2018-12-17 02:38 上傳
#include <at89x51.h>
#include <intrins.h>
#define lcm P1
sbit p_csl=P2^4;
sbit p_csr=P2^3;
sbit p_di=P2^2;
sbit p_rw=P2^1;
sbit p_e=P2^0;
sbit p_rst=P2^7;
uchar code HZ[];
uchar code Ez[];
void delay(uint k);
void wcode(uchar c,uchar csl,uchar csr);
void wdata(uchar c,uchar csl,uchar csr);
void set_statrline(uchar i);
void set_xy(uchar x,uchar y);
void dison_off(uchar o);
void reset();
void lcd_init(void);
void lw(uchar x,uchar y,uchar dd);//寫數(shù)據(jù)函數(shù)
void disp_Hz(uchar xx,uchar yy,uchar n,uchar fb);//顯示漢字
void disp_Ez(uchar xx,uchar yy,uchar n,uchar fb);
//延時
void delay(uint k)
{ uint i;
for(;k>0;k--)
{ for(i=0;i<500;i++)
//LCM忙判斷
void lcd_busy(void)
{ p_di=0;
p_rw=1;
//寫指令到LCM
{ p_csl=csl;
p_csr=csr;
lcd_busy();
p_di=0;
p_rw=0;
lcm=c;//將變量C賦予LCM
p_e=1;
p_e=0;
//寫數(shù)據(jù)到LCM子函數(shù)
{ p_csl=csl;
p_csr=csr;
lcd_busy();
p_di=1;
p_rw=0;
lcm=c;//將變量C賦予LCM
p_e=1;
p_e=0;
//設(shè)定起始行
void set_startline(uchar i)
{ i=0xc0+i;
wcode(i,1,1);
//定位X方向,Y方向
{ x=x+0x40;
y=y+0xb8;
wcode(x,1,1);
wcode(y,1,1);
//屏幕開啟、關(guān)閉
{ o=o+0x3e; //o為1為開,為0是關(guān)
wcode(o,1,1);
//復(fù)位子函數(shù)
void reset()
{//delay(1000);
p_rst=0;
delay(20);
p_rst=1;
delay(20);
//LCM初始化
void lcd_init(void)
{ uchar x,y;
reset();
dison_off(0);
for(y=0;y<8;y++)
{ for(x=0;x<128;x++)
lw(x,y,0);
dison_off(1);
set_startline(0);
//寫數(shù)據(jù)到LCM
{ if(x>=64)
{ set_xy(x-64,y);
wdata(dd,0,1);
{ set_xy(x,y);
wdata(dd,1,0);
//顯示漢字子函數(shù)
void disp_Hz(uchar xx,uchar yy,uchar n,uchar fb)//xx為該行第xx個字,共8字,yy為第幾行,共8行。
{ uchar i,dx;
for(i=0;i<16;i++)
{ dx=HZ[2*i+n*32]; //2*i為選擇偶數(shù)行,因其為列掃描
if(fb)
dx=255-dx;//反白顯示
lw(xx*16+i,yy,dx);
dx=HZ[(2*i+1)+n*32];
if(fb)
dx=255-dx;
lw(xx*16+i,yy+1,dx);
uchar code HZ[]=
{0x40,0x40,0x40,0x40,0x20,0x42,0x20,0x42,0x50,0x4A,0x48,0x72,0x44,0x42,0xC3,0x7F,
0x44,0x42,0x48,0x62,0x50,0x5A,0x50,0x42,0x20,0x42,0x60,0x40,0x20,0x40,0x00,0x00,/*"金",0*/
0x00,0x00,0xFE,0xFF,0x22,0x02,0x5A,0x04,0x86,0x43,0x10,0x48,0x94,0x24,0x74,0x22,
0x94,0x15,0x1F,0x09,0x34,0x15,0x54,0x23,0x94,0x60,0x94,0xC0,0x10,0x40,0x00,0x00,/*"陵",1*/
0x04,0x00,0x64,0x00,0x24,0x81,0x24,0x41,0x24,0x21,0x2F,0x19,0xE4,0x07,0x24,0x01,
0x24,0x01,0x24,0x41,0x2F,0x81,0x24,0x7F,0x24,0x00,0x64,0x00,0x24,0x00,0x00,0x00,/*"勞",2*/
