查看: 4440|回復(fù): 1
STC8單片機ad數(shù)模轉(zhuǎn)換速度電壓源程序
ID:460161 發(fā)表于 2019-1-2 15:54 | 顯示全部樓層 |閱讀模式
include "STC8.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC            11059200UL
#define BRT             (65536 - FOSC / 9600 / 4)
bit busy;
char wptr;
char rptr;
char buffer[16];
void Delay(WORD n)
    WORD x;
    while (n--)
        x = 5000;
        while (x--);
void UartIsr() interrupt 4 using 1
    if (TI)
        TI = 0;
        busy = 0;
    if (RI)
        RI = 0;
        buffer[wptr++] = SBUF;
        wptr &= 0x0f;
void UartInit()
    SCON = 0x50;
    TMOD = 0x00;
    TL1 = BRT;
    TH1 = BRT >> 8;
    TR1 = 1;
    AUXR = 0x40;
    wptr = 0x00;
    rptr = 0x00;
    busy = 0;
void UartSend(char dat)
    while (busy);
    busy = 1;
    SBUF = dat;
void UartSendStr(char *p)
    while (*p)
        UartSend(*p++);
void InitADC()
    P1M0 = 0xff;
    P1M1 = 0xff;
        P0M0 = 0xff;
    P0M1 = 0xff;
        ADCCFG = 0x0f;                              //設(shè)置ADC時鐘為系統(tǒng)時鐘/2/16/16
    ADC_CONTR = 0x80;                           //使能ADC模塊
BYTE GetADCResult(BYTE ch)
        ADC_CONTR |= (0x40+ch);
        _nop_();
    _nop_();
        _nop_();
    _nop_();
        _nop_();
    _nop_();_nop_();
    _nop_();_nop_();
    _nop_();_nop_();
    _nop_();_nop_();
    _nop_();_nop_();
    while (!(ADC_CONTR & 0x20));            //查詢ADC完成標志
        ADC_CONTR &= ~ADC_FLAG;         //Close ADC
    ADC_CONTR &= ~0x20;                     //清完成標志
    return ADC_RES;                           //讀取ADC結(jié)果
void ShowResult(BYTE ch)
    //UartSend(ch);                   //Show Channel NO.
    UartSend(GetADCResult(ch));     //Show ADC high 8-bit result
//if you want show 10-bit result, uncomment next line
//    SendData(ADC_LOW2);             //Show ADC low 2-bit result
    BYTE i=0;
        UartInit();
    ES = 1;
    EA = 1;
    //UartSendStr("Uart OK !\r\n");
        InitADC();                      //Init ADC sfr
    while (1)
                InitADC();
                //UartSend(1);
                ShowResult(11);
                Delay(100);
                InitADC();
                UartSend(2);
                //ShowResult(12);
                Delay(100);
                InitADC();
                UartSend(3);
                //ShowResult(13);
                Delay(100);
                InitADC();
                UartSend(4);
                //ShowResult(14);
                Delay(100);
ID:838732 發(fā)表于 2024-5-15 17:36 | 顯示全部樓層
點贊,測試可用!
