- #include "stm32f10x.h"
- #include "stdio.h"
- #include "delay.h"
- #include "tft.h"
- #include "math.h"
- #include "stm32_init.h"
- #include "motor.h"
- #include "pid.h"
- #include "math.h"
- #define pi 3.1415926535898
- #define TwoPi 6.2831853071796
- #define ZhiXing 1
- #define HouZhuan 2
- #define ZuoZhuan 3
- #define YouZhuan 4
- #define ZhengZhuan 0
- #define FanZhuan 1
- #define NoWall 0
- #define YouGenQiang 1
- #define ZuoGenQiang 2
- //#define ShuangGenQiang 3
- #define YouGenQiangXia 4
- #define ZuoGenQiangXia 5
- //#define ShuangGenQiangXia 6
- #define X_ZhengFangXiang 1
- #define Y_ZhengFangXiang 2
- #define X_FuFangXiang 3
- #define Y_FuFangXiang 4
- #define YiGeTime1 96000 //95000
- //#define YiGeTime2 94000
- #define YiGeTime3 99000
- #define BanGeTime1 47500
- #define ZhongDianZuoBiao 7
- #define Active 1
- #define Dead 2
- #define FenZhiID_MAX_3FangXiang 2
- #define FenZhiID_MAX_2FangXiang 1
- #define XunLu 0
- #define FanHui 1
- #define ChongCi 2
- #define YES 1
- #define NO 0
- #define XiuZhengZhuanWanYiGeTime 85000 //90000
- #define GenQiangYuZhi1 0x80
- #define GenQiangYuZhi2 0xff
- #define MAX_SuDu 400
- #define MIN_SuDu 500
- u16 tim2_count=0;//程序循環(huán)周期
- u16 shuju[4];//定義第一組、2、4、6、8
- u16 shuju1[4];//定義第二組、1、3、5、7
- u16 qian,hou,zuo,you,zuoshang,zuoxia,youshang,youxia;//&0xf00
- u16 youshang2,youxia2,zuoshang2,zuoxia2;//&0xfc0,0xf80
- u16 youshang3,youxia3,zuoshang3,zuoxia3;//
- u8 GenQiangFlag=0;//跟墻標(biāo)志,做跟、右跟、雙跟
- u8 YunXingFlag=0;//運(yùn)行標(biāo)志,直行、左轉(zhuǎn)、右轉(zhuǎn)、后轉(zhuǎn)
- u8 QianJinFangXiang=0;//前進(jìn)方向,Y正、Y負(fù)、X正、X負(fù)
- u8 XunLuFanHuiChongCiFlag=XunLu;//尋路返回沖刺標(biāo)志
- u8 YiZouGuoGeShu=0;//已經(jīng)走過的格數(shù)
- u8 FenZhiDuiZhan=0;//分支堆棧
- //u8 FenZhiID=0;//分支ID
- u8 FenZhiID_MAX=0;//分支ID的最大值
- u8 CunChuLuJingShuZuXiaBiao=0;//存儲路徑數(shù)組下標(biāo)
- u8 ChongCiLuJingXiaBiao=0;//沖刺路徑下標(biāo)
- u32 YiGeTime_PanDuan=0;//判斷一格的時間,默認(rèn)為時間1,轉(zhuǎn)彎后為時間2,下次滿格變成時間3
- u8 LianXuZhiXing_Count=0;//判斷是否連續(xù)直行,連續(xù)直行需要改變一格時間
- u8 YouShangGenQiang_YuZhi=0;//右上跟墻閾值
- u8 YouXiaGenQiang_YuZhi=0;//右下跟墻閾值
- u8 ZuoShangGenQiang_YuZhi=0;//左上跟墻閾值
- u8 ZuoXiaGenQiang_YuZhi=0;//左下跟墻閾值
- u8 YouShangGenQiang_Count=0;//右上跟墻計數(shù)
- u8 YouXiaGenQiang_Count=0;//右下跟墻計數(shù)
- u8 ZuoShangGenQiang_Count=0;//左上跟墻計數(shù)
- u8 ZuoXiaGenQiang_Count=0;//左下跟墻計數(shù)
- const u16 juli[201];//查表,速度與距離的關(guān)系
- const int sin_figure[451];
