查看: 5789|回復(fù): 2
[分享]已解決
ID:10802 發(fā)表于 2009-4-6 20:44 | 顯示全部樓層 |閱讀模式
那個(gè)時(shí)鐘顯示的程序已經(jīng)顯示成功了,感謝大家對(duì)我這個(gè)單片機(jī)新手的幫助。所以把自己的這個(gè)程序貢獻(xiàn)出來(lái)和大家一起分享一下。還請(qǐng)大家多多指教。先謝過(guò)了。。。
42h----秒,41h-----分,40h----時(shí)
BUF_LED0  送給秒的個(gè)位
BUF_LED1  送給秒的十位
BUF_LED2  送給分的個(gè)位
BUF_LED3 送給秒的十位
BUF_LED4  送給秒的個(gè)位
BUF_LED5  送給秒的十位
一共用了六個(gè)數(shù)碼管進(jìn)行顯示
LED0 BIT P2.0
LED1 BIT P2.1
LED2 BIT P2.2
LED3 BIT P2.3
LED4 BIT P2.4
LED5 BIT P2.5
BUF_LED0  EQU   60H
BUF_LED1  EQU   61H
BUF_LED2  EQU   62H
BUF_LED3  EQU   63H
BUF_LED4  EQU   64H
BUF_LED5  EQU   65H
ORG  00H
AJMP MAIN
ORG  0BH
AJMP IT0P
MAIN: MOV P2,#0FFH
      MOV P0,#0FFH
      MOV BUF_LED0,#0C0H           ;設(shè)初值
      MOV BUF_LED1,#0C0H
      MOV BUF_LED2,#0C0H
      MOV BUF_LED3,#0C0H
      MOV BUF_LED4,#0C0H
      MOV BUF_LED5,#0C0H
      MOV DPTR,#TABLE
      MOV TMOD,#01H                   ;設(shè)定工作方式
      MOV 21H,#100
      CLR A
      MOV 42H,#00
      MOV 41H,#00
      MOV 40H,#00H
      MOV TH0,#0D8H
      MOV TL0,#0F0H
      SETB TR0
      MOV IE,#82H
HERE: CALL XIANSHI       ;等待中斷
      SJMP HERE
IT0P: PUSH Acc
      PUSH PSW
      MOV TH0,#0D8H
      MOV TL0,#0F0H
      DJNZ 21H,RETURN
      MOV 21H,#100
      MOV A,#01H
      ADD A,42H
      MOV 42H,A
      MOV B,#10
      DIV AB
      MOVC A,@A+DPTR
      MOV BUF_LED1,A
      MOV A,B
      MOVC A,@A+DPTR
      MOV BUF_LED0,A
      ;CALL LED_L0
      MOV R2,42H
      CJNE R2,#60,RETURN
      MOV 42H,#00
      MOV A,#01H
      ADD A,41H
      MOV 41H,A
      MOV R3,A
      MOV B,#10
      DIV AB
      MOVC A,@A+DPTR
      MOV BUF_LED3,A
      MOV A,B
      MOVC A,@A+DPTR
      MOV BUF_LED2,A
      ;CALL LED_L2
      CJNE R3,#60,RETURN
      MOV 41H,#00
      MOV A,#01H
      ADD A,40H
      ;DA A
      MOV 40H,A
      MOV R4,A
      MOV B,#0AH
      DIV AB
      MOVC A,@A+DPTR
      MOV BUF_LED5,A
      MOV A,B
      MOVC A,@A+DPTR
      MOV BUF_LED4,A
      ;CALL LED_L4
      CJNE R4,#24,RETURN
      MOV 40H,#00
RETURN:POP PSW
       POP Acc
       RETI
XIANSHI:
LED_L0:
       MOV P2,#11111110B
       MOV P0,BUF_LED0
       CALL DELAY
LED_L1:MOV P2,#11111101B
       MOV P0,BUF_LED1
       CALL DELAY
LED_L2:MOV P2,#11111011B
       MOV P0,BUF_LED2
       CALL DELAY
LED_L3:MOV P2,#11110111B
       MOV P0,BUF_LED3
       CALL DELAY
LED_L4:MOV P2,#11101111B
       MOV P0,BUF_LED4
       CALL DELAY
LED_L5:MOV P2,#11011111B
       MOV P0,BUF_LED5
       CALL DELAY
       RET
DELAY:MOV R5,#5         ;延時(shí)
   D2:MOV R6,#248
   D1:DJNZ R6,D1
      DJNZ R5,D2
      RET
TABLE:DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H
      END
游客,如果您要查看本帖隱藏內(nèi)容請(qǐng)回復(fù)
[此貼子已經(jīng)被作者于2009-4-9 16:20:00編輯過(guò)]
ID:9960 發(fā)表于 2009-4-6 22:30 | 顯示全部樓層
1,加上注釋會(huì)好看點(diǎn)。 2,MOV P2,11111110B 類似的這幾句好像少了個(gè)#號(hào), 3,我也是新手,所以目前只看出這幾點(diǎn)。
ID:10802 發(fā)表于 2009-4-8 11:20 | 顯示全部樓層
謝謝啊,你說(shuō)得很對(duì).
