LCD1602定時計數(shù)測試
單片機源程序如下:
- #include<iom16v.h>
- #include <macros.h>
- #include "LCD1602.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar num;
- // IO端口定義
- void IO_init()
- DDRA = 0XFF;
- DDRB = 0XFF;
- DDRC = 0XFF;
- DDRD = 0XFF;
- PORTA = 0X00;
- PORTB = 0X00;
- PORTC = 0X00;
- PORTD = 0XFF;
- //延時函數(shù)
- void delayms(uint z) //8M晶振下,延時1ms
- uint x,y;
- for(x=z;x>0;x--)
- for(y=1333;y>0;y--);
- void timer1_init()//定時器1初始化
- TCCR1B = 0x04; //T/C1控制寄存器 設(shè)置256分頻
- TCNT1H = 0x85; //計數(shù)寄存器 設(shè)置初值 H (65536-(8M/256)=34286=85EE)
- TCNT1L = 0xEE; //計數(shù)寄存器 設(shè)置初值 L (34286:十進制 85EE:十六進制)
- TIMSK |=BIT(2);//T/C1中斷屏蔽寄存器 設(shè)置定時器1中斷
- SREG|=BIT(7); //開啟總中斷
- void display()
- LCD_write_char(0,1,0x30+num/10);
- LCD_write_char(1,1,0x30+num%10);
- void main()
- IO_init();
- timer1_init();//定時器1初始化
- LCD_init(); //LCD初始化
- LCD_clear();//LCD清屏
- while(1)
- display();
- #pragma interrupt_handler timer1_isr:9
- void timer1_isr()
- num++;
- if(num==60)
- num=0;
- TCNT1H = 0x85;
- TCNT1L = 0xEE;
復制代碼
LCD1602定時計數(shù)測試.zip
(26.93 KB, 下載次數(shù): 23)
2018-12-17 16:52 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
