查看: 4119|回復(fù): 5
單片機(jī)轉(zhuǎn)速測(cè)量程序與仿真
ID:34643 發(fā)表于 2018-12-30 07:58 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
采用51單片機(jī)為主控電路,傳感器用光電管,電路設(shè)計(jì)含轉(zhuǎn)速采樣電路。數(shù)碼管采用4位一體共陰數(shù)碼管。下載地址: 單片機(jī)轉(zhuǎn)速測(cè)量程序與仿真.rar (153.78 KB, 下載次數(shù): 78)
部分源程序:(完整程序請(qǐng)自己下載)
#include <REG52.H>
#define ulong unsigned long
#define LED_DAT P0
sbit LED_SEG0 = P2^7;
sbit LED_SEG1 = P2^6;
sbit LED_SEG2 = P2^5;
sbit LED_SEG3 = P2^4;
sbit pin_SpeedSenser = P3^5;         //光電傳感器信號(hào)接在T1上
#define TIME_CYLC 200                         //12M晶振,定時(shí)器5ms 中斷一次 我們1秒計(jì)算一次轉(zhuǎn)速 // 1000ms/5ms = 200
#define PLUS_PER 1                         //碼盤的齒數(shù) ,這里假定碼盤上有10個(gè)齒,即傳感器檢測(cè)到10個(gè)脈沖,認(rèn)為1圈
#define K         100.0                   //校準(zhǔn)系數(shù)
unsigned char code  table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar data Disbuf[4];                        // 顯示緩沖區(qū)
uint Tcounter = 0,speed,PlusCounter;                           //時(shí)間計(jì)數(shù)器
bit Flag_Fresh = 0;                         // 刷新標(biāo)志
bit Flag_clac = 0;                                 //計(jì)算轉(zhuǎn)速標(biāo)志
bit Flag_Err = 0;                                 //超量程標(biāo)志 //在數(shù)碼管上顯示一個(gè)四位數(shù)
void DisplayFresh();                           //計(jì)算轉(zhuǎn)速,并把結(jié)果放入數(shù)碼管緩沖區(qū)
void ClacSpeed();                                   //初始化定時(shí)器T0
void init_timer0();                                   //初始化定時(shí)器T1
void init_timer1();                                   //延時(shí)函數(shù)
void Delay(uint ms);
void it_timer0() interrupt 1
        TF0 = 0;                                       //d定時(shí)器 T0用于數(shù)碼管的動(dòng)態(tài)刷新
        TH0 = 0xEC;
        TL0 = 0xA8;                            //78
        Tcounter++;
        if(Tcounter>TIME_CYLC)
                PlusCounter = TH1*256 + TL1;
            TH1=TL1 = 0x00;//脈沖計(jì)數(shù)清零
            Tcounter = 0;//周期定時(shí) 清零
                speed =60*PlusCounter/PLUS_PER;//
                 Flag_clac = 1;                        //周期到,該重新計(jì)算轉(zhuǎn)速了
        Flag_Fresh = 1;
void main(void)
        Disbuf[0] = 0; //開(kāi)機(jī)時(shí),初始化為0000
        Disbuf[1] = 0;
        Disbuf[2] = 0;
        Disbuf[3] = 0;
           init_timer0();
        init_timer1();
                if(Flag_Fresh)
                        Flag_Fresh = 0;
                    DisplayFresh();    // 定時(shí)刷新數(shù)碼管顯示
                   if(Flag_clac)
                        Flag_clac = 0;
                    ClacSpeed(); //計(jì)算轉(zhuǎn)速,并把結(jié)果放入數(shù)碼管緩沖區(qū)
                   if(speed>9999)        //超量程處理//數(shù)碼管顯示字母'EEEE'
                    Disbuf[0] = 0x9e; //開(kāi)機(jī)時(shí),初始化為0000
                    Disbuf[1] = 0x9e;
                    Disbuf[2] = 0x9e;
                    Disbuf[3] = 0x9e;
void DisplayFresh()
        LED_DAT =~table[Disbuf[0]];
        LED_SEG3 = 1;
        Delay(10);
        LED_SEG3 = 0;
        Delay(3);
        LED_DAT =~table[Disbuf[1]];
        LED_SEG2 = 1;
        Delay(10);
        LED_SEG2 = 0;
        Delay(3);
         LED_DAT =~table[Disbuf[2]];
        LED_SEG1 = 1;
        Delay(10);
        LED_SEG1 = 0;
         Delay(3);
        LED_DAT =~table[Disbuf[3]];
        LED_SEG0 = 1;
        Delay(10);
        LED_SEG0 = 0;
        Delay(3);
void ClacSpeed()
        Disbuf[0] = (speed/1000)%10;
        Disbuf[1] = (speed/100)%10;
        Disbuf[2] = (speed/10)%10;
        Disbuf[3] = speed%10;
//初始化定時(shí)器T0
void init_timer0()
        TMOD &= 0xf0; //定時(shí)10毫秒
        TMOD |= 0x01;
        TH0 = 0xC0;
        TL0 = 0x00;
        ET0=1;
        EA=1;
        TR0=1;
收藏收藏3 分享淘帖 頂 踩
ID:722043 發(fā)表于 2020-4-4 02:52 | 只看該作者
這個(gè)還是不錯(cuò)的
ID:724089 發(fā)表于 2020-4-9 16:11 | 只看該作者
想問(wèn)一下這個(gè)程序可以測(cè)量風(fēng)速吧,但我想加一個(gè)測(cè)量風(fēng)向的,是不是要重新弄一個(gè)
ID:555420 發(fā)表于 2020-5-23 21:11 | 只看該作者
只有我一個(gè)人打不開(kāi)嗎
ID:1154370 發(fā)表于 2025-6-17 17:31 | 只看該作者
如果加控制的話還可以用這個(gè)嗎
ID:540334 發(fā)表于 2025-6-20 23:59 來(lái)自觸屏版 | 只看該作者
這個(gè)很好,……。。。。。。。