- u8 LuJingZuoBiao[128][2];//路徑坐標(biāo)
- u8 FenZhiDianZuoBiao[64][2];//分支點(diǎn)坐標(biāo)
- u8 FenZhiID[64];//分支ID
- u8 FenZhiQiWangFangXiang[64][4]; //分支期望方向
- u8 LuJingQiWangFangXiang[1];//路徑期望方向
- float zuolun=0;
- float youlun=0;
- u16 zuolunint=0;
- u16 youlunint=0;
- int x_point=0;
- int y_point=0;
- u32 zuolun_juli=0;
- u32 youlun_juli=0;
- u32 hecheng_juli=0;//合成距離
- u8 FenZhi_ZhiZhen=0;
- void CaiYang(void);
- void XianShiZhi(void);
- int ABS_2(int x);
- void QianXiangPanDuan(void);//前向判斷
- void YouZhuanChuLi(void);
- void ZuoZhuanChuLi(void);
- void HouZhuanChuLi(void);
- void JiSuanZuoBiao(void);//計算坐標(biāo)
- void QiBu_Init(void);//起步初始化
- void JiLuFenZhiDianJiXuanZeFangXiang(void);//記錄分支點(diǎn)及選擇方向
- void GenJuQiWangFangXiangJiSuanQianJinFangXiang(void);//根據(jù)期望方向計算前進(jìn)方向
- void XianLuJing(void);//顯示路徑坐標(biāo)
- void GenJuLuJingQiWangFangXiangJiSuanQianJinFangXiang(void);//根據(jù)路徑期望方向計算前進(jìn)方向
- void AnLuJingFanHui(void);//按路徑返回
- void GenQiangZiChengXu(void);//跟墻子程序
- void AnLuJingChongCi(void);//按路徑?jīng)_刺
- void ZhuanWanQianDaoWei(void);//轉(zhuǎn)彎前到位
- void ChongCiQianXiangPanDuan(void);
- void QiBu_Init2(void);
- *入口參數(shù):無
- *出口參數(shù):無
- *功能:主函數(shù)
- int main(void)
- RCC_Configuration();//RCC配置
- GPIO_Configuration();//GPIO配置
- EXTI_Configuration();//初始化PA9外部中斷
- NVIC_Configuration();//嵌套向量中斷控制器配置
- TIM2_Int_Init(999,359);//tim2初始化
- SPI_Configuration();
- GPIO_SetBits(GPIOE,GPIO_Pin_15);//打開TFT電源
- delay(0xffffff);//延時
- Lcd_Init();//初始化TFT屏
- LCD_Clear(0);//清屏顯示黑色
- QiBu_Init();//起步初始化
- CaiYang();
- while(qian>0x200)
- CaiYang();
- delay(10000);
- Init_Motor(400,ZhengZhuan,400,ZhengZhuan);//直行
- delay(15000000);
- while(1)
- if(tim2_count>=20)//20*5ms=100ms
- tim2_count=0;
- if(YunXingFlag==ZhiXing)//2800//3300
- zuolun_juli = juli[zuolunint-400];
- youlun_juli = juli[youlunint-400];
- hecheng_juli += (zuolun_juli + youlun_juli);
- if(hecheng_juli>YiGeTime_PanDuan)//
- hecheng_juli=0;
- JiSuanZuoBiao();
- CaiYang();
- if(XunLuFanHuiChongCiFlag==XunLu)//尋路
- QianXiangPanDuan();
- else if(XunLuFanHuiChongCiFlag==ChongCi)
- ChongCiQianXiangPanDuan();
- /**********************沖刺前向判斷***********************/
- char msg[20];
- if(qian>0x500)//qian zhuang qiang
- if((you<0x200)&&(zuo<0x200))
- if(x_point==LuJingZuoBiao[ChongCiLuJingXiaBiao+1][0])
- if(LuJingZuoBiao[ChongCiLuJingXiaBiao+1][1]<y_point)
- LuJingQiWangFangXiang[0]=Y_FuFangXiang;
