查看: 10819|回復(fù): 10
PIC單片機(jī)+LCD12864顯示漢字程序
ID:21069 發(fā)表于 2018-12-21 23:33 | 顯示全部樓層 |閱讀模式
#include<pic.h>
#define RS RD2
#define CS2 RD1
#define CS1 RD0
#define E RD4
#define RW RD3
#define BUSY RC7
const unsigned char tab2[]={
/*--  文字:  福  --*/
/*--  宋體12;  此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16   --*/
0x08,0x08,0x89,0xCE,0x28,0x18,0x02,0x7A,0x4A,0x4A,0x4A,0x4A,0x4A,0x7A,0x02,0x00,
0x02,0x01,0x00,0xFF,0x01,0x02,0xFF,0x49,0x49,0x49,0x7F,0x49,0x49,0x49,0xFF,0x00,
/*--  文字:  建  --*/
0x00,0x42,0x62,0x5A,0xC6,0x10,0x54,0x54,0x54,0xFF,0x54,0x54,0x7C,0x10,0x10,0x00,
0x40,0x23,0x14,0x08,0x17,0x28,0x29,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x40,0x00,
/*--  文字:  工  --*/
0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
/*--  文字:  程  --*/
0x10,0x12,0xD2,0xFE,0x91,0x11,0x80,0xBF,0xA1,0xA1,0xA1,0xA1,0xBF,0x80,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x41,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0x40,0x00,
/*--  文字:  學(xué)  --*/
0x40,0x30,0x10,0x12,0x5C,0x54,0x50,0x51,0x5E,0xD4,0x50,0x18,0x57,0x32,0x10,0x00,
0x00,0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x00,
/*--  文字:  院  --*/
0xFE,0x02,0x32,0x4A,0x86,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0x0C,0x04,0x00,
0xFF,0x00,0x02,0x04,0x83,0x41,0x31,0x0F,0x01,0x01,0x7F,0x81,0x81,0x81,0xF1,0x00,
/*--  文字:  ,  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  環(huán)  --*/
0x00,0x22,0x22,0xFE,0x22,0x22,0x00,0x02,0xC2,0x32,0xFE,0x42,0x82,0x02,0x02,0x00,
0x00,0x04,0x04,0x03,0x12,0x0A,0x04,0x03,0x00,0x00,0xFF,0x00,0x00,0x03,0x0E,0x00,
/*--  文字:  境  --*/
0x20,0x20,0xFE,0x20,0x20,0x00,0x24,0xAC,0xB4,0xA5,0xA6,0xB4,0xAC,0x24,0x00,0x00,
0x10,0x30,0x1F,0x08,0x08,0x00,0x80,0x4F,0x3A,0x0A,0x0A,0x7A,0x8F,0x80,0xE0,0x00,
/*--  文字:  優(yōu)  --*/
0x40,0x20,0xF8,0x17,0x02,0x10,0x10,0xF0,0x1F,0xF0,0x12,0x1C,0x14,0x10,0x00,0x00,
0x00,0x00,0xFF,0x00,0x40,0x20,0x18,0x07,0x00,0x3F,0x40,0x40,0x40,0x78,0x20,0x00,
/*--  文字:  美  --*/
0x00,0x84,0x84,0x94,0x95,0x96,0x94,0xFC,0x94,0x96,0x95,0x94,0x94,0x84,0x80,0x00,
0x80,0x80,0x44,0x44,0x24,0x14,0x0C,0x07,0x0C,0x14,0x24,0x64,0xC4,0x44,0x00,0x00,
/*--  文字:  ,  --*/
/*--  文字:  歷  --*/
0x00,0x00,0xFE,0x02,0x22,0x22,0x22,0x22,0xFA,0x22,0x22,0x22,0xE2,0x02,0x02,0x00,
0x40,0x30,0x0F,0x00,0x40,0x20,0x18,0x06,0x01,0x00,0x20,0x60,0x3F,0x00,0x00,0x00,
/*--  文字:  史  --*/
0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,
0x80,0x80,0x41,0x40,0x22,0x14,0x08,0x17,0x20,0x20,0x20,0x40,0x41,0xC0,0x40,0x00,
/*--  文字:  悠  --*/
0x20,0x10,0xFC,0x03,0xF8,0x20,0x10,0x0C,0x17,0xA4,0x44,0xB4,0x0C,0x04,0x04,0x00,
