#include "reg51.h"
#include "stdio.h"
#include "intrins.h"
#include "LCD1602.h"
#include "fmq.h"
#include "key.h"
sbit dq=P2^3;
uchar wenduh;
uchar wendul;
uchar shiduh;
uchar shidul;
uchar wendu;
uchar shidu;
uchar wendus;
uchar shidus;
uchar wendux;
uchar shidux;
uchar keyv;
uchar mode;
uchar n=0;
uchar x;
//uchar flag=2;
void delay1(uint n)
uint i,j;
for(i=0;i<n;i++)
for(j=0;j<100;j++);
bit init_dht11()
uchar num;
bit flag;
dq=0;
delay1(20);
dq=1;
for(num=0;num<11;num++);
for(num=0;num<12;num++);
flag=dq;
for(num=0;num<24;num++);
return flag;
uchar dht11_rd_char()
uchar byte=0;
uchar num;
uchar num1;
while(dq==1);
for(num1=0;num1<8;num1++)
while(dq==0);
byte<<=1;
for(num=0;dq==1;num++);
if(num<10)
byte|=0x00;
byte|=0x01;
return byte;
void dht11_dushu()
uchar num;
if(init_dht11()==0)
shiduh=dht11_rd_char();
shidul=dht11_rd_char();
wenduh=dht11_rd_char();
wendul=dht11_rd_char();
shidu=(shiduh*256+shidul)/10;
wendu=(wenduh*256+wendul)/10;
for(num=0;num<20;num++);
dq=1;
shidu=00;
wendu=00;
void display()
write_char(1,0,'w');
write_char(1,1,'n');
write_char(1,2,'d');
write_char(1,3,'u');
write_char(1,4,':');
write_data(wendu/10%10+48);
write_data(wendu%10+48);
write_char(1,9,0xdf);
write_char(1,10,'C');
write_char(2,0,'s');
write_char(2,1,'h');
write_char(2,2,'i');
write_char(2,3,'d');
write_char(2,4,'u');
write_char(2,5,':');
write_data(shidu/10%10+48);
write_data(shidu%10+48);
write_char(2,10,'%');
wendu=0;
shidu=0;
wendus=40;
wendux=20;
shidus=90;
shidux=20;
delay1(100);
Init_LCD1602();
dht11_dushu();
delay1(300);
if(n%2==0)
display();
delay1(300);
else if(n%2==1)
write_str(1,0,"wMax:");
write_data(wendus/10%10+48);
write_data(wendus%10+48);
write_str(2,0,"wMin:");
write_data(wendux/10%10+48);
write_data(wendux%10+48);
write_str(1,8,"sMax:");
write_data(shidus/10%10+48);
write_data(shidus%10+48);
write_str(2,8,"sMin:");
write_data(shidux/10%10+48);
write_data(shidux%10+48);
if(k2==0)
write_com(0x01);
delay1(10);
if(k2==0)
x++;
if(x%4==1)
write_char(1,7,'<');
if(k3==0)
delay1(10);
if(k3==0)
wendus++;
else if(k4==0)
delay1(10);
if(k4==0)
wendus--;
else if(x%4==2)
write_char(2,7,'<');
if(k3==0)
delay1(10);
if(k3==0)
wendux++;
else if(k4==0)
delay1(10);
if(k4==0)
wendux--;
else if(x%4==3)
write_char(1,15,'<');
if(k3==0)
delay1(10);
if(k3==0)
shidus++;
else if(k4==0)
delay1(10);
if(k4==0)
shidus--;
else if(x%4==0)
write_char(2,15,'<');
if(k3==0)
delay1(10);
if(k3==0)
shidux++;
else if(k4==0)
delay1(10);
if(k4==0)
shidux--;
if(k1==0)
delay1(10);
if(k1==0)
n++;
write_com(0x01);
溫度測量上下限.rar
2019-1-12 15:20 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
51.1 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
