程序代碼
#include<reg51.h>
#include"st7565.h"
//---存一個圖片--//
unsigned char code pic[]={
/*-- 寬度x高度=128x64 --*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,
0x57,0x53,0x57,0x07,0xFF,0x0F,0xE3,0x0F,0xEF,0xFF,0xEF,0xEF,0xEF,0x03,0xEF,0xEF,
0xEF,0x0F,0xE3,0x0F,0xEF,0xFF,0x77,0x77,0x17,0x57,0x57,0x53,0x57,0x57,0x17,0x77,
0x77,0xFF,0xFB,0x8B,0xAB,0x83,0xAB,0x83,0xAB,0x8B,0xFF,0x37,0xDB,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEE,0xF5,
0xFB,0xF4,0xEF,0xE0,0xFF,0xF4,0xFB,0xF4,0xEF,0xFF,0xE0,0xEE,0xEE,0xEE,0xEE,0xE0,
0xFF,0xF4,0xFB,0xF5,0xEC,0xFF,0xE2,0xEF,0xEF,0xE1,0xFD,0xFD,0xFD,0xF9,0xF7,0xEF,
0xEE,0xFF,0xEB,0xF2,0xFA,0xE2,0xEA,0xFA,0xF2,0xEB,0xFF,0xE0,0xFD,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xE3,0x81,0x81,0xE3,0xFF,0xFF,0xDF,0xDD,0xD5,0x4D,0x9D,0x00,
0x9D,0x4D,0xD5,0xDD,0xDF,0xFF,0xFB,0xFB,0x00,0xFB,0xFB,0x9B,0xEB,0xFB,0x0F,0xE9,
0xEE,0xFF,0xEF,0xEE,0x2A,0xAA,0xAA,0xA8,0xA2,0x0A,0xAA,0x6E,0xEF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFE,0xFF,0x7F,0x78,
0x7F,0x7F,0xFE,0x7D,0x7D,0xBF,0xBB,0xBB,0xBA,0xBA,0x3A,0xBB,0xBB,0xBD,0xBE,0x7D,
0x7B,0xBF,0xBF,0xBF,0x78,0xFA,0xFA,0xFA,0xFA,0xF8,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x87,0xF8,0xFF,0xFF,
0xFF,0x7F,0x7E,0xBD,0xCF,0x73,0xBF,0xDB,0xDD,0xBD,0x7B,0xFE,0x7F,0xBB,0xDD,0xDD,
0xBB,0x7F,0xE7,0x9F,0x5F,0xBE,0x7D,0x73,0xEF,0x9F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFD,0x0D,0xF2,0xFC,
0xFE,0xFF,0xFF,0xEF,0x1F,0x3E,0xDC,0xE8,0xEB,0xED,0xDE,0xD7,0xD6,0xD4,0x68,0x6B,
0xED,0xF6,0xF7,0xEF,0x1F,0xFE,0xFD,0xF3,0x0E,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xC3,0x81,0x3C,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,
0xBD,0x00,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,0xBD,0xC3,0xFF,0xFC,0x73,
0x37,0x2F,0xAF,0xDE,0xDF,0xBF,0xAC,0x9B,0xB7,0xB7,0x6C,0x6C,0x6F,0x6F,0xB6,0xB6,
0xDB,0xCB,0xD5,0xAA,0x2F,0x37,0x7B,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,
0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,0xDF,0xDF,0xC1,0xC8,0xDC,
0xFF,0xF8,0xF7,0xEF,0xDF,0xF8,0xF2,0xF2,0xF8,0xFC,0xFE,0xFC,0xFC,0xFE,0xFC,0xF8,
0xF2,0xD2,0xE8,0xF7,0xF8,0xFF,0xDC,0xC8,0xC1,0xC3,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