0x24,0x01,0x24,0x41,0x2F,0x81,0x24,0x7F,0x24,0x00,0x64,0x00,0x24,0x00,0x00,0x00,/*"勞",3*/
0x40,0x40,0x41,0x20,0xC6,0x1F,0x00,0x20,0x40,0x40,0x48,0x48,0x49,0x44,0x4E,0x43,
0xF8,0x40,0x4C,0x41,0x4B,0x42,0x48,0x4C,0x48,0x40,0x40,0x40,0x00,0x40,0x00,0x00,/*"送",4*/
0x00,0x08,0x18,0x08,0x04,0x05,0x84,0x04,0x44,0xFC,0x7C,0x46,0xA5,0x46,0x26,0x45,
0x24,0x45,0xA4,0x46,0x64,0x46,0x24,0xFE,0x14,0x04,0x0C,0x0C,0x04,0x04,0x00,0x00,/*"客",5*/
0x00,0x00,0x40,0x40,0x30,0x48,0x12,0x48,0xDC,0x4B,0x54,0x4A,0x50,0x4A,0x5F,0x7E,
0x50,0x4A,0x50,0x4A,0xD8,0x4B,0x16,0x48,0x54,0x48,0x38,0x48,0x10,0x40,0x00,0x00,/*"堂",6*/
0x00,0x00,0x00,0x00,0x00,0x58,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",7*/
0x02,0x80,0x02,0x80,0x82,0x83,0xBA,0x42,0xAA,0x4A,0xAF,0x5B,0xAA,0x2A,0xBA,0x2A,
0xAA,0x2A,0xAF,0x5B,0xAA,0x4A,0xBA,0x42,0x82,0x83,0x02,0x80,0x00,0x80,0x00,0x00,/*"蔓",8*/
0x04,0x08,0x04,0x08,0x04,0x08,0xE4,0x0B,0xA4,0x0A,0xBF,0x0A,0xA4,0x0A,0xA4,0xFE,
0xA4,0x0A,0xBF,0x0A,0xA4,0x0A,0xE4,0x0B,0x04,0x08,0x04,0x08,0x04,0x08,0x00,0x00,/*"草",9*/
0x00,0x00,0x04,0x00,0x04,0xFE,0xF4,0x02,0x84,0x1A,0xCC,0x16,0xAD,0x12,0x96,0x13,
0x94,0x12,0xAC,0x16,0xCC,0x1A,0x84,0x72,0xF4,0x82,0x06,0x7E,0x04,0x00,0x00,0x00,/*"離",10*/
0x94,0x12,0xAC,0x16,0xCC,0x1A,0x84,0x72,0xF4,0x82,0x06,0x7E,0x04,0x00,0x00,0x00,/*"離",11*/
0x00,0x01,0x80,0x40,0x60,0x40,0x1E,0x41,0x10,0x41,0x10,0x41,0x10,0x41,0x10,0x41,
0xFF,0x7F,0x12,0x41,0x10,0x41,0x10,0x41,0x98,0x41,0x10,0x61,0x00,0x40,0x00,0x00,/*"生",12*/
0x40,0x40,0x42,0x20,0xCC,0x1F,0x00,0x20,0x04,0x40,0x04,0x40,0xE5,0x5F,0xB6,0x4A,
0xAC,0x4A,0xA4,0x4A,0xA6,0x4A,0xE5,0x5F,0x04,0x40,0x04,0x40,0x00,0x40,0x00,0x00,/*"道",13*/
0x40,0x00,0x20,0x00,0xF8,0x7F,0x07,0x00,0x82,0x00,0x64,0x41,0x2C,0x31,0x34,0x0F,
0x65,0x05,0xA6,0x05,0x34,0x25,0x2C,0x45,0xA4,0x3D,0x74,0x01,0x20,0x00,0x00,0x00,/*"傍",14*/
0x00,0x00,0x00,0x18,0x00,0x24,0x00,0x24,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"。",15*/
0x08,0x00,0x08,0x00,0x08,0x00,0x08,0x7F,0x08,0x21,0x08,0x21,0x08,0x21,0xFF,0x21,
0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x7F,0x08,0x00,0x08,0x00,0x08,0x00,0x00,0x00,/*"古",16*/
0x70,0x00,0x00,0x00,0xFF,0xFF,0x08,0x00,0x50,0x00,0x44,0x00,0x54,0xFF,0x54,0x15,
