查看: 2442|回復(fù): 2
51單片機(jī)C語(yǔ)言指針數(shù)組發(fā)送的疑惑
ID:120930 發(fā)表于 2018-12-26 23:17 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
請(qǐng)大俠指點(diǎn)迷津:在串口中斷服務(wù)函數(shù)里比如當(dāng)串口接收到數(shù)據(jù)4時(shí),程序依次執(zhí)行61,62,63,64,65,66,17,18,19,20,21,37,38,39,40,41,67,68,69,70,71,72,73,74,75,然后就跳出67,if(TI)這個(gè)函數(shù)了,此時(shí)TI=0,RI=0,cmdArrived=0,主程序就停在17的位置了,此時(shí)第72行就執(zhí)行了一次,就發(fā)送了數(shù)組的首地址的數(shù)據(jù),然而事實(shí)上是都發(fā)送完了。請(qǐng)大俠指導(dǎo)一下,謝謝
各位大俠先看代碼
1,#include <reg52.h>
2,bit cmdArrived = 0;   //命令到達(dá)標(biāo)志,即接收到上位機(jī)下發(fā)的命令
3,unsigned char cmdIndex = 0;//命令索引,與上位機(jī)約定好的數(shù)組編號(hào)
4,unsigned char *ptrTxd;//串口發(fā)送指針
5,unsigned char cntTxd = 0;//串口發(fā)送計(jì)數(shù)器
6,unsigned char array1[1] = {1};   //數(shù)組1
7,unsigned char array2[2] = {1,2}; //數(shù)組2
8,unsigned char array3[4] = {1,2,3,4}; //數(shù)組3
9,unsigned char array4[8] = {1,2,3,4,5,6,7,8};//數(shù)組4
10,void ConfigUART(unsigned int baud);
11,void main()
12,{
13,    EA = 1;  //開(kāi)總中斷
14,    ConfigUART(9600);  //配置波特率為9600
15,    while (1)
16,    {
17,        if(cmdArrived) 串口接收到數(shù)據(jù)標(biāo)志為真
18,        {
19,            cmdArrived = 0;
20,            switch(cmdIndex) //cmdIndex為串口接收的數(shù)值
21,            {
22,                case 1:
23,                ptrTxd = array1;//數(shù)組1的首地址賦值給發(fā)送指針
24,                cntTxd = sizeof(array1);//數(shù)組1的長(zhǎng)度賦值給發(fā)送計(jì)數(shù)器
25,                TI = 1;//手動(dòng)方式啟動(dòng)發(fā)送中斷,處理數(shù)據(jù)發(fā)送
26,                break;
27,                case 2:
28,                ptrTxd = array2;
29,                cntTxd = sizeof(array2);
30,                TI = 1;
31,                break;
32,                case 3:
33,                ptrTxd = array3;
34,                cntTxd = sizeof(array3);
35,                TI = 1;
36,                break;
37,                case 4:
38,                ptrTxd = array4;
39,                cntTxd = sizeof(array4);
40,                TI = 1;
41,                break;
42,                default:
43,                break;
44,            }
45,  }
46,}
47,}
48,void ConfigUART(unsigned int baud)
49,{
50,    SCON  = 0x50;  //配置串口為模式1
51,    TMOD &= 0x0F;  //清零T1的控制位
52,    TMOD |= 0x20;  //配置T1為模式2
53,    TH1 = 256 - (11059200/12/32)/baud;  //計(jì)算T1重載值
54,    TL1 = TH1;     //初值等于重載值
55,    ET1 = 0;       //禁止T1中斷
56,    ES  = 1;       //使能串口中斷
57,    TR1 = 1;       //啟動(dòng)T1
58,}
59,void InterruptUART() interrupt 4 //串口中斷服務(wù)函數(shù)
60,{
61,    if (RI)  //接收到字節(jié)
62,    {
63,        RI = 0;  //清零接收中斷標(biāo)志位
64,        cmdIndex = SBUF; //接收的數(shù)值送給cmdIndex
65,        cmdArrived = 1;  //設(shè)置命令到達(dá)標(biāo)志
66,    }
67,    if (TI)  //字節(jié)發(fā)送完畢
68,    {
69,        TI = 0;  //清零發(fā)送中斷標(biāo)志位
70,        if(cntTxd > 0)
71,        {
72,            SBUF = *ptrTxd;//發(fā)送指針指向的數(shù)據(jù)
73,            cntTxd--;//發(fā)送計(jì)數(shù)器遞減
74,            ptrTxd++;//發(fā)送計(jì)數(shù)器遞增
75,        }
ID:120930 發(fā)表于 2018-12-27 09:07 | 只看該作者
這個(gè)程序是用串口調(diào)試助手對(duì)單片機(jī)發(fā)送1,單片機(jī)回傳數(shù)組1.對(duì)單片機(jī)發(fā)送2,單片機(jī)回傳數(shù)組2.依次類推,最多到4
ID:120930 發(fā)表于 2018-12-27 09:10 | 只看該作者
這個(gè)程序是串口調(diào)試助手對(duì)單片機(jī)發(fā)送1 單片機(jī)回傳數(shù)組1. 對(duì)單片機(jī)發(fā)送2 單片機(jī)回傳數(shù)組2. 對(duì)單片機(jī)發(fā)送3 單片機(jī)回傳數(shù)組3.  對(duì)單片機(jī)發(fā)送4 單片機(jī)回傳數(shù)組4