- else if(LuJingZuoBiao[ChongCiLuJingXiaBiao+1][1]>y_point)
- LuJingQiWangFangXiang[0]=Y_ZhengFangXiang;
- else if(y_point==LuJingZuoBiao[ChongCiLuJingXiaBiao+1][1])
- if(LuJingZuoBiao[ChongCiLuJingXiaBiao+1][0]<x_point)
- LuJingQiWangFangXiang[0]=X_FuFangXiang;
- else if(LuJingZuoBiao[ChongCiLuJingXiaBiao+1][0]>x_point)
- LuJingQiWangFangXiang[0]=X_ZhengFangXiang;
- else
- Off_Motor(3);
- LCD_ShowString(0,0,"cuo wu");
- sprintf(msg,"x_zb=%1d",LuJingZuoBiao[ChongCiLuJingXiaBiao+1][0]);
- LCD_ShowString(0,96,msg);
- sprintf(msg,"y_zb=%1d",LuJingZuoBiao[ChongCiLuJingXiaBiao+1][1]);
- LCD_ShowString(0,128,msg);
- while(1);
- GenJuLuJingQiWangFangXiangJiSuanQianJinFangXiang();
- else if(you<0x200)//bu shi fen zhi dian
- YouZhuanChuLi();
- else if(zuo<0x200)//bu shi fen zhi dian
- ZuoZhuanChuLi();
- else//shi si hu tong
- HouZhuanChuLi();
- else//qian wu qiang bi
- if(hecheng_juli==0)//zheng ge pan duan
- if((qian<0x80)&&((zuo<0x200)||(you<0x200)))
- else
- Off_Motor(3);
- while(1);
- else
- GenQiangZiChengXu();
- else
- /**********************前向判斷***********************/
- JiLuFenZhiDianJiXuanZeFangXiang();
- GenJuQiWangFangXiangJiSuanQianJinFangXiang();
- YouZhuanChuLi();
- ZuoZhuanChuLi();
- HouZhuanChuLi();
- else
- else
- /**********************跟墻子程序***********************/
- // float you1,zuo1;
- YunXingFlag=ZhiXing;
- if(youshang>0x300)
- zuolunint=MIN_SuDu;
- youlunint=MAX_SuDu;
- else if(zuoshang>0x300)
- zuolunint=MAX_SuDu;
- youlunint=MIN_SuDu;
- else
- if(you>0x100)
- if((youshang>0x80)&&(youshang<0x300))
- if(GenQiangFlag != YouGenQiang)
- YouShangGenQiang_Count++;
- YouXiaGenQiang_Count=0;
- ZuoShangGenQiang_Count=0;
- ZuoXiaGenQiang_Count=0;
- if(YouShangGenQiang_Count>2)
- YouShangGenQiang_Count=0;
- GenQiangFlag=YouGenQiang;
- PID_init2();
- PID_realize(0x180,youshang3,YouGenQiang);//0x180
- else
- else if((youxia>0x80)&&(youxia<0x300))
- if(GenQiangFlag == YouGenQiang)
- GenQiangFlag=YouGenQiangXia;
- PID_init2();
- PID_realize2(0x180,youxia3,YouGenQiangXia);//0x180
- else if((GenQiangFlag != YouGenQiangXia)&&(youxia>0x100))
- YouXiaGenQiang_Count++;
- if(YouXiaGenQiang_Count>2)
- PID_init2();
- else if(GenQiangFlag==YouGenQiangXia)
- else if(zuo>0x100)
- if((zuoshang>0x80)&&(zuoshang<0x300))
- if(GenQiangFlag != ZuoGenQiang)
- ZuoShangGenQiang_Count++;
- if(ZuoShangGenQiang_Count>2)
- GenQiangFlag=ZuoGenQiang;
- PID_init3();
- PID_realize(0x140,zuoshang3,ZuoGenQiang);//0x180
- else