0x54,0x15,0x7F,0x15,0x54,0x55,0x54,0x95,0x54,0x7F,0x44,0x00,0x40,0x00,0x00,0x00,/*"情",17*/
0x00,0x00,0x02,0x08,0x02,0x04,0x02,0x02,0x02,0x01,0x82,0x00,0x42,0x00,0xFE,0x7F,
0x06,0x00,0x42,0x00,0xC2,0x00,0x82,0x01,0x02,0x07,0x03,0x02,0x02,0x00,0x00,0x00,/*"不",18*/
0x00,0x08,0x00,0x04,0x00,0x03,0xFE,0x00,0x12,0x00,0x12,0x09,0x12,0x11,0x12,0x32,
0x72,0x66,0x92,0x00,0x12,0x01,0x12,0x02,0x1E,0x06,0x00,0x0C,0x00,0x04,0x00,0x00,/*"盡",19*/
0x00,0x00,0x04,0x00,0x04,0x20,0xC4,0x18,0xB4,0x0E,0x8C,0x04,0x87,0x20,0x84,0x40,
0xF4,0xFF,0x84,0x00,0x84,0x02,0x84,0x04,0x84,0x18,0x04,0x30,0x00,0x00,0x00,0x00,/*"東",20*/
0x10,0x04,0x60,0x04,0x01,0xFC,0x86,0x03,0x60,0x40,0x04,0x30,0x44,0x0F,0x64,0x00,
0x55,0x00,0x4E,0x7F,0x44,0x00,0x64,0x3F,0xC4,0x40,0x04,0x40,0x04,0x70,0x00,0x00,/*"流",21*/
0x00,0x10,0x10,0x10,0x10,0x08,0x10,0x06,0x90,0x01,0x70,0x40,0x00,0x80,0xFF,0x7F,
0x20,0x00,0x60,0x00,0x90,0x01,0x08,0x06,0x04,0x0C,0x00,0x18,0x00,0x08,0x00,0x00,/*"水",22*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",23*/
0x00,0x20,0x00,0x20,0xF0,0x3F,0x00,0x10,0x00,0x10,0xFF,0x0F,0x20,0x08,0x20,0x08,
0x00,0x00,0xFF,0x3F,0x40,0x40,0x20,0x40,0x20,0x40,0x10,0x40,0x10,0x78,0x00,0x00,/*"此",24*/
0x10,0x20,0x10,0x20,0x10,0x10,0xFE,0x1F,0x10,0x08,0x50,0x08,0x40,0x00,0xFE,0x3F,
0x20,0x40,0x20,0x40,0xFF,0x4F,0x10,0x42,0x10,0x44,0xF8,0x43,0x10,0x70,0x00,0x00,/*"地",25*/
0x00,0x00,0x44,0x20,0x54,0x38,0x54,0x00,0x54,0x3C,0xFF,0x41,0x00,0x40,0x00,0x42,
0x00,0x4C,0xFF,0x41,0x54,0x40,0x54,0x70,0x54,0x00,0x44,0x08,0x40,0x30,0x00,0x00,/*"悲",26*/
0x00,0x40,0x00,0x20,0x00,0x18,0xFE,0x07,0x02,0x10,0x12,0x08,0x22,0x04,0x42,0x02,
0x82,0x01,0x7A,0x06,0x12,0x1C,0x02,0x00,0xFE,0x0F,0x00,0x30,0x00,0x7C,0x00,0x00,/*"風(fēng)",27*/
0x10,0x00,0x12,0x41,0xD2,0x30,0x32,0x00,0xFF,0x3B,0x31,0x40,0x51,0x42,0x10,0x4A,
0x08,0x51,0x90,0x40,0x7F,0x40,0x90,0x60,0x08,0x09,0x0C,0x33,0x00,0x01,0x00,0x00,/*"愁",28*/
0x00,0x00,0x00,0x00,0xF8,0x7F,0x08,0x21,0x08,0x21,0x0C,0x21,0x0B,0x21,0x08,0x21,
0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0xF8,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,/*"白",29*/
0x08,0x04,0x08,0x03,0xC8,0x00,0xFF,0xFF,0x48,0x00,0x88,0x01,0x0A,0x08,0x42,0x24,
