查看: 4619|回復(fù): 2
基于Arduino的8號(hào)球設(shè)計(jì)(Proteus仿真+代碼)
ID:218023 發(fā)表于 2018-12-15 20:16 | 顯示全部樓層 |閱讀模式
The With Commands - Electronics & Minecraft Name
源程序:
  1. #include <LiquidCrystal.h>
  2. typedef unsigned char uchar;
  3. LiquidCrystal lcd(2,3,4,5,6,7);
  4. #define Backlight 8
  5. #define Button 9
  6. const uchar button_char[]={
  7. B11000,
  8. B11010,
  9. B11011,
  10. B00011,
  11. B11011,
  12. B11010,
  13. B11000,
  14. B00000
  15. };
  16. void setup()
  17. {
  18.   pinMode(Backlight,OUTPUT);
  19.   pinMode(Button,INPUT_PULLUP);
  20.   lcd.begin(16,2);
  21.   lcd.createChar(0,button_char);
  22.   digitalWrite(Backlight,HIGH);
  23. }
  24. void backlightbool()
  25. {
  26.   for(uchar i=0;i<=3;i++){
  27.     for(uchar j=0;j<=1;j++){
  28.       digitalWrite(Backlight,j);
  29.       delay(200);
  30.     }
  31.   }
  32. }
  33. void loop()
  34. {
  35.   uchar i=random()%9;
  36.   lcd.setCursor(0,0);
  37.   lcd.print("Ask question");
  38.   lcd.setCursor(0,1);
  39.   lcd.print("then press ");
  40.   lcd.write(uchar(0));
  41.   while(digitalRead(Button));
  42.   backlightbool();
  43.   lcd.clear();
  44.   if(i==0){
  45.     lcd.print("Very nice");
  46.   }
  47.   if(i==1){
  48.     lcd.print("Good");
  49.   }
  50.   if(i==2){
  51.     lcd.print("Better");
  52.   }
  53.   if(i==3){
  54.     lcd.print("Commonly");
  55.   }
  56.   if(i==4){
  57.     lcd.print("Not good");
  58.   }
  59.   if(i==5){
  60.     lcd.print("Very bad");
  61.   }
  62.   if(i==6){
  63.     lcd.print("You trash,");
  64.     lcd.setCursor(0,1);
  65.     lcd.print("get out of here.");
  66.   }
  67.   if(i==7){
  68.     lcd.print("I'm angry!");
  69.   }
  70.   if(i==8){
  71.     lcd.print("I'm very angry!");
  72.   }
  73.   while(digitalRead(Button));
  74.   while(!digitalRead(Button));
  75. }
全部資料51hei下載地址:
8ball.zip (26 KB, 下載次數(shù): 19)
ID:149451 發(fā)表于 2019-1-25 14:11 | 顯示全部樓層
樓主這是哪個(gè)版本的proteus仿真軟件?我的怎打不開?
ID:218023 發(fā)表于 2019-2-9 15:18 | 顯示全部樓層
w1179benp 發(fā)表于 2019-1-25 14:11
Proteus 8.7