0x40,0x70,0x03,0x00,0x38,0x40,0x40,0x45,0x59,0x40,0x40,0x70,0x01,0x13,0x61,0x00,
/*--  文字:  久  --*/
0x00,0x00,0x80,0x40,0x30,0x0C,0x0B,0x08,0xC8,0xBC,0x08,0x00,0x00,0x00,0x00,0x00,
0x40,0x41,0x20,0x20,0x10,0x08,0x04,0x03,0x00,0x01,0x06,0x18,0x30,0x60,0x20,0x00,
/*--  文字:  。  --*/
0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  歡  --*/
0x14,0x24,0x44,0x84,0x64,0x1C,0x20,0x18,0x0F,0xE8,0x08,0x08,0x28,0x18,0x08,0x00,
0x20,0x10,0x4C,0x43,0x43,0x2C,0x20,0x10,0x0C,0x03,0x06,0x18,0x30,0x60,0x20,0x00,
/*--  文字:  迎  --*/
0x40,0x41,0xCE,0x04,0x00,0xFC,0x04,0x02,0x02,0xFC,0x04,0x04,0x04,0xFC,0x00,0x00,
0x40,0x20,0x1F,0x20,0x40,0x47,0x42,0x41,0x40,0x5F,0x40,0x42,0x44,0x43,0x40,0x00,
/*--  文字:  你  --*/
0x80,0x40,0xF0,0x2C,0x43,0x20,0x98,0x0F,0x0A,0xE8,0x08,0x88,0x28,0x1C,0x08,0x00,
0x00,0x00,0x7F,0x00,0x10,0x0C,0x03,0x21,0x40,0x3F,0x00,0x00,0x03,0x1C,0x08,0x00,
/*--  文字:  的  --*/
0x00,0xF8,0x8C,0x8B,0x88,0xF8,0x40,0x30,0x8F,0x08,0x08,0x08,0x08,0xF8,0x00,0x00,
0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x03,0x26,0x40,0x20,0x1F,0x00,0x00,
/*--  文字:  到  --*/
0x00,0x22,0x72,0x2A,0x26,0xE2,0x2A,0x72,0x22,0x00,0xF8,0x00,0x00,0xFF,0x00,0x00,
0x00,0x42,0xC2,0x42,0x22,0x3F,0x22,0x12,0x12,0x00,0x0F,0x40,0x80,0x7F,0x00,0x00,
/*--  文字:  來  --*/
0x00,0x80,0x84,0x84,0x94,0xA4,0xC4,0xFF,0x84,0xC4,0xB4,0x94,0x84,0x84,0x80,0x00,
0x20,0x20,0x10,0x10,0x08,0x04,0x02,0xFF,0x01,0x02,0x04,0x08,0x18,0x30,0x10,0x00,
/*--  文字:  !  --*/
0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x5F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  電  --*/
0x00,0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xF8,0x00,0x00,0x00,
0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x3F,0x44,0x44,0x44,0x44,0x4F,0x40,0x70,0x00,
/*--  文字:  子  --*/
0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xE2,0x12,0x0A,0x06,0x02,0x00,0x80,0x00,0x00,
0x01,0x01,0x01,0x01,0x01,0x41,0x81,0x7F,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
/*--  文字:  信  --*/
0x80,0x40,0x30,0xFC,0x07,0x0A,0xA8,0xA8,0xA9,0xAE,0xAA,0xA8,0xA8,0x08,0x08,0x00,
0x00,0x00,0x00,0x7F,0x00,0x00,0x7E,0x22,0x22,0x22,0x22,0x22,0x7E,0x00,0x00,0x00,
/*--  文字:  息  --*/
0x00,0x00,0x00,0xFC,0x54,0x54,0x56,0x55,0x54,0x54,0x54,0xFC,0x00,0x00,0x00,0x00,
0x00,0x20,0x38,0x01,0x3D,0x41,0x41,0x45,0x59,0x41,0x41,0x71,0x00,0x08,0x30,0x00,
/*--  文字:  工  --*/
/*--  文字:  程  --*/
/*--  文字:  !  --*/
/*--  文字:     --*/
//寫指令代碼(左)
void l_w_code(char l_code)
        //check_busy();
        PORTD=0x12;
        PORTC=l_code;
        E=1;
        E=0;
        asm("nop");
//寫顯示數(shù)據(jù)(左)
void l_w_data(char l_data)
        //check_busy();