0x62,0x13,0xD2,0x08,0x4A,0x06,0xC6,0x41,0x42,0x80,0xC0,0x7F,0x00,0x00,0x00,0x00,/*"楊",30*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"。",31*/
0x20,0x04,0x20,0x04,0x22,0x42,0x22,0x82,0xFE,0x7F,0x21,0x01,0x21,0x01,0x20,0x10,
0x20,0x10,0xFF,0x08,0x20,0x07,0x22,0x1A,0xAC,0x21,0x20,0x40,0x20,0xF0,0x00,0x00,/*"我",32*/
0x08,0x22,0x28,0x22,0x2A,0x11,0x2A,0x11,0xFA,0x0B,0x0A,0x0C,0x0A,0x06,0xFE,0x7F,
0x0A,0x02,0x09,0x04,0xF9,0x0D,0x49,0x19,0x29,0x31,0x2C,0x11,0x88,0x01,0x00,0x00,/*"乘",33*/
0x20,0x00,0x22,0x40,0x2A,0x44,0x2A,0x25,0x2A,0x15,0xAA,0x47,0x6A,0x85,0x3F,0x7D,
0x2A,0x05,0xAA,0x04,0x2A,0x14,0x2A,0x26,0x2A,0x4C,0x22,0x00,0x20,0x00,0x00,0x00,/*"素",34*/
0x40,0x80,0x40,0x60,0xFC,0x1F,0x56,0x01,0x65,0x46,0x44,0x80,0xFC,0x7F,0x00,0x00,
0xE4,0x07,0x24,0x02,0x24,0x02,0xE4,0x47,0x04,0x80,0xFC,0x7F,0x04,0x00,0x00,0x00,/*"舸",35*/
0x00,0x00,0xFE,0xFF,0x02,0x00,0x12,0x00,0x92,0x1F,0x92,0x08,0x92,0x08,0x92,0x08,
0x92,0x08,0x92,0x08,0x92,0x1F,0x12,0x40,0x02,0x80,0xFE,0x7F,0x00,0x00,0x00,0x00,/*"同",36*/
0x00,0x80,0x00,0x60,0xFC,0x1F,0x44,0x20,0x54,0x63,0x54,0x15,0x54,0x49,0x55,0x81,
0xFE,0x7F,0x54,0x0D,0x54,0x11,0x54,0x29,0xF4,0x6D,0x44,0xC0,0x44,0x40,0x00,0x00,/*"康",37*/
0x00,0x00,0x00,0x20,0x40,0x18,0xFC,0x0C,0x44,0x07,0x44,0x12,0x44,0x20,0x46,0x40,
0xFA,0x3F,0x42,0x00,0x43,0x00,0x43,0x02,0x42,0x0C,0x40,0x38,0x00,0x10,0x00,0x00,/*"樂",38*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",39*/
0x00,0x00,0xFC,0x3F,0x94,0x10,0x95,0x08,0x96,0x06,0x94,0x4C,0xFC,0x40,0x00,0x20,
0x00,0x18,0xFE,0x07,0x22,0x01,0x22,0x21,0x22,0x41,0xFE,0x3F,0x00,0x00,0x00,0x00,/*"朗",40*/
0xFC,0x07,0x04,0x02,0x04,0x02,0xFC,0x07,0x00,0x20,0x40,0x18,0x48,0x06,0xC9,0x41,
0x09,0x80,0xFA,0x7F,0x00,0x01,0x80,0x02,0x70,0x0C,0x20,0x18,0x00,0x08,0x00,0x00,/*"詠",41*/
0x10,0x04,0x61,0x04,0x06,0xFF,0xE0,0x00,0x18,0x00,0x20,0x00,0xAA,0xFF,0xAA,0x0A,
0xAA,0x0A,0xBF,0x0A,0xAA,0x4A,0xAA,0x8A,0xAA,0x7F,0x2A,0x00,0x00,0x00,0x00,0x00,/*"清",42*/
0x00,0x00,0x00,0x80,0x00,0x60,0xFF,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0xFE,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x7F,0x00,0x00,0x00,0x00,/*"川",43*/
0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,
0x02,0x00,0xFE,0x03,0x60,0x0C,0x90,0x10,0x08,0x21,0x00,0x40,0x00,0x78,0x00,0x00,/*"飛",44*/
