查看: 1521|回復(fù): 1
小車紅外控制(stm32f4芯片)
ID:380211 發(fā)表于 2019-1-4 14:18 | 顯示全部樓層 |閱讀模式
#include "stm32f10x.h"
#include "interface.h"
#include "LCD1602.h"
#include "IRCtrol.h"
#include "motor.h"
//全局變量定義
unsigned int speed_count=0;//占空比計數(shù)器 50次一周期
char front_left_speed_duty=SPEED_DUTY;
char front_right_speed_duty=SPEED_DUTY;
char behind_left_speed_duty=SPEED_DUTY;
char behind_right_speed_duty=SPEED_DUTY;
unsigned char tick_5ms = 0;//5ms計數(shù)器,作為主函數(shù)的基本周期
unsigned char tick_1ms = 0;//1ms計數(shù)器,作為電機的基本計數(shù)器
unsigned char tick_200ms = 0;//刷新顯示
char ctrl_comm = 'S';//控制指令
unsigned char continue_time=0;
void InitIO()
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE , ENABLE);//使能LED使用的GPIO時鐘
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOE , &GPIO_InitStructure);//將使用LED燈相關(guān)的GPIO初始化
GPIO_SetBits(GPIOE , GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10);//關(guān)閉所有的LED指示燈
int main(void)
        delay_init();
        LCD1602Init();
        IRCtrolInit();
        TIM2_Init();
        MotorInit();
        ServoInit();
InitIO();
                         if(tick_5ms >= 5)
                        tick_5ms = 0;
                        tick_200ms++;
                        if(tick_200ms >= 40)
                                tick_200ms = 0;
                                LEDToggle(GPIO_Pin_8);
                        continue_time--;//200ms 無接收指令就停車
                        if(continue_time == 0)
                                continue_time = 1;
                                CarStop();
                        //do something
                        if(ir_rec_flag == 1)//接收到紅外信號
                                ir_rec_flag = 0;
                                switch(ctrl_comm)
                                        case COMM_UP:    CarGo();break;
                                        case COMM_DOWN:  CarBack();break;
                                        case COMM_LEFT:  CarLeft();break;
                                        case COMM_RIGHT: CarRight();break;
                                        case COMM_STOP:  CarStop();break;
                                        default : break;
                                LCD1602WriteCommand(ctrl_comm);
1.小車紅外遙控實驗.rar
275.84 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
ID:1 發(fā)表于 2019-1-4 17:49 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