- else if((zuoxia>0x80)&&(zuoxia<0x300))
- if(GenQiangFlag == ZuoGenQiang)
- GenQiangFlag=ZuoGenQiangXia;
- PID_init3();
- PID_realize2(0x140,zuoxia3,ZuoGenQiangXia);//0x180
- else if((GenQiangFlag != ZuoGenQiangXia)&&(zuoxia>0x100))
- ZuoXiaGenQiang_Count++;
- if(ZuoXiaGenQiang_Count>2)
- PID_init3();
- else if(GenQiangFlag==ZuoGenQiangXia)
- else if((zuo<0x80)&&(you<0x80)&&(hou<0x80))
- GenQiangFlag=NoWall;
- // if(qian>0x80)
- // PID_init4();
- // you1=youshang2;
- // zuo1=zuoshang2;
- // PID_realize(0,ABS(you1-zuo1),NoWall);
- // else
- if(zuolunint==0)
- zuolunint=400;
- if(youlunint==0)
- youlunint=400;
- Init_Motor(zuolunint,ZhengZhuan,youlunint,ZhengZhuan);//直行
- /**********************計算坐標(biāo)***********************/
- u8 i,j;
- char msg[20];
- if(QianJinFangXiang==Y_ZhengFangXiang)
- y_point += 1;
- else if(QianJinFangXiang==Y_FuFangXiang)
- y_point -= 1;
- else if(QianJinFangXiang==X_ZhengFangXiang)
- x_point += 1;
- else if(QianJinFangXiang==X_FuFangXiang)
- x_point -= 1;
- if(y_point<0)
- y_point=0;
- else if(y_point>ZhongDianZuoBiao)
- y_point=ZhongDianZuoBiao;
- if(x_point<0)
- x_point=0;
- else if(x_point>ZhongDianZuoBiao)
- x_point=ZhongDianZuoBiao;
- // sprintf(msg,"FenZhi_ZhiZhen=%1d",FenZhi_ZhiZhen);
- // LCD_ShowString(0,64,msg);
- // sprintf(msg,"FenZhiDuiZhan=%1d",FenZhiDuiZhan);
- // LCD_ShowString(0,96,msg);
- sprintf(msg,"x_point=%1d",x_point);
- LCD_ShowString(0,160,msg);
- sprintf(msg,"y_point=%1d",y_point);
- LCD_ShowString(0,192,msg);
- if((LuJingZuoBiao[YiZouGuoGeShu-1][0]==x_point)&&(LuJingZuoBiao[YiZouGuoGeShu-1][1]==y_point))
- return;
- for(i=0;i<YiZouGuoGeShu;i++)
- if((LuJingZuoBiao[i][0]==x_point)&&(LuJingZuoBiao[i][1]==y_point))
- YiZouGuoGeShu=i;
- for(j=0;j<FenZhiDuiZhan+1;j++)
- if((FenZhiDianZuoBiao[j][0]==x_point)&&(FenZhiDianZuoBiao[j][1]==y_point))
- FenZhiID[j]++;
- FenZhi_ZhiZhen=j;
- break;
- break;
- LuJingZuoBiao[YiZouGuoGeShu][0]=x_point;
- LuJingZuoBiao[YiZouGuoGeShu][1]=y_point;
- YiZouGuoGeShu++;
- if((x_point==ZhongDianZuoBiao)&&(y_point==ZhongDianZuoBiao))
- delay(15000000);
- Off_Motor(3);
- XianLuJing();
- while(XunLuFanHuiChongCiFlag==XunLu);
- ChongCiLuJingXiaBiao++;
- delay(15000000);
- Off_Motor(3);
- LCD_ShowString(0,0,"success");
- while(1);
- /**********************記錄分支點(diǎn)及選擇方向***********************/
- u8 i;
- if( (x_point==0) && (y_point==0) )
- return;
