查看: 4444|回復(fù): 1
avr單片機(jī)帶小數(shù)點(diǎn)數(shù)碼管的程式
ID:21069 發(fā)表于 2018-12-15 14:33 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
//------------2_8數(shù)碼管鍵調(diào)時(shí)帶小數(shù)點(diǎn)功能
#include<iom128v.h>
#define uint  unsigned int
#define P0_1  PORTA |= (1<<0)
#define P0_0  PORTA &=~ (1<<0)
#define P1_1  PORTA |= (1<<1)
#define P1_0  PORTA &=~ (1<<1)
#define P2_1  PORTA |= (1<<2)
#define P2_0  PORTA &=~ (1<<2)
#define P3_1  PORTA |= (1<<3)
#define P3_0  PORTA &=~ (1<<3)
#define P4_1  PORTA |= (1<<4)
#define P4_0  PORTA &=~ (1<<4)
#define P5_1  PORTA |= (1<<5)
#define P5_0  PORTA &=~ (1<<5)
#define P6_1  PORTA |= (1<<6)
#define P6_0  PORTA &=~ (1<<6)
#define P7_1  PORTA |= (1<<7)
#define P7_0  PORTA &=~ (1<<7)
uchar i,m,h;
uint j;
uchar led_discode[]={0xc0,0xf9,0xa4,0xb0,0x99,
0x92,0x82,0xf8,0x80,0x90,0xbf,0xef,};     //共陽數(shù)碼管數(shù)字碼
void delay(uint mS)        //微秒
                uchar x,y;
                for(x=0;x<mS;x++)
                        for(y=0;y<10;y++);
void init(void)   //初始化PORUT口
        DDRA=0XFF;             //LED IO口設(shè)為輸出
        PORTA=0X00;
        DDRB |=0X10;           //PB4設(shè)為輸出
        PORTB|=0X10;           //關(guān)閉PB4外接的LED
        DDRC=0XFF;             //數(shù)碼管段選設(shè)為輸出
        PORTC=0X00;
        DDRF |=0X03;           //LED及數(shù)碼管鎖存IO口設(shè)為輸出
        PORTF|=0X0E;
        PORTF&=0xF7;           //鎖存數(shù)據(jù)關(guān)閉數(shù)碼管
        DDRD=0;//全部設(shè)為輸入
        PORTD=0xff;//全部上拉
        PIND=0xff;//設(shè)初始值
void playh(uchar h)
    PORTC = led_discode[h/10] ;
        P0_1;
        delay(1);
        P0_0;
        PORTC =tablee[h%10];
        P1_1;
        delay(1);
        P1_0;
    PORTC = led_discode[10] ;
        P2_1;
        delay(1);
        P2_0;
void key1(void)
        if(PIND == 0xfe)  //按鍵掃描函數(shù)----------加鍵
                delay(5);
                if(PIND == 0xfe)
                        while(PIND == 0xfe);
                m++;
        void key2(void)
        if(PIND == 0xfd)  //按鍵掃描函數(shù)----------減鍵
                delay(5);
                if(PIND == 0xfd)
                        while(PIND == 0xfd)        play(i);
        h++;
void main (viod)
        init() ;
                key1();
                key2();
                j=300;
                while(j--)
                        play(i); //顯示函數(shù)
                i++;
                if(i==60)
                        i=0;    //如果秒計(jì)滿60,將秒計(jì)數(shù)變量清0
                        m++;    //分鐘計(jì)數(shù)變量加1
                if(m == 60)
                        m=0;    //如果分鐘計(jì)滿60,將分鐘計(jì)數(shù)變量清0
                        h++;      //小時(shí)計(jì)數(shù)變量加1
                if(h == 24)
                        h=0;    //如果小時(shí)計(jì)滿24,將小時(shí)計(jì)數(shù)變量清0
完全代碼與仿真文件附件中
帶點(diǎn)數(shù)碼管.zip (25.14 KB, 下載次數(shù): 15)
參與人數(shù) 2黑幣 +65 收起 理由
shuisheng + 15
ID:279771 發(fā)表于 2020-12-4 04:11 | 只看該作者
代碼不對(duì)吧,不全