* 函 數(shù) 名 : main
* 函數(shù)功能 : 主函數(shù)
* 輸 入 : 無
* 輸 出 : 無
void main(void)
uchar i , j;
uint n;
Lcd12864_Init(); //初始化
Lcd12864_ClearScreen(); //清屏
for (i=0;i<8;i++)
//--設置初始顯示開始位置--//
LcdSt7565_WriteCmd(0x40);
//--設置Y坐標--//
LcdSt7565_WriteCmd(0xB0+i);
//--設置X坐標--//
LcdSt7565_WriteCmd(0x10);
LcdSt7565_WriteCmd(0x04);
for(j=0; j<128; j++)
LcdSt7565_WriteData(~pic[n]);
n=n+1;
while (1)
//---重定義關鍵詞---//
#ifndef uchar
#endif
#ifndef uint
#endif
//--定時使用的IO口--//
#define DATA_PORT P0
sbit LCD12864_CS = P3^2;
sbit LCD12864_RSET = P3^3;
sbit LCD12864_RS = P2^6;
sbit LCD12864_RW = P2^7;
sbit LCD12864_RD = P2^5;
//--定義全局函數(shù)--//
void LcdSt7565_WriteCmd(cmd);
void LcdSt7565_WriteData(dat);
void Lcd12864_Init();
void Lcd12864_ClearScreen(void);
uchar Lcd12864_Write16CnCHAR(uchar x, uchar y, uchar *cn);
#endif
#include"st7565.h"
* 函 數(shù) 名 : LCD12864_WriteCmd
* 函數(shù)功能 : 寫入一個命令到12864
* 輸 入 : cmd
* 輸 出 : 無
LCD12864_CS = 0; //chip select,打開片選
LCD12864_RD = 1; //disable read,讀失能
LCD12864_RS = 0; //select command,選擇命令
LCD12864_RW = 0; //select write,選擇寫模式
_nop_();
_nop_();
DATA_PORT = cmd; //put command,放置命令
_nop_();
_nop_();
LCD12864_RW = 1; //command writing ,寫入命令
* 函 數(shù) 名 : LcdSt7565_WriteData
* 函數(shù)功能 : 寫入一個數(shù)據(jù)到12864
* 輸 入 : dat
* 輸 出 : 無
LCD12864_RS = 1; //select data,選擇數(shù)據(jù)
_nop_();
_nop_();
DATA_PORT = dat; //put data,放置數(shù)據(jù)
_nop_();
_nop_();
LCD12864_RW = 1; //data writing,寫數(shù)據(jù)
* 函 數(shù) 名 : LCD12864_Init
* 函數(shù)功能 : 初始化12864
* 輸 入 : 無
* 輸 出 : 無
* 說 明 : LCD12864的命令指令可以查看例程文件夾下的《ST7565p數(shù)據(jù)手冊》
* * 的第51頁的位置。
uchar i;
LCD12864_RSET = 0;
for (i=0; i<100; i++);
LCD12864_CS = 0;
LCD12864_RSET = 1;
//----------------Star Initial Sequence-------//
//------程序初始化設置,具體命令可以看文件夾下---//
//--軟件初始化--//
LcdSt7565_WriteCmd(0xE2); //reset
for (i=0; i<100; i++); //延時一下
//--表格第8個命令,0xA0段(左右)方向選擇正常方向(0xA1為反方向)--//
LcdSt7565_WriteCmd(0xA1); //ADC select segment direction
//--表格第15個命令,0xC8普通(上下)方向選擇選擇反向,0xC0為正常方向--//
LcdSt7565_WriteCmd(0xC8); //Common direction
//--表格第9個命令,0xA6為設置字體為黑色,背景為白色---//
//--0xA7為設置字體為白色,背景為黑色---//
LcdSt7565_WriteCmd(0xA6); //reverse display
//--表格第10個命令,0xA4像素正常顯示,0xA5像素全開--//