- if( (x_point==FenZhiDianZuoBiao[FenZhiDuiZhan][0]) && (y_point==FenZhiDianZuoBiao[FenZhiDuiZhan][1]) )
- return;
- for(i=0;i<FenZhiDuiZhan;i++)
- if( (x_point==FenZhiDianZuoBiao[i][0]) && (y_point==FenZhiDianZuoBiao[i][1]) )
- // FenZhiID[i]++;
- // FenZhi_ZhiZhen=i;
- return;
- FenZhiDuiZhan++;
- FenZhiDianZuoBiao[FenZhiDuiZhan][0]=x_point;
- FenZhiDianZuoBiao[FenZhiDuiZhan][1]=y_point;
- FenZhi_ZhiZhen=FenZhiDuiZhan;
- if((qian<0x80)&&(zuo<0x200)&&(you<0x200))//qian zuo you
- FenZhiID_MAX=FenZhiID_MAX_3FangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][0]=Y_ZhengFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][1]=X_ZhengFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][2]=X_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][3]=Y_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][0]=X_ZhengFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][1]=Y_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][3]=Y_ZhengFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][1]=Y_ZhengFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][2]=Y_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][3]=X_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][1]=X_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][3]=X_ZhengFangXiang;
- else if((qian<0x80)&&(zuo<0x200))//qian zuo
- FenZhiID_MAX=FenZhiID_MAX_2FangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][2]=Y_ZhengFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][0]=X_FuFangXiang;
- FenZhiQiWangFangXiang[FenZhiDuiZhan][2]=X_ZhengFangXiang;
- else if((qian<0x80)&&(you<0x200))//qian you
- FenZhiQiWangFangXiang[FenZhiDuiZhan][0]=Y_FuFangXiang;
- else if((zuo<0x200) &&(you<0x200))
- /**********************根據(jù)期望方向計算前進(jìn)方向***********************/
- u8 FangXiangChaZhi;
- if(FenZhiQiWangFangXiang[FenZhi_ZhiZhen][FenZhiID[FenZhi_ZhiZhen]]<QianJinFangXiang)
- FangXiangChaZhi=QianJinFangXiang-FenZhiQiWangFangXiang[FenZhi_ZhiZhen][FenZhiID[FenZhi_ZhiZhen]];
- if(FangXiangChaZhi==2)
- FenZhiID[FenZhi_ZhiZhen]++;
- else
- FangXiangChaZhi=FenZhiQiWangFangXiang[FenZhi_ZhiZhen][FenZhiID[FenZhi_ZhiZhen]]-QianJinFangXiang;
- switch(FangXiangChaZhi)
- case 1:YouZhuanChuLi();break;//delay(1000000);
- // case 2:HouZhuanChuLi();break;
- case 3:ZuoZhuanChuLi();break;
- default:break;
- else
- case 0:break;
- case 1:ZuoZhuanChuLi();break;
- case 3:YouZhuanChuLi();break;
- default:break;
- /**********************起步初始化***********************/
