以下代碼中如果我要改變播放的歌曲,該如何修改呢?或者如何添加歌曲進(jìn)去呢?看不懂啊求救
- #include <reg52.h> //調(diào)用單片機(jī)頭文件
- #define uchar unsigned char //無(wú)符號(hào)字符型宏定義 變量范圍0~255
- #define uint unsigned int //無(wú)符號(hào)整型 宏定義 變量范圍0~65535
- sbit beep = P2^5; //蜂鳴器定義
- sbit K1=P1^0;//給P1^0定義,控制DO的發(fā)音
- sbit K2=P1^1;//給P1^1定義,控制XI的發(fā)音
- sbit K3=P1^2;//給P1^2定義,控制LA的發(fā)音
- sbit K4=P1^3;//給P1^3定義,控制SO的發(fā)音
- sbit K5=P3^4;//給P3^4定義,控制FA的發(fā)音
- sbit K6=P3^5;//給P3^5定義,控制MI的發(fā)音
- sbit K7=P3^6;//給P3^6定義,控制RE的發(fā)音
- sbit K8=P3^7;//給P3^7定義,控制DO的發(fā)音
- sbit K9=P2^0;//音樂(lè)播放按鍵
- uchar flag_en = 0; //開(kāi)始放歌
- uchar flag_i = 0;
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar codesmg_du[]={0xde,0x90,0xcd,0xd9,0x93,0x5b,0x5f,0xd0,0xdf,0xdb
- // A B C D E F 不顯示
- }; //斷碼
- uchar m,n;
- uchar code T[49][2]={{0,0},
- {0xF8,0x8B},{0xF8,0xF2},{0xF9,0x5B},{0xF9,0xB7},{0xFA,0x14},{0xFA,0x66},{0xFA,0xB9},{0xFB,0x03},{0xFB,0x4A},{0xFB,0x8F},{0xFB,0xCF},{0xFC,0x0B},
- {0xFC,0x43},{0xFC,0x78},{0xFC,0xAB},{0xFC,0xDB},{0xFD,0x08},{0xFD,0x33},{0xFD,0x5B},{0xFD,0x81},{0xFD,0xA5},{0xFD,0xC7},{0xFD,0xE7},{0xFE,0x05},
- {0xFE,0x21},{0xFE,0x3C},{0xFE,0x55},{0xFE,0x6D},{0xFE,0x84},{0xFE,0x99},{0xFE,0xAD},{0xFE,0xC0},{0xFE,0x02},{0xFE,0xE3},{0xFE,0xF3},{0xFF,0x02},
- {0xFF,0x10},{0xFF,0x1D},{0xFF,0x2A},{0xFF,0x36},{0xFF,0x42},{0xFF,0x4C},{0xFF,0x56},{0xFF,0x60},{0xFF,0x69},{0xFF,0x71},{0xFF,0x79},{0xFF,0x81}
- uchar code music1[][2]={{0,4}, //青花瓷
- {0,4},{24,4},{24,4},{21,4},{19,4},{21,4},{14,8},{19,4},{21,4},{24,4},{21,4},{19,16},{0,4},{24,4},{24,4},{21,4},{19,4},{21,4},{12,8},{19,4},{21,4},{24,4},{19,4},{17,16},{0,4},{17,4},{19,4},{21,4},
- {24,4},{26,4},{24,4},{22,4},{24,4},{21,4},{21,4},{19,4},{19,16},{0,4},
- {17,4},{19,4},{17,4},{17,4},{19,4},{17,4},{19,4},{19,4},{21,8},{24,4},{21,4},{21,12},{0,4},{24,4},{24,4},{21,4},{19,4},{21,4},{14,8},{19,4},{21,4},{24,4},{21,4},{19,16},{0,4},{24,4},{24,4},{21,4},
- {19,4},{21,4},{12,8},{19,4},{21,4},{24,4},{19,4},{17,16},{0,4},{17,4},{19,4},{21,4},{24,4},{26,4},{24,4},{22,4},{24,4},{21,4},{21,4},{19,4},{19,12},{12,4},{21,8},{19,4},{19,8},{17,16},
- {0xFF,0xFF}};
- uchar code music2[][2]={{0,4}, //生日快樂(lè)
- {17,6},{17,2},{19,8},{17,8},{22,8},{21,16},
- {17,6},{17,2},{19,8},{17,8},{24,8},{22,16},{17,6},{17,2},{29,8},{26,8},{22,8},{21,8},{19,8},{27,6},{27,2},{26,8},{22,8},{24,8},{22,16},
- {0xFF,0xFF}};
- uchar code music3[][2]={{0,4}, //愛(ài)情買(mǎi)賣(mài)
- {22,4},{22,4},{17,4},{15,4},{15,4},{17,12},
- {15,4},{15,2},{17,2},{15,4},{13,4},{13,4},{15,12},{0,4},
- {20,4},{20,4},{20,4},{17,4},{20,4},{20,4},{20,4},{17,4},
- {22,4},{17,4},{17,4},{15,4},{15,4},{17,12},
- {20,4},{20,4},{20,2},{17,2},{17,4},{20,4},{20,4},{20,2},{17,2},{17,2},{17,2},
- {24,4},{20,4},{20,2},{17,2},{17,4},{20,4},{22,12},