LcdSt7565_WriteCmd(0xA4); //normal display
//--表格第11個命令,0xA3偏壓為1/7,0xA2偏壓為1/9--//
LcdSt7565_WriteCmd(0xA2); //bias set 1/9
//--表格第19個命令,這個是個雙字節(jié)的命令,0xF800選擇增壓為4X;--//
//--0xF801,選擇增壓為5X,其實效果差不多--//
LcdSt7565_WriteCmd(0xF8); //Boost ratio set
LcdSt7565_WriteCmd(0x01); //x4
//--表格第18個命令,這個是個雙字節(jié)命令,高字節(jié)為0X81,低字節(jié)可以--//
//--選擇從0x00到0X3F。用來設置背景光對比度。---/
LcdSt7565_WriteCmd(0x81); //V0 a set
LcdSt7565_WriteCmd(0x23);
//--表格第17個命令,選擇調節(jié)電阻率--//
LcdSt7565_WriteCmd(0x25); //Ra/Rb set
//--表格第16個命令,電源設置。--//
LcdSt7565_WriteCmd(0x2F);
//--表格第2個命令,設置顯示開始位置--//
LcdSt7565_WriteCmd(0x40); //start line
//--表格第1個命令,開啟顯示--//
LcdSt7565_WriteCmd(0xAF); // display on
* 函 數(shù) 名 : LCD12864_ClearScreen
* 函數(shù)功能 : 清屏12864
* 輸 入 : 無
* 輸 出 : 無
uchar i, j;
for(i=0; i<8; i++)
//--表格第3個命令,設置Y的坐標--//
//--Y軸有64個,一個坐標8位,也就是有8個坐標--//
//所以一般我們使用的也就是從0xB0到0x07,就夠了--//
//--表格第4個命令,設置X坐標--//
//--當你的段初始化為0xA1時,X坐標從0x10,0x04到0x18,0x04,一共128位--//
//--當你的段初始化為0xA0時,X坐標從0x10,0x00到0x18,0x00,一共128位--//
//--在寫入數(shù)據(jù)之后X坐標的坐標是會自動加1的,我們初始化使用0xA0所以--//
//--我們的X坐標從0x10,0x00開始---//
//--X軸有128位,就一共刷128次,X坐標會自動加1,所以我們不用再設置坐標--//
LcdSt7565_WriteData(0x00); //如果設置背景為白色時,清屏選擇0XFF
* 函 數(shù) 名 : LCD12864_Write16CnCHAR
* 函數(shù)功能 : 在12864上面書寫16X16的漢字
* 輸 入 : x, y, cn
* 輸 出 : 無
* 說 明 : 該函數(shù)可以直接書寫字符串,但是書寫是從右到左,所以輸入的時
* * 侯注意輸入。漢字的取模方式請觀看文件夾下的《漢字取模軟件的
* * 使用說明》
#ifdef CHAR_CODE
#include"charcode.h"
uchar j, x1, x2, wordNum;
//--Y的坐標只能從0到7,大于則直接返回--//
if(y > 7)
return 0;
//--X的坐標只能從0到128,大于則直接返回--//
if(x > 128)
return 0;
y += 0xB0; //求取Y坐標的值
//--設置Y坐標--//
LcdSt7565_WriteCmd(y);
while ( *cn != '\0') //在C語言中字符串結束以‘\0’結尾
//--設置Y坐標--//
x1 = (x >> 4) & 0x0F; //由于X坐標要兩句命令,分高低4位,所以這里先取出高4位
x2 = x & 0x0F; //去低四位
//--設置X坐標--//
LcdSt7565_WriteCmd(0x10 + x1); //高4位
LcdSt7565_WriteCmd(0x04 + x2); //低4位
for (wordNum=0; wordNum<50; wordNum++)
//--查詢要寫的字在字庫中的位置--//
if ((CN16CHAR[wordNum].Index[0] == *cn)
&&(CN16CHAR[wordNum].Index[1] == *(cn+1)))
for (j=0; j<32; j++) //寫一個字
if (j == 16) //由于16X16用到兩個Y坐標,當大于等于16時,切換坐標
//--設置Y坐標--//
LcdSt7565_WriteCmd(y + 1);
//--設置X坐標--//
LcdSt7565_WriteData(CN16CHAR[wordNum].Msk[j]);
x += 16;
}//if查到字結束
} //for查字結束
cn += 2;
} //while結束
return 1;
#endif
