查看: 3551|回復(fù): 1
arduino EEPROM 無(wú)法保存數(shù)據(jù)問(wèn)題
ID:389836 發(fā)表于 2019-1-12 16:07 | 顯示全部樓層 |閱讀模式
arduino 寫入數(shù)據(jù),斷掉重啟后,不能保存當(dāng)前數(shù)據(jù),是什么情況,還是我的代碼有問(wèn)題?
#include <EEPROM.h>
int D2_ON=A1;
int D1_OFF=A0;
int OUT=5;
int addr=0;
int state;
void setup() {
Serial.begin(9600);
while(!Serial);
pinMode(D2_ON,INPUT);
pinMode(D1_OFF,INPUT);
pinMode(OUT,OUTPUT);
void loop() {
  int i=0;
  int value_ON=digitalRead(D2_ON);
  int value_OFF=digitalRead(D1_OFF);
  if((value_ON==1)||(value_OFF==1)){
    if(value_ON==1){
      state=1;
    }else if(value_OFF==1){
      state=0;
   /*EEPROM.update(i, state);
  if( EEPROM.read(addr)!= state ){
      EEPROM.write(addr, state);
    int result= EEPROM.read(i);
    if(result==1){
      digitalWrite(OUT,HIGH);
    if(result==0){
      digitalWrite(OUT,LOW);
    Serial.print(i);
    Serial.print("\n");
    Serial.print("result:");
    Serial.print(result);
    Serial.print("\n");
    delay(10);
ID:832314 發(fā)表于 2020-12-24 16:43 | 顯示全部樓層
arduino EEPROM 數(shù)據(jù)保存方法:
每次寫入數(shù)據(jù)后需要執(zhí)行 EEPROM.commit(); 函數(shù),才會(huì)真正的將數(shù)據(jù)保存到內(nèi)部Flash存儲(chǔ)中,掉電后不會(huì)丟失。
