查看: 3501|回復(fù): 0
51單片機(jī)MODBUS框架程序
ID:145411 發(fā)表于 2018-12-16 00:07 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
新鮮出爐的MODBUS框架程序,有不足的地方望大家指出
  1. #include <all.h>
  2. unsigned char xdata Modbus_Read_Buffer[256] = 0;  //數(shù)據(jù)接收緩沖區(qū)
  3. unsigned char xdata Modbus_Write_Buffer[256] = 0; //數(shù)據(jù)發(fā)送緩沖區(qū)
  4. unsigned int Modbus_Read_Value = 0;        //接收字節(jié)計(jì)數(shù)
  5. unsigned int Modbus_Write_Value = 0;  //發(fā)送字節(jié)計(jì)數(shù)
  6. unsigned char Modbus_Read_Complete = 0; //幀接收完成標(biāo)志位
  7. unsigned int Modbus_CRC_Cecode(unsigned char *puchMsg, unsigned int usDataLen);        //CRC校驗(yàn)
  8. void Modbus_Init();        //幀檢測(cè)定時(shí)器
  9. void Modbus_data_Decode();
  10. void Modbus_Init()//利用定時(shí)器2來(lái)計(jì)算數(shù)據(jù)幀 定時(shí)1MS
  11. {
  12.         AUXR |= 0x04;//定時(shí)器2用作定時(shí),不分頻
  13.         IE2 |= 0x04;//允許定時(shí)器2中斷
  14.         T2L = 0xCD;                //設(shè)置定時(shí)初值
  15.         T2H = 0xD4;                //設(shè)置定時(shí)初值
  16.         EA = 1;  //開(kāi)總中斷
  17.         AUXR |= 0x10;
  18. }
  19. unsigned int Modbus_CRC_Cecode(unsigned char *puchMsg, unsigned int usDataLen)
  20. {
  21.
  22.          unsigned int i,j,CRC_Reg,Check;
  23.          CRC_Reg = 0xFFFF;
  24.          for(i=0;i<usDataLen;i++)
  25.          {
  26.                 CRC_Reg = CRC_Reg ^ (unsigned int)*(puchMsg + i);
  27.                 for(j=0;j<8;j++)
  28.                 {
  29.                         Check = CRC_Reg & 0x0001;
  30.                         CRC_Reg >>= 1;
  31.                         if(Check==0x0001)
  32.                         {
  33.                                 CRC_Reg ^= 0xA001;
  34.                         }
  35.                 }
  36.          }
  37.
  38.          return CRC_Reg;
  39. }
  40. void Modbus_data_Decode()
  41. {
  42.          unsigned int CRC_Data,i;
  43.          unsigned char CRC_H, CRC_L;
  44.
  45.         if(Modbus_Read_Complete)
  46.         {
  47.                  EA = 0;
  48.                  Modbus_Read_Complete = 0;
  49.                  CRC_Data = Modbus_CRC_Cecode(Modbus_Read_Buffer,Modbus_Read_Value-2);
  50.
  51.                  CRC_H = CRC_Data >> 8;
  52.                  CRC_L = CRC_Data & 0x00ff;
  53.
  54.                  if((CRC_H == Modbus_Read_Buffer[Modbus_Read_Value-1]) && (CRC_L == Modbus_Read_Buffer[Modbus_Read_Value-2]))
  55.                  {
  56.                          //這里可以開(kāi)始分析數(shù)據(jù) 程序進(jìn)入這里就證明CRC檢驗(yàn)已經(jīng)通過(guò)了
  57.                         Modbus_Write_Value = 0; //清除發(fā)送直接計(jì)數(shù) ,調(diào)試用
  58.                          for(i = 0; i < (Modbus_Read_Value-2); i++)         //調(diào)試用主要把接收的數(shù)據(jù)發(fā)送出去
  59.                         {
  60.                                 Modbus_Write_Buffer[i] = Modbus_Read_Buffer[i];         //調(diào)試用
  61.                                 Modbus_Write_Value++;                                                    //調(diào)試用
  62.                         }
  63.                  }
  64.                  Modbus_Write_Buffer[Modbus_Write_Value] = CRC_L;          //調(diào)試用
  65.                  Modbus_Write_Value++;        //調(diào)試用
  66.                  Modbus_Write_Buffer[Modbus_Write_Value] = CRC_H;           //調(diào)試用
  67.                  Modbus_Read_Value = 0;                //接收直接數(shù)清零
  68.
  69.                  EA = 1;
  70.                  for(i = 0; i <= Modbus_Write_Value; i++)                 //調(diào)試用
  71.                  {
  72.                          SBUF = Modbus_Write_Buffer[i];                          //調(diào)試用
  73.                         while(!TI);        //調(diào)試用
  74.                  }
  75.                  Modbus_Write_Value = 0;                                          //調(diào)試用
  76.
  77.          }
  78. }
  79. /* 串口接收監(jiān)控,由空閑時(shí)間判定幀結(jié)束,需在定時(shí)中斷中調(diào)用,ms-定時(shí)間隔 */
  80. void UartRxMonitor(unsigned char ms)
  81. {
  82.     static unsigned char cntbkp = 0;
  83.     static unsigned char idletmr = 0;
  84.     if (Modbus_Read_Value > 0)  //接收計(jì)數(shù)器大于零時(shí),監(jiān)控總線空閑時(shí)間
  85.     {
  86.         if (cntbkp != Modbus_Read_Value)  //接收計(jì)數(shù)器改變,即剛接收到數(shù)據(jù)時(shí),清零空閑計(jì)時(shí)
  87.         {
  88.             cntbkp = Modbus_Read_Value;
  89.             idletmr = 0;
  90.         }
  91.         else                   //接收計(jì)數(shù)器未改變,即總線空閑時(shí),累積空閑時(shí)間
  92.         {
  93.             if (idletmr < 2)  //空閑計(jì)時(shí)小于30ms時(shí),持續(xù)累加
  94.             {
  95.                 idletmr += ms;
  96.                 if (idletmr >= 2)  //空閑時(shí)間達(dá)到2ms時(shí),即判定為一幀接收完畢
  97.                 {
  98.                                         Modbus_Read_Complete = 1;  //設(shè)置幀接收完成標(biāo)志
  99.                 }
  100.             }
  101.         }
  102.     }
  103.     else
  104.     {
  105.         cntbkp = 0;
  106.     }
  107. }
  108. void Timer2_Routine() interrupt 12
  109. {
  110.         UartRxMonitor(1);
  111.
  112. }
MODBUS調(diào)試.zip (44.77 KB, 下載次數(shù): 83)