        PORTD=0x16;
        PORTC=l_data;
        E=1;
        E=0;
        asm("nop");
//寫指令代碼(右)
void r_w_code(char        r_code)
        //check_busy();
        PORTD=0x11;
        PORTC=r_code;
        E=1;
        E=0;
        //asm("nop");
//寫顯示數(shù)據(jù)(右)
void r_w_data(char r_data)
        //check_busy();
        PORTD=0x15;
        PORTC=r_data;
        E=1;
        E=0;
        asm("nop");
void initializeLCD(void)
        l_w_code(0x3f);
        l_w_code(0xc0);
        l_w_code(0xb8);
        l_w_code(0x40);
        r_w_code(0x3f);
        r_w_code(0xc0);
        r_w_code(0xb8);
        r_w_code(0x80);
void l_display(void)
        unsigned char m,n;
    unsigned char i;
    unsigned char x=0xb8;
    unsigned char y=0x40;
        unsigned int k=0;
        //k=0;
    l_w_code(x);                        //寫入頁(yè)地址
    l_w_code(y);                        //第一列開始
for(i=0;i<4;i++)
        for(y=0x40;y<0x80;y+=0x10)
          for (m=0;m<2;m++)
             for(n=0;n<16;n++)
                          l_w_data(tab2[k++]);
              x+=0x01;
          x=x-0x02;
          for (m=0;m<2;m++)
            r_w_code(x);                        //寫入頁(yè)地址
            r_w_code(y);                        //第一列開始
            for(n=0;n<16;n++)
                         r_w_data(tab2[k++]);
             x+=0X01;
         x-=0x02;
   x+=0x02;
void delaycnt(unsigned int cnt)
        while(--cnt);
void main(void)
        //port_init();
        TRISC=0X00;
        TRISD=0X00;
        initializeLCD();
                l_display();
            delaycnt(65535);
PIC顯示漢字.rar (3.84 KB, 下載次數(shù): 102)
參與人數(shù) 8黑幣 +128 收起 理由
yoxi + 15 很給力!
鉆牛尖滴劉尖尖 + 10
areyouok + 10 很給力!
shuisheng + 15
Trump1438 + 10 贊一個(gè)!
#include51.h + 8 贊一個(gè)!
Sawardeakar + 10 很給力!
ID:472242 發(fā)表于 2019-2-3 21:13 | 顯示全部樓層
做的很漂亮,收下了
參與人數(shù) 5黑幣 +107 收起 理由
站著說話不腰疼 + 12
Trump1438 + 15
shuisheng + 35
刀刀見紅 + 35
areyouok + 10
ID:472325 發(fā)表于 2019-2-7 00:04 | 顯示全部樓層
好樣的,這就是所要的
參與人數(shù) 2黑幣 +27 收起 理由
找人PK + 12
#include51.h + 15
ID:472268 發(fā)表于 2019-2-7 00:32 | 顯示全部樓層
真的不錯(cuò)!值得學(xué)習(xí)了
參與人數(shù) 2黑幣 +60 收起 理由
就你**** + 25
Sawardeakar + 35
ID:471066 發(fā)表于 2019-2-7 15:09 | 顯示全部樓層
這就是很好的!
參與人數(shù) 2黑幣 +47 收起 理由
站著說話不腰疼 + 12
刀刀見紅 + 35
ID:474670 發(fā)表于 2019-2-9 14:00 | 顯示全部樓層
非常好的東東
ID:509052 發(fā)表于 2019-4-10 19:28 | 顯示全部樓層
您的原理圖是什么軟件畫的?
ID:556500 發(fā)表于 2019-6-6 15:10 | 顯示全部樓層
您的原理圖是什么軟件畫的?
ID:615610 發(fā)表于 2020-4-1 21:30 | 顯示全部樓層
做的漂亮
ID:729144 發(fā)表于 2020-4-14 17:32 | 顯示全部樓層
支持,PIC單片機(jī)的資料不太多。
ID:964960 發(fā)表于 2021-9-8 20:09 | 顯示全部樓層
Yunuis 發(fā)表于 2019-6-6 15:10
您的原理圖是什么軟件畫的?
PROTEUS軟件