0x04,0x02,0x04,0x01,0x84,0x00,0xC4,0xFF,0x3C,0x00,0x14,0x82,0x85,0x41,0x66,0x22,
0xBC,0x14,0x24,0x09,0x24,0x14,0x24,0x23,0xE4,0x40,0x24,0xC0,0x04,0x40,0x00,0x00,/*"夜",45*/
0x00,0x00,0x0C,0x22,0x04,0x1A,0x55,0x06,0xD5,0xFF,0x55,0x06,0x05,0x0A,0x7F,0x00,
0x05,0xFF,0x55,0x55,0x55,0x55,0x55,0x55,0x05,0xFF,0x0C,0x00,0x04,0x00,0x00,0x00,/*"霜",46*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"。",47*/
0x00,0x00,0x40,0x00,0x48,0x00,0x48,0x00,0x48,0xFF,0x7F,0x49,0x48,0x49,0x48,0x49,
0x48,0x49,0x48,0x49,0x7F,0x49,0x48,0xFF,0x48,0x00,0x48,0x00,0x40,0x00,0x00,0x00,/*"昔",48*/
0x00,0x00,0xFC,0xFF,0x00,0x00,0x11,0x08,0x12,0x08,0xF0,0x0F,0x52,0x09,0x52,0x09,
0x52,0x05,0xF2,0x7F,0x12,0x04,0x12,0x44,0x02,0x80,0xFE,0x7F,0x00,0x00,0x00,0x00,/*"聞",49*/
0x00,0x00,0x40,0x01,0x30,0x01,0x0E,0x01,0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,
0xFF,0x7F,0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,0x08,0x01,0x00,0x01,0x00,0x00,/*"牛",50*/
0x10,0x04,0x60,0xFC,0x01,0x03,0xC6,0x00,0x00,0x02,0x20,0x02,0x24,0xFF,0x24,0x49,
0xA4,0x49,0x7F,0x49,0x24,0x49,0x34,0x49,0x28,0xFF,0x26,0x00,0x20,0x00,0x00,0x00,/*"渚",51*/
0xFE,0x07,0x02,0x01,0x02,0x01,0x02,0x01,0xFE,0x07,0x40,0x00,0x20,0x01,0x10,0x01,
0x0C,0x01,0x23,0x81,0xC4,0x61,0x08,0x19,0x10,0x07,0x30,0x01,0x60,0x00,0x00,0x00,/*"吟",52*/
0x00,0x20,0x02,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x3F,0xFE,0x20,0x82,0x20,
0x82,0x20,0x82,0x20,0xC2,0x3F,0x82,0x20,0x02,0x20,0x00,0x30,0x00,0x20,0x00,0x00,/*"五",53*/
0x10,0x10,0x10,0x10,0x12,0x10,0xD2,0x17,0x56,0x15,0x5A,0x15,0x52,0x15,0x53,0xFD,
0x52,0x15,0x5A,0x15,0x56,0x15,0xD2,0x17,0x12,0x10,0x12,0x10,0x10,0x10,0x00,0x00,/*"章",54*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*",",55*/
0x80,0x00,0x80,0x00,0x40,0x00,0x20,0x02,0x10,0x02,0x08,0x02,0x24,0x02,0x43,0x82,
0xC4,0x42,0x08,0x32,0x10,0x0E,0x20,0x02,0x60,0x00,0xC0,0x00,0x40,0x00,0x00,0x00,/*"今",56*/
0x00,0x20,0x80,0x20,0x84,0x10,0x84,0x10,0x94,0x08,0xA4,0x04,0xC4,0x02,0xFF,0xFF,
0x84,0x01,0xC4,0x02,0xB4,0x04,0x94,0x08,0x84,0x18,0x84,0x30,0x80,0x10,0x00,0x00,/*"來",57*/
0x80,0x00,0x40,0x00,0xF0,0x7F,0x1C,0x00,0x07,0x00,0xE2,0x07,0x24,0x02,0x24,0x02,
0x24,0x02,0xE4,0x07,0x04,0x20,0x04,0x40,0xFC,0x3F,0x04,0x00,0x04,0x00,0x00,0x00,/*"何",58*/
