查看: 4894|回復(fù): 0
用LCD1602顯示輸出8位可連續(xù)進(jìn)行簡(jiǎn)單的加減乘除運(yùn)算,包含單片機(jī)代碼
功能:用LCD1602顯示輸出8位可連續(xù)進(jìn)行簡(jiǎn)單的加減乘除運(yùn)算
說(shuō)明:無(wú)論與0相乘還是相除輸出結(jié)果是隨機(jī)的,錯(cuò)誤的;
      除法輸出是帶小數(shù)點(diǎn)的8位數(shù)字顯示輸出,還沒(méi)有繼續(xù)小數(shù)點(diǎn)轉(zhuǎn)換
#include <reg52.h>
sbit rs=P2^2;
sbit rw=P2^1;
sbit e=P2^0;
void write_dat(uchar dat);
void write_com(uchar com);
void process(void);
void keyscan();
/*按鍵功能*/
uchar code table1[]=
1,2,3,0x2b-0x30,                   // 1,   2,   3,    +
4,5,6,0x2d-0x30,                   // 4,   5,   6,    -
7,8,9,0x2a-0x30,                   // 7,   8,   9,    x
0,0x3d-0x30,0x01-0x30,0x2f-0x30       // 0,   =,   清零, /
uchar k=0,flag=0,num,fuhao[6],i,temp1=0,flag1=0;
long a,b,c,d;
void delay(uint z)
    uint x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
/********按鍵處理***********/
void keyscan()
    uchar temp;
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    while(temp!=0xf0)
       delay(5);
       temp=P3;
       temp=temp&0xf0;
       while(temp!=0xf0)
           temp=P3;
           switch(temp)
              case 0xee:num=0;
                break;
              case 0xde:num=1;
                break;
              case 0xbe:num=2;
                break;
              case 0x7e:num=3;
                break;
             while(temp!=0xf0)         // 松手檢測(cè)
                { temp=P3;
                  temp=temp&0xf0;
       if(num==0||num==1||num==2)
            if(flag==0)
               a=a*10+table1[num]; //如果沒(méi)有按符號(hào)鍵,符號(hào)前的數(shù)值為a
            else if(flag==1)
               b=b*10+table1[num];  //如果按了符號(hào)鍵,符號(hào)后的數(shù)值為b
            else if(temp1>=2&&flag1==1)
             flag=1;
             flag1=0;
             process();
             a=c;
             b=table1[num];
            if(k==1)
                k=0;
                write_com(0x01);
        else if(num==3)
             flag++;
             flag1=1;
             temp1++;
           fuhao[temp1-1]=1;
      i=table1[num];    //顯示按下的鍵
      write_dat(0x30+i);
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    while(temp!=0xf0)
       delay(5);
       temp=P3;
       temp=temp&0xf0;
       while(temp!=0xf0)
           temp=P3;
           switch(temp)
              case 0xed:num=4;
                break;
              case 0xdd:num=5;
                break;
              case 0xbd:num=6;
                break;
              case 0x7d:num=7;
                break;
             while(temp!=0xf0)
                { temp=P3;
                 temp=temp&0xf0;
         if(num==4||num==5||num==6)
                 if(k==1)
                    k=0;
                    write_com(0x01);
             if(flag==0)
                a=a*10+table1[num];
             else if(flag==1)
                b=b*10+table1[num];
                 flag=1;
                 flag1=0;
                 process();
                    a=c;
                 b=table1[num];
         else if(num==7)
             flag++;
             temp1++;
             flag1=1;
             fuhao[temp1-1]=2;
         i=table1[num];
         write_dat(0x30+i);
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    while(temp!=0xf0)
       delay(5);
       temp=P3;
       temp=temp&0xf0;
       while(temp!=0xf0)
           temp=P3;
           switch(temp)
              case 0xeb:num=8;
                break;
              case 0xdb:num=9;
                break;
              case 0xbb:num=10;
                break;
              case 0x7b:num=11;
                break;
             while(temp!=0xf0)
                { temp=P3;
                 temp=temp&0xf0;
           if(num==8||num==9||num==10)
               if(k==1)
                    k=0;
                    write_com(0x01);
               if(flag==0)
                  a=a*10+table1[num];
               else if(flag==1)
                  b=b*10+table1[num];
                 flag=1;
                 flag1=0;
                 process();
                    a=c;
                 b=table1[num];
           else if(num==11)
                flag++;
                temp1++;
                flag1=1;
                fuhao[temp1-1]=3;
           i=table1[num];