- {17,4},{22,4},{25,4},{25,4},{17,4},{22,4},{25,8},
- {24,4},{22,2},{24,2},{22,4},{20,4},{15,4},{17,12},
- {15,4},{15,4},{15,4},{10,4},{15,4},{17,4},{20,8},
- {17,4},{24,4},{24,4},{20,4},{15,4},{17,12},
- {29,4},{27,2},{29,2},{27,4},{25,4},{25,4},{27,12},
- {29,4},{29,2},{27,4},{25,4},{27,6},{27,2},{25,4},{24,4},
- {20,4},{20,2},{17,2},{20,4},{20,2},{22,2},{22,16},
- {0xFF,0xFF}};
- void delay(uchar p)
- uchar i,j;
- for(;p>0;p--)
- for(i=181;i>0;i--)
- for(j=181;j>0;j--);
- void pause()
- uchar i,j;
- for(i=150;i>0;i--)
- for(j=150;j>0;j--);
- /***********************1ms延時(shí)函數(shù)*****************************/
- void delay_1ms(uint q)
- uinti,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /******************按鍵程序*************************/
- void key() //按鍵程序
- if(K1==0)
- delay_1ms(10); //按鍵去抖動(dòng)
- if(K1==0)
- P0=smg_du[0];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K1)
- m = 8;
- TR0 = 1; //打開(kāi)定時(shí)器
- }//使蜂鳴器發(fā)出相應(yīng)頻率的聲音;
- TR0= 0; //關(guān)閉定時(shí)器
- if(K2==0)
- if(K2==0)
- P0=smg_du[1];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K2)
- m = 9;
- if(K3==0)
- if(K3==0)
- P0=smg_du[2];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K3)
- m = 10;
- if(K4==0)
- if(K4==0)
- P0=smg_du[3];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K4)
- m = 11;
- if(K5==0)
- if(K5==0)
- P0=smg_du[4];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K5)
- m = 12;
- if(K6==0)
- if(K6==0)
- P0=smg_du[5];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K6)
- m = 13;
- if(K7==0)
- if(K7==0)
- P0=smg_du[6];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K7)
- m = 14;
- if(K8==0)
- if(K8==0)
- P0=smg_du[7];//使數(shù)碼管顯示該音調(diào)的字符
- while(!K8)
- m = 15;
- P0= 0x20;
- K9= 1;
- if(K9==0)
- if(K9==0)
- flag_en++;
- flag_i= 0;
- if(flag_en> 3)
- flag_en = 0;
- TR0 = 0;
- while(!K9)
- /******************主程序**********************/
- void main()
- P0= P1 = P2 = P3 = 0xff;
- TMOD=0x01; EA=1; ET0=1; //定時(shí)器0初始化
- while(1)
- key(); //按鍵程序
- if(flag_en == 1) //青花瓷
- m=music1[flag_i][0];n=music1[flag_i][1]; //放歌
- P0= smg_du[m % 8]; //顯示
- if(m==0x00)
- TR0=0;
- beep = 1;
- delay(n);
- flag_i++;
- elseif(m==0xFF) //放歌結(jié)束
- TR0=0;beep = 1;delay(30);flag_i=0;flag_en= 0;}
- elseif(m==music1[flag_i+1][0])
- {TR0=1;delay(n);TR0=0;beep =1;pause();flag_i++; }
- else
- {TR0=1;delay(n);flag_i++;}
- else
- beep= 1 ;
- if(flag_en == 2) //生日歌
- m=music2[flag_i][0];n=music2[flag_i][1]; //放歌
- if(m==0x00)
- TR0=0;
- beep = 1;
- delay(n);
- flag_i++;
- elseif(m==music2[flag_i+1][0])
- else
- else
- beep= 1 ;
- if(flag_en == 3) //愛(ài)情買(mǎi)賣(mài)
- m=music3[flag_i][0];n=music3[flag_i][1]; //放歌
- if(m==0x00)
- TR0=0;
- beep = 1;
- delay(n);
- flag_i++;
- elseif(m==music3[flag_i+1][0])
- else
- else
- beep= 1 ;
復(fù)制代碼 |