0x40,0x00,0x42,0x00,0xCC,0x3F,0x04,0x50,0x00,0x29,0xFC,0x11,0x56,0x4D,0x55,0x83,
0xFC,0x7F,0x50,0x00,0x90,0x41,0x10,0x80,0xFF,0x7F,0x10,0x00,0x10,0x00,0x00,0x00,/*"謝",59*/
0x10,0x20,0x10,0x20,0x14,0x10,0xD4,0x11,0x54,0xF9,0x54,0x45,0x54,0x23,0x5F,0x03,
0x54,0x05,0x54,0x09,0x54,0x11,0xD4,0x29,0x14,0x64,0x10,0xC2,0x10,0x40,0x00,0x00,/*"袁",60*/
0x00,0x00,0x18,0x29,0x04,0x29,0x14,0x15,0x94,0x14,0x94,0x4A,0xD5,0x89,0xB6,0x44,
0x14,0x3F,0x14,0x06,0x94,0x09,0x04,0x09,0x14,0x10,0x0C,0x30,0x04,0x10,0x00,0x00,/*"家",61*/
0x00,0x00,0xFC,0x7F,0x94,0x20,0x95,0x10,0x96,0x0A,0x94,0x04,0xFC,0x18,0x00,0x00,
0x00,0x00,0xFE,0xFF,0x02,0x00,0x42,0x08,0xB2,0x08,0x0E,0x11,0x02,0x0E,0x00,0x00,/*"郎",62*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"。",63*/
//李白
0x80,0x00,0x84,0x04,0x44,0x04,0xC4,0x04,0xA4,0x04,0x94,0x44,0x8C,0x84,0xFF,0x7E,
0x8C,0x05,0x94,0x04,0xA4,0x04,0x24,0x04,0x44,0x04,0xC4,0x04,0x40,0x04,0x00,0x00,/*"李",0*/
0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0xF8,0x7F,0x00,0x00,0x00,0x00,0x00,0x00};/*"白",1*/
//數(shù)字
uchar code Ez[]={
0x00,0x00,0xE0,0x0F,0x10,0x10,0x08,0x20,0x08,0x20,0x10,0x10,0xE0,0x0F,0x00,0x00,/*"0",0*/
0x00,0x00,0x10,0x20,0x10,0x20,0xF8,0x3F,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,/*"1",1*/
0x00,0x00,0x70,0x30,0x08,0x28,0x08,0x24,0x08,0x22,0x88,0x21,0x70,0x30,0x00,0x00,/*"2",2*/
0x00,0x00,0x30,0x18,0x08,0x20,0x88,0x20,0x88,0x20,0x48,0x11,0x30,0x0E,0x00,0x00,/*"3",3*/
0x00,0x00,0x00,0x07,0xC0,0x04,0x20,0x24,0x10,0x24,0xF8,0x3F,0x00,0x24,0x00,0x00,/*"4",4*/
0x00,0x00,0xF8,0x19,0x08,0x21,0x88,0x20,0x88,0x20,0x08,0x11,0x08,0x0E,0x00,0x00,/*"5",5*/
0x00,0x00,0xE0,0x0F,0x10,0x11,0x88,0x20,0x88,0x20,0x18,0x11,0x00,0x0E,0x00,0x00,/*"6",6*/
0x00,0x00,0x38,0x00,0x08,0x00,0x08,0x3F,0xC8,0x00,0x38,0x00,0x08,0x00,0x00,0x00,/*"7",7*/
0x00,0x00,0x70,0x1C,0x88,0x22,0x08,0x21,0x08,0x21,0x88,0x22,0x70,0x1C,0x00,0x00,/*"8",8*/
0x00,0x00,0xE0,0x00,0x10,0x31,0x08,0x22,0x08,0x22,0x10,0x11,0xE0,0x0F,0x00,0x00,/*"9",9*/
0x00,0x00,0x00,0x60,0x00,0x18,0x00,0x06,0x80,0x01,0x60,0x00,0x18,0x00,0x04,0x00/*"/",10*/
完整代碼附件中
LCD12864基本漢字顯示案例.zip
(19.5 KB, 下載次數(shù): 97)
2018-12-17 02:38 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
