時(shí)間有限,只用了數(shù)碼管顯示一位的數(shù)的加減乘除
唯一的兩個(gè)亮點(diǎn),就是減法數(shù)碼管能顯示負(fù)數(shù)
除法能顯示小數(shù)
所有的Proteus仿真圖和C源代碼都在里面
- #include<reg52.h>
- #include<intrins.h>
- #include<math.h>
- sbit Sel1=P3^0;
- sbit Sel2=P3^1;
- sbit Sel3=P3^2;
- sbit Sel4 =P3^3;
- sbit Sel5=P3^4;
- sbit Sel6 =P3^5;
- sbit led=P2^0;
- unsigned char line=0,cross=0,comline=0,comcross=0;//顯示掃描后的行列值
- unsigned char shu1=0,shu2=0;//顯示計(jì)算的數(shù)據(jù)
- unsigned char keynum=0,workflag=0;
- int keyflag=0,i=0,cons=0,cons1,cons2; //顯示按鍵和運(yùn)算狀態(tài)的邏輯標(biāo)志變量
- unsigned char Shuma[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//數(shù)碼管段碼值
- unsigned char Shuma1[10]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};//數(shù)碼管段碼值
- void delay(int k); //延時(shí)函數(shù)
- void Keycode(); //鍵盤編碼函數(shù)
- void Keys(); //鍵盤掃描函數(shù)
- void main()
- unsigned char n=0;
- unsigned int temp=0;
- TMOD=0x01;
- TH0=(2^16-50000)/2^8;TL0=(2^16-50000)%2^8;EA=1;TR0=1;ET0=1;
- while(1)
- Keycode();
- if(keyflag == 1)
- shu1 = keynum;
- else if(keyflag == 2)
- shu2 = keynum;
- else if(keyflag == 3)
- switch(workflag)
- case 1:cons = shu1+shu2;break;
- case 2:cons = shu1-shu2;break;
- case 3:cons = shu1*shu2;break;
- case 6:temp =(int)(((float)(shu1)/(float)(shu2))*10);cons1 = temp/10;cons2=temp%10;
- break;
- default:break;
- else ;
- if (workflag == 5)
- keyflag = 0;cross=0;line=0;workflag=0;keynum=0;P0=0xff;
- shu1=0;shu2=0;cons=0;
- for(n=0;n<8;n++)
- switch(n)
- case 0:Sel1=1,Sel2=0,Sel3=0,Sel4=0,Sel5=0,Sel6=0;P0=~Shuma[shu1/10];break;
- case 1:Sel1=0,Sel2=1,Sel3=0,Sel4=0,Sel5=0,Sel6=0;P0=~Shuma[shu1%10];break;
- case 2:Sel1=0,Sel2=0,Sel3=1,Sel4=0,Sel5=0,Sel6=0;P0=~Shuma[shu2/10];break;
- case 3:Sel1=0,Sel2=0,Sel3=0,Sel4=1,Sel5=0,Sel6=0;P0=~Shuma[shu2%10];break;
- case 4:Sel1=0,Sel2=0,Sel3=0,Sel4=0,Sel5=1,Sel6=0;
- if(cons >= 0)
- P0=~Shuma[cons/10];
- else
- P0=0xBF;
- if(workflag == 6)
- P0=~Shuma1[cons1];
- }break;
- case 5:Sel1=0,Sel2=0,Sel3=0,Sel4=0,Sel5=0,Sel6=1;
- P0=~Shuma[abs(cons)%10];
- if(workflag == 6)
- P0=~Shuma[cons2];break;
- default:break;
- delay(20);
- P0=0xff;
- void delay(int k)
- while(k--);
- void Keycode()
- switch(cross)
- case 1:
- switch(line)
- case 1:keynum=1;break;
- case 2:keynum=2;break;
- case 3:keynum=3;break;
- case 4:workflag=1;break;
- default:break;
- };break;
- case 2:
- switch(line)
- case 1:keynum=4;break;
- case 2:keynum=5;break;
- case 3:keynum=6;break;
- case 4:workflag=2;break;
- default:break;
- };break;
- case 3:
- switch(line)
- case 1:keynum=7;break;
- case 2:keynum=8;break;
- case 3:keynum=9;break;
- case 4:workflag=3;break;
- default:break;
- };break;
- case 4:
- switch(line)
- case 1:keynum=0;break;
- case 2:workflag=4;break;
- case 3:workflag=5;break;
- case 4:workflag=6;break;
- default:break;
- };break;
- default:break;
- void Keys()
- P1=0xf0;
- if( P1 != 0xf0)
- keyflag++;
- switch(P1)
- case 0x70:cross=1;break;
- case 0xb0:cross=2;break;
- case 0xd0:cross=3;break;
- case 0xe0:cross=4;break;
Calculate.rar
(17.67 KB, 下載次數(shù): 116)
2019-1-11 19:46 上傳
點(diǎn)擊文件名下載附件