- u8 i;
- tim2_count=0;//程序循環(huán)周期
- GenQiangFlag=0;//跟墻標(biāo)志,做跟、右跟、雙跟
- YunXingFlag=0;//運(yùn)行標(biāo)志,直行、左轉(zhuǎn)、右轉(zhuǎn)、后轉(zhuǎn)
- XunLuFanHuiChongCiFlag=ChongCi;//尋路返回沖刺標(biāo)志
- FenZhiDuiZhan=0;//分支堆棧
- // FenZhiID=0;//分支ID
- FenZhiID_MAX=0;//分支ID的最大值
- CunChuLuJingShuZuXiaBiao=0;//存儲路徑數(shù)組下標(biāo)
- ChongCiLuJingXiaBiao=0;//沖刺路徑下標(biāo)
- LianXuZhiXing_Count=0;//判斷是否連續(xù)直行,連續(xù)直行需要改變一格時間
- zuolun=0;
- youlun=0;
- zuolunint=0;
- youlunint=0;
- x_point=0;
- y_point=0;
- zuolun_juli=0;
- youlun_juli=0;
- hecheng_juli=0;//合成距離
- QianJinFangXiang=Y_ZhengFangXiang;
- YiZouGuoGeShu=1;
- YiGeTime_PanDuan=YiGeTime1;
- for(i=0;i<64;i++)
- FenZhiDianZuoBiao[i][0]=0;
- FenZhiDianZuoBiao[i][1]=0;
- FenZhiID[i]=0;
- for(i=0;i<64;i++)
- FenZhiQiWangFangXiang[i][0]=0;
- FenZhiQiWangFangXiang[i][1]=0;
- FenZhiQiWangFangXiang[i][2]=0;
- FenZhiQiWangFangXiang[i][3]=0;
- LuJingQiWangFangXiang[0]=0;
- YouShangGenQiang_YuZhi=GenQiangYuZhi2;
- YouXiaGenQiang_YuZhi=GenQiangYuZhi2;
- ZuoShangGenQiang_YuZhi=GenQiangYuZhi2;
- ZuoXiaGenQiang_YuZhi=GenQiangYuZhi2;
- u8 i;
- XunLuFanHuiChongCiFlag=XunLu;//尋路返回沖刺標(biāo)志
- zuolun=0;
- youlun=0;
- zuolunint=0;
- youlunint=0;
- x_point=0;
- y_point=0;
- zuolun_juli=0;
- youlun_juli=0;
- YiZouGuoGeShu=1;
- LuJingZuoBiao[0][0]=0;
- LuJingZuoBiao[0][1]=0;
- for(i=0;i<128;i++)
- LuJingZuoBiao[i][0]=0;
- LuJingZuoBiao[i][1]=0;
- for(i=0;i<64;i++)
- FenZhiID[i]=0;
- for(i=0;i<64;i++)
- /**********************按路徑返回***********************/
- if(CunChuLuJingShuZuXiaBiao!=0)
- if(LuJingZuoBiao[CunChuLuJingShuZuXiaBiao][0]==LuJingZuoBiao[CunChuLuJingShuZuXiaBiao-1][0])
- if(LuJingZuoBiao[CunChuLuJingShuZuXiaBiao-1][1]<LuJingZuoBiao[CunChuLuJingShuZuXiaBiao][1])
- else
- else
- if(LuJingZuoBiao[CunChuLuJingShuZuXiaBiao-1][0]<LuJingZuoBiao[CunChuLuJingShuZuXiaBiao][0])
- else
- /**********************按路徑?jīng)_刺***********************/
- if(ChongCiLuJingXiaBiao != CunChuLuJingShuZuXiaBiao)
- if(LuJingZuoBiao[ChongCiLuJingXiaBiao][0]==LuJingZuoBiao[ChongCiLuJingXiaBiao+1][0])
- if(LuJingZuoBiao[ChongCiLuJingXiaBiao+1][1]<LuJingZuoBiao[ChongCiLuJingXiaBiao][1])
- else
- else
- if(LuJingZuoBiao[ChongCiLuJingXiaBiao+1][0]<LuJingZuoBiao[ChongCiLuJingXiaBiao][0])
- else
- /**********************根據(jù)路徑期望方向計算前進(jìn)方向***********************/
- // LianXuZhiXing_Count=0;
- // ZhuanWanQianDaoWei();
- if(LuJingQiWangFangXiang[0]<QianJinFangXiang)