           write_dat(0x30+i);
       P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    while(temp!=0xf0)
       delay(5);
       temp=P3;
       temp=temp&0xf0;
       while(temp!=0xf0)
           temp=P3;
           switch(temp)
              case 0xe7:num=12;    // 0鍵
                break;
              case 0xd7:num=13;     // '='
                break;
              case 0xb7:num=14;     //清零鍵
                break;
              case 0x77:num=15;        //除號(hào)鍵
                break;
             while(temp!=0xf0)
                { temp=P3;
                 temp=temp&0xf0;
          switch(num)
             case 12:
                  if(k==1)
                    k=0;
                    write_com(0x01);
                 if(flag==0)
                   a=a*10;
                 else if(flag==1)
                   b=b*10;
                 flag=1;
                 flag1=0;
                 process();
                    a=c;
                 b=table1[num];
                   write_dat(0x30);
                   break;
             case 13:
                  k=1;
                  if(temp1>=2)
                     fuhao[0]=fuhao[temp1-1];
                 if(fuhao[0]==1)
                     write_com(0x80+0x4f);
                     write_com(0x04);
                     c=a+b;
                     d=c;
                     while(c!=0)
                        write_dat(0x30+c%10);
                        c=c/10;
                    write_dat(0x3d);
                     fuhao[0]=0;fuhao[1]=0;fuhao[2]=0;
                    fuhao[3]=0;fuhao[4]=0;fuhao[5]=0;
                    a=0;b=0;flag=0;flag1=0;temp1=0;
                 if(fuhao[0]==2)
                    write_com(0x04);
                     if(a>=b)
                      c=a-b;
                      d=c;
                      while(c!=0)
                         c=c/10;
                    else if(a<b)
                       c=b-a;
                       d=c;
                       while(c!=0)
                           c=c/10;
                      write_dat(0x2d);
                    write_dat(0x3d);
                 if(fuhao[0]==3)
                    write_com(0x04);
                    c=a*b;
                    d=c;
                    while(c!=0)
                       c=c/10;
                    write_dat(0x3d);
                 if(fuhao[0]==4)
                     i=0;
                     write_com(0x04);
                    c=(long)(((float)a/b)*1000000);
                    d=c;
                    while(c!=0)
                       c=c/10;
                       i++;
                       if(i==6)
                        write_dat(0x2e);
                    if(a/b<=0)
                     write_dat(0x30);
                     write_dat(0x3d);
              break;
            case 14:
                { write_com(0x01);
                 a=0;b=0;flag=0;temp1=0;flag1=0;
                 break;
             case 15:
                    flag++;
                    temp1++;
                    flag1=1;
                    fuhao[temp1-1]=4;
                     write_dat(0x30+table1[num]);
                   break;
/*******led1602顯示*******/
   rs=0;
   rw=0;
   P0=com;
   e=1;
   delay(5);
   e=0;
   rs=1;
   rw=0;
   P0=dat;
   e=1;
   delay(5);
   e=0;
void process(void)
         if(fuhao[temp1-2]==1)    //如果符號(hào)鍵是+,執(zhí)行加法運(yùn)算
           c=a+b;
           b=0;
          }                        // 如果符號(hào)鍵是-,執(zhí)行減法運(yùn)算
         if(fuhao[temp1-2]==2)
            c=a-b;
            b=0;
          if(fuhao[temp1-2]==3)   //如果符號(hào)鍵是*執(zhí)行乘法運(yùn)算
            c=a*b;
            b=0;
          if(fuhao[temp1-2]==4)      //如果符號(hào)鍵是/ 執(zhí)行除法運(yùn)算
            c=(long)((float)a/b);
            b=0;
/*液晶的初始化*/
void init()  //初始化
   delay(15);
   write_com(0x38);
   delay(6);
   write_com(0x38);
   delay(6);
   write_com(0x38);
   write_com(0x38);
   write_com(0x0c);  //開(kāi)顯示,關(guān)光標(biāo)
   write_com(0x06);  //光標(biāo)移動(dòng)
   write_com(0x01);  //清屏
    init();
      keyscan();
計(jì)算器.zip
86.09 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
源碼
收藏收藏 分享淘帖 頂1 踩
