1,1,1,2,1,1,2,1,1,3,0.5,0.25,0.5,0.25,1,1,
- 0.5,0.25,0.5,1,1,1,1,3,1,1,3,0xFF };
- uchar *spe_Tone_Ptr[]={
- spe1_Tone,spe2_Tone,spe3_Tone,spe4_Tone},
- *spe_Time_Ptr[]=
- {spe1_Time,spe2_Time,spe3_Time,spe4_Time};
- uint Tone_Idx = 0;
- uint i = 0,j=1,spe_Idx = 0;
- uint FALSE = 0, TRUE = 1, Pause = 1;
- void delay_1ms(void)
- uint i;
- for(i=1;i<(uint)(153*143-2);i++)
- void delay(unsigned int n)
- unsigned int i;
- for(i=0;i<n;i++)
- delay_1ms();
- uchar KeyMatrix_Down()
- DDRB=0XF0;
- PORTB=0X0F;
- delay(1);
- return PINB!=0x0f? 1:0;
- void Keys_Scan()
- switch(PINB)
- case 0B00001110: key_0=0; break;
- case 0B00001101: key_0=1; break;
- case 0B00001011: key_0=2; break;
- case 0B00000111: key_0=3; break;
- default:key_0=0xFF;
- DDRB=0x0F;
- PORTB=0xF0;
- delay(1);
- switch(PINB)
- case 0B11100000: key_0+=0; break;
- case 0B11010000: key_0+=4; break;
- case 0B10110000: key_0+=8; break;
- case 0B01110000: key_0+=12; break;
- default: key_0= 0xFF;
- int main()
- DDRB=0xFF;
- PORTB=0xFF;
- DDRA=0xFF;
- PORTA=0xFF;
- DDRC=0xFF;
- PORTC=0xBF;
- DDRD|=BIT(PD7);
- PORTD&=~BIT(PD7);
- DDRD=~(BIT(PD2)|BIT(PD3));
- PORTD=BIT(PD2)|BIT(PD3);
- MCUCR=0x82;
- GICR=BIT(INT0)|BIT(INT1);
- TCCR1A=0x00;
- TCCR1B=0x09;
- SREG=0x80;
- while(1)
- if(KeyMatrix_Down()==0)
- if(Pause)
- continue;
- TCCR1B=0x01;
- Tone_Idx=spe_Tone_Ptr[spe_Idx][i];
- if(Tone_Idx==0xFF)
- delay(200);
- i=0;
- continue;
- TIMSK=BIT(TOIE1);
- delay(spe_Time_Ptr[spe_Idx][Tone_Idx]*200/26);
- TIMSK=0x00;
- i++;
- else
- if(Pause==0)
- continue;
- if(key_0==0 || key_0>16);
- continue;
- PORTC=SEG_CODE[key_0];
- OCR1A=153/2/Fr[key_0];
- TCNT1=0;TIMSK|= BIT(OCIE1A);
- while(KeyMatrix_Down());
- TIMSK &=~BIT(OCIE1A);
- #pragma interrupt_handler timer1_ovf_isr:9
- void timer1_ovf_isr(void)
- if(Tone_Idx==0xFF)return;
- TCNT1=Tone_Delay_Table[Tone_Idx];
- PORTD^= BIT(PD7);
- #pragma interrupt_handler int0_isr:2
- void int0_isr(void)
- TIMSK=0x00;
- if(spe_Idx==3)spe_Idx=0;
- else spe_Idx++;
- i=0;
- switch(spe_Idx)
- case 0:LED1_ON();PORTC=SEG_CODE[1]; break;
- case 1:LED2_ON(); PORTC=SEG_CODE[2];break;
- case 2:LED3_ON(); PORTC=SEG_CODE[3];break;
- case 3:LED4_ON(); PORTC=SEG_CODE[4];break;
- delay(10);
- #pragma interrupt_handler int1_isr:3
- void int1_isr(void)
- Pause= !Pause;
- if(Pause)
- PORTC=0xFF;
- PORTA=0xFF;
- TIMSK=0x00;
- #pragma interrupt_handler timer1_compa_isr:7
- void timer1_compa_isr(void)
- PORTD^=BIT(PD7);
全部源碼附件中
定時(shí)與中斷做的電子琴.zip
(14.79 KB, 下載次數(shù): 52)
2018-12-13 18:22 上傳
點(diǎn)擊文件名下載附件