- FangXiangChaZhi=QianJinFangXiang-LuJingQiWangFangXiang[0];
- case 1:
- YouZhuanChuLi();break;
- case 3:
- ZuoZhuanChuLi();break;
- default:break;
- else
- FangXiangChaZhi=LuJingQiWangFangXiang[0]-QianJinFangXiang;
- case 0:break;
- case 1:
- case 3:
- default:break;
- *入口參數(shù):無
- *出口參數(shù):無
- *功能:定時器2中斷服務(wù)函數(shù)
- void TIM2_IRQHandler(void)
- TIM_ClearITPendingBit(TIM2,TIM_IT_Update); //清除中斷標(biāo)志
- tim2_count++;
- if(hecheng_juli>XiuZhengZhuanWanYiGeTime)
- JiSuanZuoBiao();
- hecheng_juli=0;
- Off_Motor(3);
- Init_Motor(400,ZhengZhuan,400,FanZhuan);//右轉(zhuǎn)
- delay(6210000);
- Off_Motor(3);
- YiGeTime_PanDuan=YiGeTime1;//
- QianJinFangXiang=X_ZhengFangXiang;
- QianJinFangXiang=X_FuFangXiang;
- QianJinFangXiang=Y_FuFangXiang;
- JiSuanZuoBiao();
- hecheng_juli=0;
- Off_Motor(3);
- Init_Motor(400,FanZhuan,400,ZhengZhuan);//左轉(zhuǎn)
- delay(6210000);
- Off_Motor(3);
- JiSuanZuoBiao();
- hecheng_juli=0;
- Off_Motor(3);
- Init_Motor(400,FanZhuan,400,ZhengZhuan);//后轉(zhuǎn)
- delay(12410000);
- Off_Motor(3);
- u8 i;
- if(qian>0x0)
- i=0;
- while(qian<0x500)
- CaiYang();
- i++;
- if(i>100)
- i=0;
- delay(1000);
- /**********************顯示路徑***********************/
- char msg[20];
- u8 i;
- for(i=0;i<7;i++)
- sprintf(msg,"%1d",LuJingZuoBiao[0+2*i][0]);//LuJingZuoBiao
- LCD_ShowString(0,0+32*i,msg);
- sprintf(msg,"%1d",LuJingZuoBiao[0+2*i][1]);
- LCD_ShowString(32,0+32*i,msg);
- sprintf(msg,"%1d",LuJingZuoBiao[1+2*i][0]);
- LCD_ShowString(200,0+32*i,msg);
- sprintf(msg,"%1d",LuJingZuoBiao[1+2*i][1]);
- LCD_ShowString(232,0+32*i,msg);
- /**********************顯示***********************/
- char msg[20];
- sprintf(msg,"1=%3X",shuju1[0]);
- LCD_ShowString(100,0,msg);
- sprintf(msg,"2=%3X",shuju[0]);
- LCD_ShowString(0,32,msg);
- sprintf(msg,"3=%3X",shuju1[1]);
- LCD_ShowString(0,64,msg);
- sprintf(msg,"4=%3X",shuju[1]);
- sprintf(msg,"5=%3X",shuju1[2]);
- LCD_ShowString(100,128,msg);
- sprintf(msg,"6=%3X",shuju[2]);
- LCD_ShowString(200,96,msg);
- sprintf(msg,"7=%3X",shuju1[3]);
- LCD_ShowString(200,64,msg);
- sprintf(msg,"8=%3X",shuju[3]);
- LCD_ShowString(200,32,msg);
- /**********************采樣***********************/
- u8 i,j;
- u16 shuju_zc[4];
- u16 shuju1_zc[4];
- GPIO_SetBits(GPIOA, GPIO_Pin_7);//打開AD_Ctrl1,開始轉(zhuǎn)換//2/4/6/8
- delay(10);//延時
- ADC_Configuration((u32)shuju,1);//轉(zhuǎn)換第一組
- GPIO_ResetBits(GPIOA, GPIO_Pin_7);//關(guān)閉AD_Ctrl1
- delay(10);//延時
- GPIO_SetBits(GPIOA, GPIO_Pin_6);//打開AD_Ctrl0,開始轉(zhuǎn)換//1/3/5/7
- delay(10);//延時
- ADC_Configuration((u32)shuju1,2); //轉(zhuǎn)換第二組
- GPIO_ResetBits(GPIOA, GPIO_Pin_6);//關(guān)閉AD_Ctrl0
- for(i=0;i<4;i++)
- shuju_zc[i] = 0;
- shuju1_zc[i] = 0;
- for(i=0;i<3;i++)
- delay(10);//延時
- delay(10);//延時
- delay(10);//延時
- for(j=0;j<4;j++)
- shuju_zc[j] += shuju[j];
- shuju1_zc[j] += shuju1[j];
- for(i=0;i<4;i++)
- shuju[i] = shuju_zc[i]/3;
- shuju1[i] = shuju1_zc[i]/3;
- qian=shuju1[0];
- zuo=shuju1[1];
- hou=shuju1[2];
- you=shuju1[3];
- zuoshang=shuju[0];
- zuoxia=shuju[1];
- youxia=shuju[2];
- youshang=shuju[3];
- zuoshang2=shuju[0]&0xf00;
- zuoxia2=shuju[1]&0xf00;
- youxia2=shuju[2]&0xf00;
- youshang2=shuju[3]&0xf00;
- zuoshang3=shuju[0]&0xfc0;
- zuoxia3=shuju[1]&0xfc0;
- youxia3=shuju[2]&0xf80;
- youshang3=shuju[3]&0xf80;
- *入口參數(shù):無
- *出口參數(shù):無
- *功能:PA9外部中斷服務(wù)函數(shù),實(shí)現(xiàn)LED燈循環(huán)點(diǎn)亮間隔的改變
- void EXTI9_5_IRQHandler(void)
- EXTI_ClearITPendingBit(EXTI_Line9);//清除PA9掛起位
- if((GPIO_ReadInputData(GPIOA)&0x0200) == 0)
- delay(500000);//延時去抖動
- QiBu_Init2();
- CaiYang();
- while(qian>0x200)
- CaiYang();
- delay(10000);
- delay(15000000);
- const u16 juli[201]={
- 2500,2487,2475,2463,2450,2439,2427,2415,
- 2403,2392,2380,2369,2358,2347,2336,2325,
- 2314,2304,2293,2283,2272,2262,2252,2242,
- 2232,2222,2212,2202,2192,2183,2173,2164,
- 2155,2145,2136,2127,2118,2109,2100,2092,
- 2083,2074,2066,2057,2049,2040,2032,2024,
- 2016,2008,2000,1992,1984,1976,1968,1960,
- 1953,1945,1937,1930,1923,1915,1908,1901,
- 1893,1886,1879,1872,1865,1858,1851,1845,
- 1838,1831,1824,1818,1811,1805,1798,1792,
- 1785,1779,1773,1766,1760,1754,1748,1742,
- 1736,1730,1724,1718,1712,1706,1700,1694,
- 1689,1683,1677,1672,1666,1661,1655,1650,
- 1644,1639,1633,1628,1623,1618,1612,1607,
- 1602,1597,1592,1587,1582,1577,1572,1567,
- 1562,1557,1552,1547,1543,1538,1533,1529,
- 1524,1519,1515,1510,1506,1501,1497,1492,
- 1488,1483,1479,1474,1470,1466,1461,1457,
- 1453,1449,1445,1440,1436,1432,1428,1424,
- 1420,1416,1412,1408,1404,1400,1396,1392,
- 1388,1385,1381,1377,1373,1369,1366,1362,
- 1358,1355,1351,1347,1344,1340,1336,1333,
- 1329,1326,1322,1319,1315,1312,1308,1305,
- 1302,1298,1295,1291,1288,1285,1282,1278,
- 1275,1272,1269,1265,1262,1259,1256,1253,
- 1250
復(fù)制代碼 |
bisai.7z
2018-12-18 02:02 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
202.49 KB, 下載次數(shù): 22, 下載積分: 黑幣 -5
迷宮機(jī)器人
